ISO to MP4- How to batch convert DVD ISO to MP4
Postod lydia622520 » 25.12.2013 9:14
Summary:Want to convert ISO/DVD to MP4 for playback on the go? This guide will tell you the easiest way to convert your ISO file to MP4 video for any popular media devices.
As you know, ISO file can only be played with virtual driver software or the similar tools, and you can't edit it directly. However, after converting it to other video format such as MP4, you can play and edit it the way you like. And here I will quickly walk you through how to convert DVD ISO to MP4 video.
In order to convert ISO to MP4 fast and easily, you can use Brorsoft DVD Ripper, which can help you rip your ISO files to MP4 as well as AVI, WMV, MOV, FLV, MPG, etc, and allows you to manually adjust encoding settings to customize the output video quality and file size. In addition, if you want to edit videos, set subtitles, select audio track, add text or image watermark to videos, all these can be easily achieved with this powerful tool. The equivalent Mac ISO converter is Brorsoft DVD Ripper for Mac.
How to convert ISO image file to MP4 video
Note: Here converting ISO to MP4 in Windows (Including Windows 8) is displayed. The steps for the conversion on Mac are the same. Just make sure you get the right version according to your situation.
1. Load ISO file > Just click "Load DVD" button to import ISO files to this program. Or simply drag & drop your ISO files to the DVD ISO to MP4 Converter.
2. Select the output format > From the drop-down list of " Format" > “Common Video”, you can select "H.264 MP4(*.mp4)" as the output format.
Tip: If you want to edit your videos, you can just hit the "Edit" to crop the black bar to make a full screen, apply special effects to the video. set the brightness, contrast and saturation, and add image or text watermark to your videos, etc. as you like.
3. Start to convert ISO files to MP4 > After all these have been prepared, simply click the "Convert" button to begin the DVD ISO to MP4 conversion. Then you can find your MP4 files by clicking the "Open" button. Then it can be easy for you to play and edit DVD ISO files anywhere you want them.
Read more:
Stream DVD ISO files to PS3
Convert ISO movie filse to MOV easily
Converting AVCHD Lite to AIC for iMovie
How to Convert & Import AVCHD Lite to Final Cut Pro
Rip DVD to MOV for native playback with QuickTime on Mac
Rip Blu-ray DVD to MKV losslessly with makemkv Alternative for Mac
Source:ISO to MP4- How to batch convert DVD ISO to MP4
lydia622520
Re: ISO to MP4- How to batch convert DVD ISO to MP4
Postod JoanCarl » 13.05.2014 10:46
why not try some other video converter such as iSkysoft Video Converter. easy to convert files to mp4 format.
JoanCarl
Postova:  2
Pridružio se:  27.02.2014 18:10
