Convert/Edit Sony HDR-AX2000 AVCHD MTS in FCP X on Mac
Postod martylyy » 24.04.2014 14:39
Sony’s HDR-AX2000 makes for an impressive prosumer-level AVCHD camcorder. While not as decked out as the HXR-NX5U (its NXCAM pro counterpart), it’s a clear step up from its HDV predecessor, the HDR-FX1000. The camera’s ability to capture HD and SD video in AVCHD and MPEG-2 formats–and save it to solid state media–is only one of the traits distinguishing it from its tape-based forebearer. Full 1920 x 1080 HD video–which can be recorded at 60i, 30p and 24p–is another. The footage is saved to either Memory Stick PRO Duo or SD/SDHC/SDXC cards, then easily downloaded to computer for editing via USB 2.0 interface.
Final Cut Pro X, the latest version of video-editing software geared for professionals from a company increasingly focused on mainstream consumers. Final Cut Pro X is a follow-up to Final Cut Pro 7, software Apple released in 2009 as part of Final Cut Studio. Like Apple’s newly released of Mac OS X Mavericks, Final Cut Pro X was only be available to customers through the Mac App Store. However, this new released FCP X does not support well with HDR-AX2000 AVCHD Videos.
So if you want to edit Sony HDR-AX2000 1080 AVCHD Videos in Final Cut Pro X, you are recommended to use UFUSoft AVCHD Converter for Mac, which is the superior Mac Sony HDR-AX2000 MTS to FCP X converter for Mavericks, Mountain Lion, Lion and Snow Leopard. It does not only convert Sony HDR-AX2000 AVCHD to MOV on Mac, but also merges 1080 MTS files for import into Final Cut Pro X.
Here is the step-by-step guide for you to import and edit Sony HDR-AX2000 MTS to Final Cut Pro X on iMac/MacBook Pro with Mac OS X like Mavericks, Mountain Lion, Lion or Snow Leopard.
Step 1. Load Sony AVCHD videos to UFUSoft AVCHD Converter for Mac.
After transferring .mts files from Sony HDR-AX2000 camera, run UFUSoft AVCHD Converter for Mac as the best Mac Sony HDR-AX2000 MTS to MOV converter, and click the “Add File” button to load .mts videos.
Step 2. Choose H.264/AVC MOV output format.
Click the “Format” option, and choose HD Video > HD MOV (*.mov) for converting AVCHD videos from MTS to MOV with H.264/AVC as video codec for loading to Final Cut Studio. With this option, the output video will be kept as high definition 1920×1080.
Step 3. Merge Sony HDR-AX2000 AVCHD MTS files. (optional)
Select all the files and then click “Merge”, and the Sony HDR-AX2000 MTS converter will join and combine the video clips into a single file as output.
Step 4. Convert Sony HDR-AX2000 MTS to MOV for Final Cut Pro X.
Click the convert button under the preview window, the Mac Panasonic MTS converter starts converting Sony HDR-AX2000 MTS videos to H.264 .mov, and joining the MTS files for editing in Final Cut Pro X.
After converting and merging the MTS files, just import the output files to Final Cut Pro X and the video is in HD 1920×1080. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Read More :
How to Play Blu-ray Disc on Windows PC with PC Blu-ray Player Software?
VLC media player: Playing Blu-Ray discs in Windows 8 for Free
2014 Best Blu-ray Player Video/Media Software for Windows 8.1 Blue/8 Review
Best Blu-ray Video/Media Player Software for Windows 8 PC
Blu-ray Video/Media Player Software for Windows 7/8/8.1/Vista
Transcode AVCHD MTS/M2TS files to AIC for Final Cut Express (FCE) editing
Transcode Sony Alpha AVCHD to ProRes/AIC/MPG for FCP/iMovie/Premiere Pro
martylyy
Postova:  26
