Import EVS XT2 MXF to FCP without audio out of sync
Postod Andyeric » 09.07.2015 8:10
Import EVS XT2 MXF to FCP without audio out of sync or audio jumping
That's what comes up when I try to convert my EVS footage. This particular file format is MXF created by EVS XT and have MJPEG compression, widely used in sports television. What I need is to import EVS MXF to Final Cut Pro. I prefer to transcode EVS MXF to ProRes MOV. Here we go!
What is EVS XT2?
The Remarkable XT 2Production server allows broadcasters to record control and play media easily, quickly, and intelligently. EVS files are DNxHD (VC-3) wrapped in MXF op-1a.
Convert EVS XT2 MXF to Apple ProRes MOV, why is necessary?
There are a few codecs supported by EVS via mxf. The original Photo Jpeg, MPEG2 and DVCPro all require EVS's transcode app (MediaXchange) or Telestream's Flip Factory with the proper export module.
However, MediaXchange is too expensive. So here comes Pavtube iMixMXF, which can easily transcode EVS MXF to multi-track or common Apple ProRes MOV, EVS MXF to multi-track MOV/MKV/MP4, EVS MXF to Avid MOV, EVS MXF to Premiere MOV, etc. This professional EVS MXF to FCP converter is very effective and efficient, which can utilize all cores to speed up process, about 5 times faster than others. The most crucial highlight is the program will create MOV from EVS MXF with broadcast quality. Thanks to advanced audio/video synchronization technology, the output ProRes will be stunning without audio out of sync or audio jumping.
Want to convert EVS MXF to MOV with 2, 4, 8 or more audio tracks? If your MXF generated from EVS XT2 with 2 separate audio channels or more, you may have the necessary to preserve and get separate audio channels. This is the strength point of TransMXF Pro for Mac. It is also possible to combine and mix multiple MXF audio tracks into one track.
Read more: Top MXF Converter for Mac Review
Slika Slika
- Pavtube old official address: http://www.pavtube.com/imixmxf-mac/
- Amazon Download: http://www.amazon.com/Pavtube-Studio-iMixMXF-Download/dp/B00QI7MY4Y
- Cnet Download: http://download.cnet.com/Pavtube-iMixMXF/3000-2194_4-76171460.html
Below is a simple guide to convert EVS XT2 MXF to FCP native supported ProRes HQ.
Step 1. Load MXF files
Click "add video" or "add folder" to load file. You can also directly drag files to the program. The program supports batch conversion and allows you capture images.
Step 2. Choose the output format
Click the "format" and choose the "Multi-track Video -> Multi-track Apple ProPres 422 HQ(*.mov)" files as the output format.
Step 3. Customize video specs. (Optional)
You can click "Settings" to set up video size, frame rate, bitrates and other settings.
Step 4. MXF to Apple ProRes 422 HQ Conversion
Click "Convert" icon, iMixMXF will transcode EVS MXF to multi-track Apple ProRes MOV at ultrafast speed on Mac, the video and audio synchronization is perfectly guaranteed. It's an powerful software, please take a free try, hope it can help you.
More Guides
How to Convert Sony XAVC MXF to Adobe Premiere Pro
Import Ikegami HDS-V10 MXF to Avid Media Composer for Editing
Edit Ikegami MXF Files in iMovie/FCE
Import Ikegami HDS-V10 MXF to Sony Vegas Pro
Canon XF300 MXF to FCP 6/7/X Workflow on Yosemite
Encode MXF to MOV, MPG, MP4, AVI, WMV, FLV on Mac/PC
Import Canon XC10 MXF to Avid Media Composer
The workflow for converting MXF to Premiere Pro CC
Upload GoPro Hero 4K Video to DropBox
Import GoPro Hero 4K Video to Sony Movie Studio
Discussion: Best Supported Video Format for PS4
Convert 5D Mark III H.264 footage to ProRes 422 for FCP 7
Import Sony Alpha NEX-5T MTS to iMovie & FCE
Canon HF R20 AVCHD footage to Adobe Premiere Pro CS5
Source: http://camcordervideoshare.altervista.org/blog/evs-mxf-to-fcp-convert-evs-xt2-mxf-to-apple-prores-mov/
