Convert Panasonic/Sony/Canon MXF to ProRes for FCP X on Mac
Postod JerryEdison001 » 07.12.2013 19:46
Question 1:
“We are using FCP X, and as far as I know it does not read Canon XF305 files natively. We tried Canon XF utility, with very limited success, on few different machines. Main problem with that piece of software is that it expects to see compact flash cards straight from the camera and doesn’t seem to work very well with folders on an HDD. Is there a recommended workflow for us to move MXF files from an HDD to FCP X?”
Answer: It is strongly suggested to convert MXF clips to Apple ProRes 422 using UFUSoft HD Converter for Mac software, because FCP X needs to have all the footage on a timeline in the single codec, otherwise it needs to render everything and does not preview clips in realtime. You can find a free trial version.
Question 2:
“I especially get confused when I need to download the plug-ins from the Canon site, which is a real mess! I have MXF footage shot on the Canon C300 and I’m trying to convert it from true 24p to ProRes 422(HQ) 23.976. Does anyone know an easy-to-use converter to do this?”
Answer: UFUSoft HD Video Converter for Mac will shed you some light on this problem. More than encoding true 24p C300 MXF files to ProRes 422(HQ) 23.976, it can also rewrap MXF to PrpRes 422, ProRes LT, ProRes Proxy, and ProRes 4444 for different FCP use.
Step-by-step: How to convert MXF files to Apple ProRes 422, ProRes 422 HQ or ProRes 4444 for Final Cut Pro X editing?
Note: To convert MXF video you need to transfer the whole MXF file structure to Mac HDD, because MXF systems produce split-file A/V (that is, the video and audio stored in separate files).
Step 1. Load MXF video files.
Connect your camcorder to Mac with USB cable or use card reader to transfer the MXF files to Apple hard drive disk.
Install and run UFUSoft HD Video MXF to Apple ProRes Converter.
Click “Add video” button to import your MXF files to the best UFUSoft HD Video Converter for Mac. Or click “Add from folder” button to load the MXF folder. The software will find corresponding audio content by itself and mix it to video during conversion.
Step 2: Select Apple ProRes as output format for FCP X.
Click “Format” bar and move your pointer to choose “Final Cut Pro > Apple PreRes 422″ or “Apple ProRes 422 HQ” or “Apple ProRes 4444″ as the output format for Final Cut Pro X.
Optional
1. You can also click “Settings” button, set bitrate and frame rate if necessary: 1920*1080 video size; 30fps frame rate(for original 60i videos) or 25fps frame rate(for original 50i videos).
2. Click “Edit” button, you can trim, crop the video, or add watermark and adjust effect to the videos which you will convert.
3. If you want to edit MXF files in iMovie or FCE, you just need to choose the “iMovie and Final Cut Express > Apple InterMediate Codec (AIC) (*.mov)” in the step 2.
Step 3. Click a big red button, start converting MXF files to Apple ProRes 422, ProRes 422 HQ or ProRes 4444with best audio and video synchronization for editing on FCP X. UFUSoft HD Video Converter for Mac supports batch conversion.
Note: If you are also a FCP 7 user, before you try to do the conversion, don’t forget to make sure that you have installed the Apple ProRes Codec manually since the FCP 7 asks users to install it by themselves.
After conversion, you can import Apple ProRes video files to Final Cut Pro X for editing without problems.
Other Tips:
1. canon c300 mxf to fcP, canon xf105 plugin for fcp,mxf converter, sony mxf file converter, mxf to prores, canon xf305 fcp plugin, canon xf100 fcp plugin, canon xf fcp plugin
2. avchd to fcp, avchd to fcp converter,avchd into fcp, avchd to fcp 7, import avchd fcp converter, avchd to fcp final cut, prores 422 fcp for editing, import avchd final cut pro, m2ts to fcp
3. Logiciel Récupération De Données mac mavericks,d'éviter la perte de données sur Mac,Récupération de Données Mac Lion,Mac Snow Leopard Récupération de Donnée,logiciel recuperation formatage mac 10.8,lecteur Blu-ray sur Mac Mini,Comment Lire Blu-ray sur un MacBook Pro,meilleur lecteur de macbook air bluray,Logiciel de Lecture Blu-ray pour HTPC,2014 le logiciel de lecteur Blu-ray pour Windows 8.1/8,Télécharger lecteur blue ray pour windows 8.1,lecteur blu ray pc gratuit télécharger,Lecteur Blu-ray sur Mac OS X Mavericks,Lecteur Blu-ray sur Mac OS X Mountain Lion,lecteur Blu-ray pour Lenovo IdeaPad ordinateur portable,le logiciel de lecteur Blu-ray pour Lenovo Thinkpad
4. remove drm protection,drm removal software,drm removal itunes, video drm removal, wmv drm removal,drm removal itunes movie, drm removal itunes 7/8, drm crack itunes, drm converter itunes
5. ufusoft blu-ray player,vlc blu ray,ufusoft mac blu-ray player,aacs codec,ufusoft mxf converter for mac,vlc blu ray windows 8,media composer mov full hd,blu ray player for windows 8,panasonic ag-hvx200 conversor
JerryEdison001
Postova:  16
Pridružio se:  24.11.2013 13:01
