Rip/Put/Move DVD movies onto Blackberry Z10
Postod kelly456 » 25.03.2013 8:42
Want to play DVD movies on BlackBerry Z10? What's the best settings to rip DVDs for the new BlackBerry Z10? Here you will find the best answer.
The BlackBerry Z10 has a 4.2" LCD touchscreen with a resolution of 768 x 1280 pixels, which puts it in HD category. Throw in its battery life and obvious portability, the Z10 can be used as a great media player for watching movies. If you have some DVD movie collections and want to download the DVDs to BlackBerry Z10 for playback. You've come to the right place. The article here will help you better enjoy your DVDs on BlackBerry Z10. Keep reading for a brief how-to process.
The process is much easier than you may think. Below I will take Pavtube DVD Ripper for example to show you how to rip DVD movies to BlackBerry Z10 supported video formats in just three step within clicks.
Overall, Pavtube DVD Ripper (The equivalent Mac version) is easy to use for editing and conversion and makes great quality copies of my DVDs. It helps me rip and convert all the DVD Discs even DVD iso/ifo image files. The audio/video synchronization is very good, the size of the subtitles too. I tried several softwares and I can tell you that NO ONE comes even close to the simpleness and great quality that Pavtubes softwares deliver. The time it takes to convert in this software is almost half that in other.
Guide: How to Convert DVD to play on BlackBerry Z10
The quick start guide below uses BlackBerry DVD Ripper Windows screenshots. The way to encode DVD movies to BlackBerry Z10 on Mac is almost the same. Just make sure you get the right version according to your computer operating system.
Step 1: Load DVD Movies
Open DVD to BlackBerry Converter, insert the DVD disc to your computer drive, and then click the "DVD Disc" icon on the interface to navigate to the videos you want to convert. As you see, you can also add ISO file, IFO file or DVD folder.
Step 2: Specify output format
Select the suitable output video format. Click "Format" bar, you can easily find the optimized videos for BlackBerry Z10 under "BlackBerry > BlackBerry Playbook HD 720p(*.mp4)". The preset is specially designed for Playbook but the output videos could fit on BlackBerry Z10 perfectly and supplies full-screen playback.
What are the best settings to rip DVDs for output on the new blackberry Z10?
The supported resolution of BlackBerry Z10 goes up to 1080p, though video playback and most apps never break out of 720p. For watching videos on Z10, 720p with 1500~2000kbps is just all right. I find that bitrate higher results in big file size, and lower visible quality loss (Click "Settings" to change the video encoder, resolution, frame rate, etc). Below is the best format settings per my experience:
Codec- H.264
Resolution- 1280×720
Bitrate- 1500/2000kbps
Framerate- 24fps
Codec- AAC
Sampling rate- 44.1khz
Bitrate- 128kbps
Channel- stereo
Step 3: Start the conversion
When you are satisfied with all the settings, you can click "Convert" and let the software do the DVD to BlackBerry Z10 MP4 conversion. After the ripping, you can click "Open" to locate the converted MP4 video files and just transfer the media files to your BlackBerry Z10. Now you can successfully rip and play your DVD movies on BlackBerry Z10 without limitations!
See also:
Watch MKV, AVI, WMV, VOB and flash videos on Blackberry Z10
If your movie isn't already in one of the BlackBerry supported formats or it's still on a DVD or a Blu-ray, you can get the Video Converter Ultimate (or the iMedia Converter Mac)which can help you rip Blu-ray/DVD, and convert various formats of 720p/1080p HD videos in MKV, AVI, TiVo, VOB, MPG, MTS, etc. to your BlackBerry PlayBook, BlackBerry Z10 or your Android/iOS/Windows RT(8) based tablets/phones for smoothly playing.
PS. If you have any problem, pls contact with [email protected] to get more information. You also can leave a message on Pavtube Community or Pavtube Facebook, we will answer your questions as soon as possilble.
Buy One Get Another Free? Yes, just join Pavtube's Special Offer to get the promotion.
