Put recored FIFA World Cup 2014 videos to iPhone 5/5S/6S
Postod JeanLiu » 23.06.2014 10:12
Put recored FIFA World Cup 2014 videos to iPhone 5, iPhone 5S, iPhone 6S for watching
2014 world cup video converter,put video to iphone 5,transfer video to iphone 5s,iphone 6 converter,enjoy world cup video on iphone
It's a nice idea to transfer your recored FIFA World Cup 2014 videos to iPhone 5, iPhone 5S, iPhone 6S for watching. Here we will show you how.
Gladly, the 2014 FIFA World Cup is just around the corner, and we can nearly smell it. If you have a channce for heading to Brazil, you can shoot videos during the games at spot, even from the auditorium, then coming back soon after watching the footaball game. you can transfer your captured videos during the vocation and merge the videos for watching and sharing on iPhone 5, iPhone 5S and the upcoming iPhone 6.
As we know, the iOS based device supports videos in .m4v, .mp4 and .mov file format. If you have some recorded 1080p/720p videos (mts, m2ts, mxf, mov, etc.) which are not in the supported video format of these iPhone series, you'll need to convert these FIFA World Cup 2014 videos to iPhone compatible video format first and then sync them to your your iPhone 5, iPhone 5S and iPhone 6 for playback. The article below will help you better enjoy your FIFA World Cup 2014 matches with your iPhone 5, iPhone 5S and iPhone 6. Just follow it.
Free Download the App - Pavtube Video Converter Ultimate
The program can help you compress Blu-ray to iPhone, rip DVD movie to iPhone and convert HD videos of 2014 World Cup to iPhone, including MKV, AVI, MPG, VOB, TiVo and more, everything can be transferred to iPhone 5, iPhone 5S and iPhone 6 optimized formats at ease. Meanwhile the playback of the converted videos is as decent as possible as original and the conversions can be made for use on all forms of the iPod. If you are a Mac user, you can use its equivalent Mac version -iMedia Converter Mac to achieve your goal smoothly.
[size="4"]Sync and Watch FIFA World Cup 2014 Videos on iPhone 5, iPhone 5S and iPhone 6[/size]
The quick start guide below uses the movie converter Windows(Windows 8.1 included) screenshots. The way to converting World Cup videos to iPhone on Mac (Mavericks included) is almost the same. Just make sure you get the right version according to your computer operating system.
Step 1: Import souce video files to the program
Once run the Ulitmate Video Converter for iPhone sftware, click "Add Video" to load source video files like MTS/M2TS, MKV, VOB, MOV, TOD, TiVo, etc.
This all-in-one toolbox also enables you to merge video clips into one full video. If you have stored any video highlights, it is very great to create a personalized video to for sharing!
Step 2: Select the suitable output video format
Click "Format" bar, you can easily find the optimized videos for iPhone under "iPhone" option. Choose iPhone 5S/5C H.264 HD 720P (*.mp4) or iPhone 5S/5C H.264 HD Full HD 1080P (*.mp4). The output videos could fit on the iPhone 5, iPhone 5S and iPhone 6 perfectly.
To get the preset, you should also install the Patch in advance, but now only windows version have the patch file.
If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish. Keep in mind that bitrate higher results in big file size, and lower visible quality loss, and vice versa.
Step 3: Start encoding 2014 FIFA World Cup Brazil movies for iPhone
After above steps, just click "Convert" to begin converting 2014 FIFA World Cup to iPhone highly compatible MP4 videos.
After getting the converted movies files, you can transfer these videos to iPhone 5, iPhone 5S and iPhone 6 via iTunes. If you don't know how to sync video files with iPhone, just follow the steps to realize it:
1) Make sure you have install iTunes. If not, you can free download iTunes here at first. And launch the iTunes.
2) Connect iphone to PC.
3) Choose "File – > Add File to Library…"
4) Drag the .mp4 file you want to the iPhone icon
So there you have it. Pretty simple. Now, you can enjoy the dramatic Brazil 2014 World Cup videos at breakfast, on the subway, during breaks, anywhere you want for great digital fun.
Read more:
How to transfer videos, music, photos from PC to iPhone 5S?
6 World Cup Apps for the iPhone
Free Download We Are One (Ole Ola) Fifa World Cup 2014 Official Song on iPhone and set as your ringtone
Source: http://iphone-5s-5c-video-tips.over-blog.com/watch-world-cup-videos-on-iphone-5-iphone-5s-iphone-6s
Re: Put recored FIFA World Cup 2014 videos to iPhone 5/5S/6S
Postod Zoner1 » 21.08.2014 10:02
If your iPhone data are indeed gone, I would suggest you try using iTunes in order to restore your iPhone data (including sms)from the last time you last synced your iPhone with your iTunes. Here is about how to recover deleted data from iPhone.
Here are two easy methods to recover data from old iPhone:
One. Recover data from iPhone via iTunes.
how to recover deleted call history on iPhone
Two. Recover iPhone Data without Backup by using third party iPhone Data Recovery Software
how to recover deleted videos from iPhone
Zoner1
Postova:  2
Pridružio se:  21.08.2014 9:49
