Fast solve Sony PMW-150 MXF footage to Premiere Pro issues
Postod lydia622520 » 24.06.2013 10:52
Summary: Follow this article, you can solve your Sony PMW-150 50Mb/s MXF files to Adobe Premiere Pro CS6/CS5/CS4 importing and editing issues. Read on to seek for the solution.
The PMW-150 is a compact camcorder with three 1/3-inch-type Full-HD sensors. One of the main highlights is that it records in broadcast friendly Full HD MPEG HD422 at 50 Mbps in MXF format – widely accepted in broadcasting stations and production houses -which will be important in many different applications, including newsgathering and documentary production. While, it becomes a pain when you cannot preview it on Mac, let along transferring the MXF to Adobe Premiere Pro CS6, CS5, CS4 for editing.
Although Adobe Premiere Pro is highly effective to edit visual effects compositing and achieve image adjustment or color correction. However the difficulty comes when import raw videos from specialist full-HD camcorders for example Sony PMW-150. To get Sony PMW-150 .mxf work in Premier Pro well, you’d better to convert Sony PMW-150 videos to Adobe highly supported format. Here is a workable solution for you- Brorosft MXF Converter for Mac, a practical Sony PMW-150 MXF to Adobe Premiere Pro Converter for Mac users to complete the conversion. In addition, this Mac MXF Converter can also help import MXF to FCP, iMovie, Avid Media Composer, etc without quality loss as well as quickly on Mac OS X(including Lion and Mountain Lion).
Just download it and follow the workflow using Adobe Premiere Pro with Sony .mxf files under Mac.
1. Install and launch the MXF to Premiere Pro Converter on your Mac, click Add button to load individual videos, otherwise you can ‘Add from folder’ to load all the raw videos in .mxf format.
2. Choose output format. Click “Format” bar, and you can get the optimized videos Adobe Premiere/Sony Vegas --> MPEG-2(*.mpg). If you like, you can click “Settings” to change the video encoder, resolution, frame rate, etc.
3. After above settings, you can click “Convert” button to start the conversion from Sony .mxf to .mpg for Adobe Premiere Pro on Mac OS X.
After the process, press “Open” to locate converted files for Premiere Pro. Now open up your Adobe and you’re ready to import Sony MXF to Adobe CS4/CS5/CS6 for post-production without any issue.
More about MXF Transcoding solutions:
How to Play MXF files with VLC
How to transcode MXF to MOV on Mac
How to ingest Sony XDCAM HD422 Media to Avid
Fast solve Sony PMW-320 MXF and FCP incompatible issues
Transcode Sony PMW-320 MXF to AIC MOV for iMovie
Take MXF clips off Sony PMW-200 and Edit with Avid MC
Source: Enable Sony PMW-150 50Mb/s MXF to work with Premiere Pro
Best MVI Converter- Change MVI into AVI, WMV, FLV, MOV, DVD
lydia622520
Postova:  84
