Way to transfer Motorola text messages to computer
Postod agneskelly » 11.07.2014 9:12
Distinct from image, video or audio files that are located in the SD card, an external flash memory card, and can be exported to the computer with a USB cable easily, text messages, as well as contacts, can not be transferred simply via USB.
Are you puzzled in how to backup messages from Motorola to computer? Here I'll guide you how to transfer messages from Motorola to computer easily with an android file manager. We just need 2 steps to finish the transfer.
Step 1:Connect Android Phone to PC
At first, download and install the app on your PC and launch it. Then connect your Android phone to PC via usb cable. Then the info of your phone will be shown on an interface.
Notice:If this is the first time you connect your android phone to computer, you shoule enable the USB debugging. You can follow the guide to open the USB begging. It's only necessary when you run this software for the first time.
Step 2:Preview sms and Start Export
You can see many folders on the top, find "Contacts" and click it, then go to "SMS", all messages on your android phone will be listed on the right. Then select and check you want to transfer, at last click "Backup" to start the work.
OK!
agneskelly
Postova:  2
Pridružio se:  11.07.2014 8:50
