Can't import XAVC S into FCP 7- A quick Fix
Postod lauralily520 » 16.06.2015 10:19
Summary: Having trouble importing XAVC S to Final Cut Pro 7 for editing? If so, just follow the simple guide to fix the issues.
Normally, we would like to adopt Final Cut Pro to edit some XAVC S footage from Sony AS100V, Sony a7s, Sony AX33, Sony a7ii, Sony X1000V, etc. in order to get better videos or more wonderful video files. Well, Final Cut Pro X might not support XAVC S format. In this case, to smoothly edit XAVC-S in Final Cut Pro 7, the easy workaround is to convert XAVC S to ProRes MOV which is the best codecs with best results when working with Final Cut Pro.
Converting XAVC S to Apple ProRes for Final Cut Pro 7
The quick workaround is to use the easy-to-use yet professional app Brorosft Video Converter for Mac which can be used as a XAVC S to ProRes Converter under OS X(including Yosemite and Mavericks). With it, you can effortlessly transcode XAVC S files to ProRes 422 encoded MOV for Final Cut Pro 7 and it works well and converts flawlessly. Meanwhile, the Mac Video Conversion tool can create files compatible with various non-linear editing systems like Avid Media Composer, FCE, FCP X, iMovie, and Adobe Premiere Pro and more. Below is how.
Read More: XAVC S to iMovie | XAVC S to Adobe Premiere | XAVC S to Avid
1: Load XAVC S to the converter
You can directly drag and drop the XAVC S files to the software, or click "Add" or "Add From Folder" to locate the XAVC S clips into the converter.
2. Choose output format
Press "Format" option and navigate the mouse cursor to choose "Format > Final Cut Pro > Apple ProRes 422 (*.mov)" as the best codec for FCP 7on Mac.
Tips: You can click “settings” button in the main interface to customize the output video’s parameters, such as resolution, frame rate, etc.
3. Start XAVC S to Final Cut Pro conversion
Click the big "Convert" button at the bottom right corner, this Mac XAVC S converter will start to transcode XAVC S to ProRes for FCP 7! Once the conversion completes, you are free to use XAVC files in FCP!
Additional Tips:
If you have problems playing, editing, converting or sharing XAVC, XAVC S or other 4K ultra HD videos on Mac/Windows, please enter "4K Workflow Column" to get the solutions.
More Topics:
Tips for converting DNxHD to ProRes
How to convert AVI to iTunes free on Mac
Edit DivX/XviD in Movie Studio Platinum 12/13
Editing MP4 in Sony Movie Studio Platinum 12/13
Solution to Sony Movie Studio can't open AVI files
Convert XAVC MXF to ProRes 422, 4444 for Final Cut Pro
Transfer Xvid, Divx codec AVI files to iTunes 12/11 for Playback
Edit GoPro Hero2/Hero3/Hero 4 footage in Sony Movie Studio Platinum 12/13
Source: Smoothly Editing XAVC S in Final Cut Pro 7
Re: Can't import XAVC S into FCP 7- A quick Fix
Postod Andyeric » 18.06.2015 7:24
Related:
Postod lauralily520 » 18.06.2015 11:04
Summary: Wanna know how to import XAVC MXF footage to Final Cut Pro successfully? This page will show you the best way to get XAVC MXF to FCP by converting XAVC MXF to ProRes.
I can not get Final Cut Pro to recognize the MXF /XAVC files from a new Sony FS7. Searching online, more than one guys are talking about the XAVC/MXF issues with FCP 7 or FCP X. Searching further, I got more info about XAVC. XAVC is designed for moderate data rates of high resolution, high frame rate material (50p frame rate, 50p and 4K), with an industry standard .MXF file wrapper for use in conventional production workflows. But the problem is, XAVC is not widely supported by NLEs including Apple’s Final Cut Pro(until FCP 10.1.4 supports native XAVC MXF import). For faster and fluid XAVC MXF to FCP workflow, a better way is to convert XAVC MXF to ProRes.
To get things done easily, you can pick up the professional XAVC converter app Brorsoft Video Converter for Mac, to convert XAVC to "a codec"- Apple ProRes that FCP can read more easily. With it, you can also effortlessly encode/re-encode XAVC files for smoothly importing and editing in various non-linear editing systems (NLE), including Final Cut Pro X, FCP 6/7, iMovie, Final Cut Express, Adobe Premiere Pro, Avid Media Composer, etc. Download the program and follow the XAVC to ProRes conversion process.
Guide: Convert XAVC MXF to ProRes 422, 4444 for Final Cut Pro
Step 1. Download, install and run the XAVC to ProRes Converter; click "Add Videos" icon to load your source XAVC files. This software supports batch conversion.
