Convert Sony XAVC to YouTube/Google/Myspace format
Postod martylyy » 21.04.2014 15:49
Do you have so many valuable or interesting moments you took with your Sony PMW-F55 and Sony PMW-F5 XAVC camcorder that you would like to share with your friends and family in YouTube, Google Video, Myspace or other video sharing websites? As you know, XAVC format is not supported on most video-sharing websites, You might need a video converter first to convert XAVC to workable formats online like SWF, FLV or F4V. Here I’d like to recommend an excellent piece of XAVC converter – UFUSoft Sony XAVC Converter for Mac. The program is specifically designed for XAVC converting which excels on output quality and its conversion speed. The following is the detailed steps of my own experience to convert Sony PMW-F55/Sony PMW-F5 XAVC files to SWF/FLV/F4V.
Step 1: Click the “Add” button to load your XAVC files to UFUSoft Mac XAVC to YouTube Converter
Step 2: Select the output format in Flash Video catalogue in Format drop-down list
There are four options under Flash Video catalogue for you to choose from: FLV, FLV H.264, F4V, and SWF format.
Step 3: Set advanced settings
Click the “Settings”, and a profile will pop up. You can adjust bit rate, frame rate, codec, etc in the window. You can lower bit rate to decrease output file size or you could enlarge bit rate for a higher video quality with comparatively larger file size.
Step 4: Edit your video files
Click the Edit button in the menu bar, and you are allowed to custom your videos for special effects. For instance, you can crop those unwanted parts of your video, split your video into several clips, add text/image/video watermark and so on.
Step 5: Convert your Sony XAVC to SWF/FLV/F4V
After all the settings, you just need to click the Convert button and wait for a while to get your converted video files in destination folder for uploading to the website.
See, it is easy, isn’t it? Hope it helps!
Read More :
Blu-ray Video/Media Player Software for Windows 7/8/8.1/Vista
Play Blu-ray in Windows Media Center on Windows 8.1/8/7/Vista
Blu-ray Player Software for Windows 7/8/8.1 Review : UFUSoft Blu-ray Player
Play Blu-ray on Windows 8 with Blu-ray Drive and Windows 8 Blu-ray Player
Get Blu-ray Playback on Mac OS X 10.9 with Mac Blu ray Software
How to Convert AVCHD MTS/M2TS to Apple ProRes 4444 Codec for FCP?
How to Make Canon XA25/Canon XA20 AVCHD MTS Compatible with Mac?
martylyy
Postova:  26
