Burn home movie from iMovie to DVD for playback on TV
Postod kelly456 » 22.03.2013 9:44
Summary: Follow this article below you can find an easy way to burn home movie from iMovie to DVD for playback on TV, free try now!
Have you ever want to burn some home movies to DVD disc from your recordings? As the cameras and camcorders are more and more popular, you must have recorded many high-definition video footages, why not burn them to DVD disc so that you can play the videos on TV via DVD players?
Don't know how to burn?
The reason maybe you don't know which software can easily burn movie to DVD from editing software like iMovie, fcp on Mac, or you may have encountered many problems, such as compatibility, exporting from editing software, just like this user's problems below.
Burning problems?
"I successfully burned a DVD with a free DVD Creator from a home movie created in iMovie but I'm not able to play on my tv DVD player. It plays on my computer but I want something that will play on a regular DVD player. I used a memorex DVD-r. Can you please tell me how I might achieve that? Thank you so much!"
Solution:
Actually, it is so easy to burn video to DVD on Mac once you have used Pavtube DVD Creator for Mac, it will help users to burn home movie from iMovie to DVD for playback on TV, and you can use it to burn any HD videos to DVD for backup or playback.
Step-by-step Guide - How to burn home movie from iMovie to DVD for playback on tv
1. Import your home movie to this iMovie to DVD Burning Software on Mac.
After you edited the recordings in iMovie, please load the footages to this DVD Creator software. Most of the edited iMovie footages are in MOV format, this format is perfectly supported by Pavtube iMovie to DVD Creator.
2. Edit AVCHD Video.
Pavtube DVD Creator for Mac enables you to crop, trim, rotate and adjust the effect of the videos. You can add watermarks to illustrate the scenes or give the video a designed music you like.
3. Customize DVD menu and start convert to DVD.
For a personalized DVD menu, you can change the menu buttons, thumbnails; add background music, custom background image, etc. to customize your DVD menu. Then you can preview your entire DVD movie project to ensure everything is perfect. If ok, pls insert a blank DVD disc into DVD drive, and switch to "Burn" tab. You can choose to burn NTSC or PAL, 5.1 channel is allowed, then click "burn" button to start converting iMovie home video to DVD.
As you can see, within few clicks, you can burn home movie from iMovie to DVD with personalized DVD menus, eye-catching video effects and high quality. Just enjoy the movies on TV via players with your family.
Related DVD burning guides:
Burn final cut pro projects to DVD
Burn AVI, MKV, MP4 to DVD
Burn AVCHD to DVD
Buy One Get Another Free? Yes, just join Pavtube's Special Offer to get the promotion.
PS. If you have any problem, pls contact with [email protected] to get more information. You also can leave a message on Pavtube Community or Pavtube Facebook, we will answer your questions as soon as possilble.
