How to convert XAVC MXF to ProRes on Mac OS X
Postod lauralily520 » 16.06.2015 10:49
Summary: Wanna know how to import XAVC MXF footage to Final Cut Pro successfully? This page will show you the best way to get XAVC MXF to FCP by converting XAVC MXF to ProRes.
I can not get Final Cut Pro to recognize the MXF /XAVC files from a new Sony FS7. Searching online, more than one guys are talking about the XAVC/MXF issues with FCP 7 or FCP X. Searching further, I got more info about XAVC. XAVC is designed for moderate data rates of high resolution, high frame rate material (50p frame rate, 50p and 4K), with an industry standard .MXF file wrapper for use in conventional production workflows. But the problem is, XAVC is not widely supported by NLEs including Apple’s Final Cut Pro(until FCP 10.1.4 supports native XAVC MXF import). For faster and fluid XAVC MXF to FCP workflow, a better way is to convert XAVC MXF to ProRes.
To get things done easily, you can pick up the professional XAVC converter app Brorsoft Video Converter for Mac, to convert XAVC to "a codec"- Apple ProRes that FCP can read more easily. With it, you can also effortlessly encode/re-encode XAVC files for smoothly importing and editing in various non-linear editing systems (NLE), including Final Cut Pro X, FCP 6/7, iMovie, Final Cut Express, Adobe Premiere Pro, Avid Media Composer, etc. Download the program and follow the XAVC to ProRes conversion process.
Guide: Convert XAVC MXF to ProRes 422, 4444 for Final Cut Pro
Step 1. Download, install and run the XAVC to ProRes Converter; click "Add Videos" icon to load your source XAVC files. This software supports batch conversion.
Step 2. Click “Format” bar and choose “Final Cut Pro >> Apple ProRes 422 (*.mov)” as output format for editing XAVC in FCP with natively supported video codec.
Tip: Click the Settings icon if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sample rate, audio channels.
Step 3. Hit the convert button, it will start converting XAVC MXF to ProRes .mov for importing to Final Cut Pro 6/7 and FCP X immediately. Soon after the conversion, just click “Open” button to get the generated files for natively editing in Final Cut Pro perfectly.
Related Guides:
Tips for converting DNxHD to ProRes
Smoothly Editing XAVC S in Final Cut Pro 7
Play Blu-ray , DVD movies on HTC One M9+
Can't import XAVC S into FCP 7- A quick Fix
Edit DivX/XviD in Movie Studio Platinum 12/13
Transfer Xvid, Divx codec AVI files to iTunes 12/11 for Playback
Edit AJA Cion 4k video clips in iMovie, FCE, Avid Media Composer
Convert Avid DNxHD to Prores 422, ProRes 422 HQ or 4444 with OS X
Edit GoPro Hero2/Hero3/Hero 4 footage in Sony Movie Studio Platinum 12/13
Source:Transcode XAVC MXF to ProRes 422, ProRes 4444
Re: How to convert XAVC MXF to ProRes on Mac OS X
Postod Andyeric » 18.06.2015 7:26
Related:
Postod lauralily520 » 25.06.2015 10:41
Summary: Having trouble importing XAVC S to Final Cut Pro 7 for editing? If so, just follow the simple guide to fix the issues.
Normally, we would like to adopt Final Cut Pro to edit some XAVC S footage from Sony AS100V, Sony a7s, Sony AX33, Sony a7ii, Sony X1000V, etc. in order to get better videos or more wonderful video files. Well, Final Cut Pro X might not support XAVC S format. In this case, to smoothly edit XAVC-S in Final Cut Pro 7, the easy workaround is to convert XAVC S to ProRes MOV which is the best codecs with best results when working with Final Cut Pro.
Converting XAVC S to Apple ProRes for Final Cut Pro 7
The quick workaround is to use the easy-to-use yet professional app Brorosft Video Converter for Mac which can be used as a XAVC S to ProRes Converter under OS X(including Yosemite and Mavericks). With it, you can effortlessly transcode XAVC S files to ProRes 422 encoded MOV for Final Cut Pro 7 and it works well and converts flawlessly. Meanwhile, the Mac Video Conversion tool can create files compatible with various non-linear editing systems like Avid Media Composer, FCE, FCP X, iMovie, and Adobe Premiere Pro and more. Below is how.
Read More: XAVC S to iMovie | XAVC S to Adobe Premiere | XAVC S to Avid
1: Load XAVC S to the converter
You can directly drag and drop the XAVC S files to the software, or click "Add" or "Add From Folder" to locate the XAVC S clips into the converter.
2. Choose output format
Press "Format" option and navigate the mouse cursor to choose "Format > Final Cut Pro > Apple ProRes 422 (*.mov)" as the best codec for FCP 7on Mac.
Tips: You can click “settings” button in the main interface to customize the output video’s parameters, such as resolution, frame rate, etc.
3. Start XAVC S to Final Cut Pro conversion
Click the big "Convert" button at the bottom right corner, this Mac XAVC S converter will start to transcode XAVC S to ProRes for FCP 7! Once the conversion completes, you are free to use XAVC files in FCP!
Additional Tips:
If you have problems playing, editing, converting or sharing XAVC, XAVC S or other 4K ultra HD videos on Mac/Windows, please enter "4K Workflow Column" to get the solutions.