Step 2. Click “Format” bar and choose “Final Cut Pro >> Apple ProRes 422 (*.mov)” as output format for editing XAVC in FCP with natively supported video codec.
Tip: Click the Settings icon if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sample rate, audio channels.
Step 3. Hit the convert button, it will start converting XAVC MXF to ProRes .mov for importing to Final Cut Pro 6/7 and FCP X immediately. Soon after the conversion, just click “Open” button to get the generated files for natively editing in Final Cut Pro perfectly.
Related Guides:
Converting AVI for Editing in Sony Studio
FFmpeg can't convert ProRes to MP4- Solution
Transfer ProRes to MP4 for Mac OS X (Yosmite)
Guide for Converting Video on Windows 8.1 with ease
How to convert videos on Windows 8.1 fast and easily
Convert AEE S71 MP4 format videos to Final Cut Pro 7
How to Load Sony PXW-X320 XAVC videos to Avid MC
Smooth Edit AEE S71 4K/HD MP4 files in Pinnacle Studio
How to Add AVI files to iTunes on Mac(Yosemite/Mavericks)
Convert H.265 to Premiere Pro CC/CS6/CS5/CS4 on Mac OS X
Convert MP4 to Sony Movie Studio more edit-friendly MPEG-2 files
Source: Can't import XAVC S into FCP 7- A quick Fix
Postod lauralily520 » 25.06.2015 10:09
Summary: This article shows you how to transcode MXF files to DaVinci Resolve compatible format, so that you can play, edit, your MXF recordings on DaVinci Resolve without issues.
MXF files are often produced by high-end cameras and camcorders, like Sony XDCAM, Panasonic P2, and Canon XF to store video, audio, and programmed data. However, MXF as a container format, still can not be supported well by many video editing programs like Davinci Resolve. In this article, we will look at a typical MXF to DaVinci Resolve issue and provide the solution to it as well.
Q: “I have a few .MXF files that I am trying to edit the MXF in Resolve, but DaVinci won't import the MXF files... it says they are missing even though I've selected the right folder. Any way help me out?”
Actually, DaVinci Resolve supports MXF files in theory. But things are different when we import MXF to Davinci Resolve for editing: DaVinci won't import the MXF files... That’s probably because MXF is a relatively complicated format to handle. The best way to let DaVinci Resolve work with MXF clips is to convert MXF files to Davinci Resolve most compatible format like DNxHD. And to finish the task, Brorsoft MXF Converter for Mac is just the best choice.
Overall, it is an easy-to-use yet powerful high-quality MXF converter, player and editor. This software can deal with almost all kinds of MXF videos on Mac OS X. With it, users can effortlessly transcode (P2) MXF files for smoothly editing in DaVinci Resolve. What's more, it can generates more optimal editing formats/codecs for you to use in different NLE apps, such as Final Cut Pro, Avid Media Composer, iMovie, Adobe Premiere Pro, and more. For Windows users, please get MXF Converter. Below is how. Just take a look at the brief guide below.
Guide: Convert MXF videos to DaVinci Resolve acceptable format
1. Import MXF files
Run the Mac MXF Coverer; click the Add button to load .mxf files to the program from your computer or camcorder. You can also directly drag the video files into the program directly.
Click Format preset and choose Avid Media Composer -> Avid DNxHD (*.mov)” as the best video format for editing Sony XAVC in Avid as well as good video quality.
Tip: If you like, adjust video and audio parameters, including the Bitrate of Video and Audio, the Codec of Video and Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings button on the main interface for getting the best quality.
3. Start conversion
Hit "Convert" button to start MXF to DNxHD .mov conversion for Davinci Resolve. You can follow the conversion process from the pop-up windows.
After the conversion, you can import the converted MXF files to Davinci Resolve 10/11/12 for smooth playback and editing. No more worries about the MXF incompatibility with DaVinci Resolve.
Additional Tips:
The versatile MXF to DaVinci Resolve converter is not only designed for converting MXF files for Resolve. It is also professional in making Canon, Sony, Panoramic MXF files editable in Adobe Premiere Pro, Final Cut Pro, Avid Media Composer, After Effects, iMovie, etc to meet your different needs.
Related Guides:
Import Red One 4K video to Final Cut Pro 10.1
How to View AVI/MKV/VOB Movies on Nexus 10
Batch convert MKV/VOB/AVI to Nexus 7/Nexus 10
Transcode XAVC MXF to ProRes 422, ProRes 4444
Edit SJCAM SJ4000 MOV footage in Adobe Premiere Pro
Prep SJCAM SJ4000 h.264 MOV Footage For Editing In FCP
Convert Avid DNxHD to Prores 422, ProRes 422 HQ or 4444 with OS X
Source: How to convert and import MXF files to Davinci Resolve
Korisnici koji su trenutno na forumu: Nema registrovanih korisnika i 31 gostiju
