How to convert PDF to Mircosoft Word documents (*.docx) Mac
Postod abcmac83 » 20.03.2012 3:29
PDF to Word Converter for Mac is a very easy-to-use application. It converts PDF to Word and preserves all the text, images, layouts, hyperlinks, tables and graphics with high accuracy. After conversion, Mac users can easily edit PDF files or reuse the contents in other applications.
Just download the PDF to Word Converter for Mac and install it on your Mac. Launch the program to have a free trial of the program. Then follow the 3 simple steps below to convert PDF to Word(*.docx) now on Mac:
Step 1: Import PDF files
Drag your PDF files into the panel, you can successfully import PDF files to convert. Also you can choose "File-> Add PDF Files" in the menu bar to add PDF files for conversion.
Step 2: Set the output folder
To set the output folder for the converted Word documents, choose "PDF to Word -> Preferences..." in the menu bar.
Step 3: Convert PDF files
Click the "Convert" button, PDF to Word for Mac will convert your imported PDF files to Word documents in seconds.
Hot Tags:
pdf to word for mac, PDF to Doc Mac, PDF to Docx Mac
change pdf to word, export pdf to word, Convert PDF to Word
convert pdf to word on mac, how to convert pdf to word, how to change pdf to word
abcmac83
Postova:  67
Pridružio se:  21.02.2012 8:53
