15%OFF-Panasonic HC-X920 60p AVCHD to Premiere Pro Workflow
Postod AbbyCarrie11 » 12.12.2013 15:56
Panasonic HC-X920 3MOS Ultrafine Full HD Camcorder features three 1/2.3″ BSI MOS sensors for recording Full HD 1080/60p video in the AVCHD format. The 12x Leica Dicomar zoom lens has a fast max aperture of f/1.5 and a 35mm equivalent of approximately 29.8-399.2mm, and the optical zoom is supplemented by an 25x Intelligent Zoom. Built-in Wi-Fi enables real time streaming and remote control via a smartphone or tablet. Other features include a 3.5″ LCD touchscreen monitor, Five Axis Hybrid OIS, 5.1-channel surround sound, and iA Plus Mode.
This video format is so special that it is difficult to import most of editing software, like Adobe Premiere. So you have to convert 1080p 60fps MTS footages with a professional Panasonic HC-X920 MTS to Adobe Premiere Pro Converter. And aPubsoft AVCHD Converter is the right program to convert Panasonic HC-X920 MTS to HD WMV for Adobe Premiere Pro CS5/CS6/CC7 as well as merging several video files into big one.
Following is the step by step guide on importing and editing Panasonic HC-X920 AVCHD in Adobe Premiere Pro CS5/CS6/CC7 on windows xp, windows vista, windows 7, windows 8, windows 8.1.
Step 1. Load HC-X920 1080p 60fps MTS files to the aPubsoft AVCHD Video Converter.
After transferring Panasonic HC-X920 1080p MTS files to this program, run aPubsoft AVCHD Video Converter as the 2014 Top AVCHD to WMV converter and click “Add File” button to import MTS footages to be converted.
Step 2. Choose HD WMV as output format for Adobe Premiere Pro.
Click “Format” option and choose HD Video-> HD WMV Video (*.wmv) for converting HC-X920 MTS to WMV for Adobe Premiere Pro.
Step 3. Merge several Panasonic HC-X920 MTS files into one.
Select the MTS files you want to merge in the filelist, then click Merge button, your selected MTS video clips can be joined into one automatically.
Step 4. Start Panasonic DMC-HC-X920 MTS files to HD WMV conversion for Adobe Premiere Pro.
Click the big button “Convert” and this Panasonic HC-X920 1080/60p AVCHD to WMV Converter will start this conversion immediately.
Once this conversion is completed, you can import and edit these converted HD WMV files on Adobe Premiere Pro CS5/CS6/CC7.
Read More:
Final Cut Pro X/7/6 Workflow:Canon C300 MXF Compatible with Mac OS X, MXF to ProRes MOV
Canon XA10 AVCHD to FCP-Import/Convert AVCHD Footages to Final Cut Pro 7 on Mac OS X
iPAD Air for Movie Playing:Transfer/Stream Flash FLV/F4V Video to Apple iPad Air
Native P2 MXF Editing in FCP,Panasonic P2 MXF Editing in FCE/iMovie,P2 MXF Editing in Avid
Solutions of MXF Importing to Adobe Premiere CS5/CS6 by Making MXF Compatible
ISO to iPad - How to Convert ISO to iPad Mini 2 and Play ISO on iPad Mini 2
AVCHD to FCE 4/Adobe Premiere Pro-Import MTS/M2TS to FCE 4 or Premiere Pro CS5/CS6/CC7
Play Blu-ray/DVD Movies on Microsoft Surface 2,Enjoy Blu-ray/DVD on Surface Pro 2
AbbyCarrie11
Postova:  20
Pridružio se:  01.12.2013 15:22
