MOV is a multimedia format that is used for saving and creating video files. It was developed by Apple for their Macintosh systems. MOV may contain video, audio, animation, graphics, virtual reality, 3D, and text information. This file format is easily manipulated with the right software installed. However, opening MOV files in Camtasia Studio can be frustrating from time to time for the complex video codec of MOV.
"Your website says Camtasia Studio should be able to import/edit .mov files. The only type of file my Kodak video camera produces is .mov but Camtasia won't recognize those files when I try to import them and I get a 'No available codec' error."
In this article, you'll learn how to edit MOV videos in Camtasia Studio using three methods: uninstalling, renaming or converting MOV to Camtasia compatible video formats.
![Slika](http://www.mediadimo.com/images/mov-in-camtasia.png)
Method 1. Uninstall QuickTime correctly
With Apple's decision to no longer support updates to QuickTime on Windows the US government posted the following announcement advising users to uninstall the QuickTime software. To avoid the vulnerabilities in the announcement we do recommend uninstalling the QuickTime software.
Method 2. Rename MOV to MP4 and import again
If the .MOV file is encoded in H.264 video and AAC audio that file can be imported and played without the use of QuickTime. If it doesn't import, simply change the extension of the file to .mp4 instead of .mov and try importing again. Any other type of .MOV files will not be able to be imported into Camtasia Studio.
Method 3. Convert MOV for importing to Camtasia Studio
Then what if you need to edit a .MOV that is not able to be imported into Camtasia Studio using the above methods? You'd better find an actual fix. As metioned, a .mov may use different codecs. It could be DNxHD, ProRes, DVCPRO, etc. So, you can't edit a MOV video directly in Camtasia Studio including the lastest Camtasia Studio 9.0.0.
An easy workaround is to change the file extentsion from "MOV" to "a codec" that Camtasia can read more easily (without rendering basically). The codec is H.264/MPEG-1, which ensures maximum editing quality and efficiency when working with Camtasia Studio. To convert MOV files to Camtasia, Dimo Video Converter Ultimate is an easy-to-use yet professional app to achieve your goal smoothly.
Unlike converting MOV with latest updated Handbrake 1.0.0, it is a free-to-try MOV converting application for Windows that features simple and user-friendly tools, functionalities for all your video needs and more video outputs.
It is designed to assist you to convert all MP4, MKV, FLV, SWF, MPEG-2, VOB, MXF, MPG, MOD, WEBM to Camtasia Studio with no efforts. It will ensure a perfect QuickTime file importing, playing and editing workflow with Camtasia Studio 9/8/7/6. For Mac users, just get Dimo Video Converter Ultimate for Mac to get th job done.
Win Mac
- Soft32 Download: http://dimo-video-converter-ultimate.soft32.com/
- Findmysoft Download: http://dimo-video-converter.findmysoft.com/
- Top4download: http://www.top4download.com/dimo-video-converter-ultimate/nsyrihrb.html
- Softpedia Download: http://www.softpedia.com/get/Multimedia/Video/Encoders-Converter-DIVX-Related/Dimo-Video-Converter-Ultimate.shtml
- Raritysoft Download: http://dimo-video-converter-ultimate.raritysoft.com/windows
- Windows8downloads Download: https://www.windows8downloads.com/win8-dimo-video-converter-ultimate-fyqxbkug/
- Stahuj Download: http://www.stahuj.centrum.cz/multimedia/prevody_formatu/dimo-video-converter-ultimate/
- OKD Download: http://www.owlkingdownload.com/index.php?a=prog&os=Windows&cat=Audio-Video&subcat=Audio-Recorders&det=550
- HTML.it Download: http://download.html.it/software/dimo-video-converter-ultimate/
- Instaluj Download: http://www.instaluj.cz/dimo-video-converter-ultimate
- Windows7download: http://www.windows7download.com/win7-dimo-video-converter-ultimate/bpphgnww.html
Step 1: Load MOV files to the program
Launch the MOV to Camtasia Studio Converter and click "Add file" button to locate the MOV file(s) you want to add.
![Slika](http://www.mediadimo.com/images/video/mpeg-1-format.png)
Step 2: Select output format
Click "Select Format" bar and then move your pointer to "Format" and turn to "HD Video" or "Video" and choose MPEG-1 or MOV as target format. Besides, you can also choose AVI, WMV, MP4, etc. if you want to get a relatively smaller output file.
Step 3 (optional): Adjust the video, audio settings
Click "Settings" to fix the frame rate, bitrate, video size, etc to your needs. If you want to edit in Camtasia Studio without having to render the clips while editing, all the frame sizes must be the same as the sequence settings. You can save a lot of render time by making all the clips the same size with this MOV video converter.
![Slika](http://www.mediadimo.com/images/video/mpeg-1-format-settings.png)
Step4: Start MOV to Camtasia Studio conversion on Mac
Click the big "Start" button at the bottom right corner to finish transcoding MOV for Camtasia Studio. When the conversion is done, you can find the output files by clicking "Open" button on the main interface, then you can import the encoded files to Camtasia Studio 9/8/7/6 to open and edit with ease. Once you've got your video edited, you can export to any codec/container, even to MOV that you'd like for playing and sharing.
![Slika](http://www.mediadimo.com/wp-content/uploads/2016/11/win-trial.png)
![Slika](http://www.mediadimo.com/wp-content/uploads/2016/11/buy-win.png)
Contact us or leave a message at Facebook if you have any issues of playing MOV on Camtasia Studio for editing.
Related Articles:
- Transcode MKV to Camtasia Studio 9/8 for editing
- Convert and Import Canon 5D Mark IV 4K files to Final Cut Pro X/7
- Any Other Program Like FFMPEG to Encode H.265/HEVC
- How to import and view 2D/3D movies on VR Box
- Convert 3D Movies to View-Master VR for watching via iPhone
- How to Make MP4 files Work in Camtasia Studio 9/8/7
- Tricks for Downscaling Canon 5D Mark IV 4K to 1080p
[*]How to Convert Video for Importing to Camtasia Studio for Editing Easily?
[*]Transcode Canon 5D Mark IV 4K Video for editing and sharing[/LIST]
Source From: Tricks to Quickly Open/Import MOV to Camtasia for Editing