More Topics:
FFmpeg can't convert ProRes to MP4- Solution
Import Red One 4K video to Final Cut Pro 10.1
Transfer ProRes to MP4 for Mac OS X (Yosmite)
How to View AVI/MKV/VOB Movies on Nexus 10
Batch convert MKV/VOB/AVI to Nexus 7/Nexus 10
How to convert videos on Windows 8.1 fast and easily
Guide for Converting Video on Windows 8.1 with ease
Import SJCAM SJ400 MOV videos to iMovie 11/09/08
Edit SJCAM SJ4000 MOV footage in Adobe Premiere Pro
Transcode AVI to ProRes 422/444/422 HQ for FCP 6/7/X
Prep SJCAM SJ4000 h.264 MOV Footage For Editing In FCP
Source: Smoothly Editing XAVC S in Final Cut Pro 7
Postod Andyeric » 03.07.2015 4:46
Play Canon T6s/760D MP4 videos on VLC/QuickTime
Summary: Tips and tricks for importing Canon T6s/760D MP4 files to VLC and QuickTime for playing and enjoying. Learn details.
EOS Rebel T6s/760D is a new model in Canon's DSLR. Users can record Full HD MP4 files with it. But there are some problems such as not showing the video, unsupported file type when playing and enjoying Canon T6s/760D MP4 videos. You cannot import recordings from Canon T6s/760D to VLC or QuickTime for playing. Is there any quick fix for the problems with Canon T6s and VLC/QuickTime?
VLC does play MP4 files, but it has strict limitations: VLC Media Player is only compatible with MPEG-4 ASP, DivX 4/5/6, XviD, 3ivX D4 and H.264 / MPEG-4 AVC. However, MP4 is a multimedia container format with many kinds of video and audio codec. If your MP4 file contains a VLC unsupported audio or video codec, VLC won't play it. In this case, we will encounter the following symptoms when we play MP4 files in VLC:
Question 1: "I'll get to about 1 hour and 50 minutes of a 3 hour long .mp4 video and the video will just stop, and it happens to all the videos I've downloaded."
Question 2: "I am a fan of VLC so use it on most machines to play MP4 videos from my NAS. Tonight it has just stopped displaying the video."
Question 3: "VLC will not play certain mp4 h264 files. Some H.264 files work, others don't."
How to solve "VLC/QuickTime not playing MP4" Issue? Pavtube Video Converter for Mac is specially designed for solving the VLC/QuickTime MP4 issue like "Does VLC/QuickTime play MP4? Can VLC/QuickTime play MP4? VLC/QuickTime is not playing MP4? VLC/QuickTime won't play MP4? How to play MP4 on VLC/QuickTime smoothly?" With this powerful MP4 to VLC/QuickTime Converter, it becomes easier to play all kinds of MP4 on VLC/QuickTime and you will never encounter the above problems. If you are Windows users, the Windows Guide can help you.
P.S Here you can choose more Video Converter for Mac softwares by viewing the Reviews.
Now, download and install the program from the website or click the free trial icon:
How to transcode Canon T6s/760D MP4 videos for playing on VLC or QuickTime?
Step 1: Then, launch the best MP4 Mac video converter and load your original MP4 files in with "Add video" or "Add from folder". Directly drag files in is available.
Step 2: Choose the right output format for VLC. As we mentioned above, we would like to introduce you to select the "HD Video>>H.264 HD Video (*.mp4)" as your best choice. Surely you can choose other suitable ones as you like.
Tips: For QuickTime, choose "Common Video>>MOV-QuickTime (*.mov)".
Step 3: The built-in editing function provided by Mac Video Converter is something worth trying. To trim the video, add artistic effects, adjust audio, add watermark, customize video parameters and so on. You can get the work done splendidly. Of course, if you don't think it's a necessary to do, you can skip it and move onto the next step directly.
Tips: You can also go to the "Settings" to set the parameters for your videos.
Step 4: Click the "Convert" button on the main interface if you have done all the preparation work. This is the workflow that we need to convert T6s/760D MP4 to VLC/QuickTime best accepted format.
Conclusion: OK, everything is ready, and you can instantly play your Canon T6s/760D camcorder captured MP4 files on VLC/QuickTime. By the way, we have promoted money saving bundles & deals activity. It really saves a lot! Why not take a look and have a try about high quality products with attractive price?
Further Reading:
Compress Sony FDR AX-100 4K XAVC S Files with Wondershare Alternative
Edit Sony Z100 4K XAVC in Sony Vegas 13
Import Ikegami GFCAM HDS-V10/HDN-X10 MXF to Aperture 3
Convert AJ-PX800 P2 MXF to MOV with no Quality Loss
Two Ways to Convert MKV to iTunes for Adding Videos
How to Get AVCHD MTS Workflow with DaVinci Resolve (Lite)?
Encode Tivo to MPEG-2 for Premiere Pro CC on Yosemite
MP4 video can be used perfectly in Premiere Pro CC
Help you import MKV to VLC Media Play
Share XAVC on YouTube/Vimeo/Facebook on Mac
Decode H.265 to Prores 422 for FCP X Editing
Source: http://pc-mac-compatibility-issues.blogspot.com/2015/03/play-t6s-mp4-on-vlc-quicktime.html
