How to backup android phone contacts to computer?
Postod lisaamy » 07.05.2015 4:01
Losing contacts from android phone happened unexpectedly, so we need to backup them to computer frequently. But as you know, we can't do that directly, we need an android file manager to help. This how to move contacts from android phone to pc with Coolmuster Android Assistant is for you.
Step 1:Connect Android Phone to pc
Download and install the Android contacts manager on your pc and launch it. The next is connecting your Android phone to pc via usb cable. Your device will appear on the screen. The manager would recognise your android device automatically.
Notice: If this is the you connect android phone to the problem on computer, you should enbale USB debugging first, and install a USB driver on your computer, then the app would detect your android phone automatically.
Step 2:Select Contacts and Start Export
You can find many icon on the left, find "Contacts" and click it, all contacts on your android phone will be listed on the right. Then select and check you want to transfer, at last click "Export" to start the work. By the way, you can click "New" on the top to add contacts to your android phone.
That's all!
lisaamy
Pridružio se:  30.01.2015 8:21
Re: How to backup android phone contacts to computer?
Postod Tennor » 29.05.2015 10:58
Android data loss is also common, so we need backup our phone data regularly. Vibosoft Android Mobile Manager is excellent app to transfer Android files for Windows and Mac.
Tennor
Pridružio se:  09.01.2015 8:32
Postod koraea » 23.11.2016 11:30
First, connect your android phone with computer via USB cable. Then start Android contacts backup program. After that, you can directly export and save Android contacts as CSV or XLS format with one simple click.
koraea
Pridružio se:  22.09.2016 9:25
