Make XAVC Mac Compatible-Convert Sony XAVC to QuickTime MOV
Postod AbbyCarrie11 » 04.12.2013 16:16
For Sony PMW-F55/Sony PMW-F5 camera owners, most of them have a headache of the video format their cameras produced, it produces XAVC files which are not compatible with QuickTime. So how to convert Sony XAVC to QuickTime (mov) files for Mac?
The tutorial will show you the fastest and easiest solution to convert XAVC to mov via aPubsoft XAVC Converter for Mac. It is an all-in-one XAVC converter tool on Mac OS X 10.9 Mavericks, 10.8 Mountain Lion, 10.7 Lion, 10.6 Snow Leopard, etc specially designed to convert Sony XAVC to avi, wmv, mpg, mov, vob, mpeg, flv, f4v, 3gp, mp4, etc with excellent quality and super fast conversion speed. The following is the detailed steps of converting xavc to mov with the program.
Step 1: Click “Add” to import your Sony PMW-F55/Sony PMW-F5 XAVC files
Click “Add” to import your XAVC files. The aPubsoft XAVC Converter for Mac supports adding multiple files.
Step 2: Choose MOV as output format and specify destination folder
There are actually various output formats you can choose from. In this case, you can simply select mov format under “General Video” catalogue from “Format” drop-down list.
After you choose mov output format, you can specify your destination folder for your converted mov files if necessary.
Step 3: Edit your Sony PMW-F55/Sony PMW-F5 XAVC videos
Click Edit to edit your XAVC files by cropping, trimming, adding watermarks (text, video or image)/effects, replacing audio, removing interlaces and video noises and so on.
Step 4: Click “Convert” to start XAVC to mov conversion
Click to convert XAVC files to QuickTime mov files automatically. If you would like to merge the variable XAVC files into one output QuickTime mov file, please select all XAVC files and click Merge before you click the “Convert” button.
Read More:
Best Baby Slideshow Maker Program for Windows 8.1/8/7-Create a Memorable Baby Slideshow
How to Make a Wedding Video/Photo Slideshow with the Best Wedding Slideshow Builder?
Import/Convert Canon EOS C300 MXF to AIC MOV for iMovie 8/9/11 on Mac
Convert/Edit Canon C300 MXF to FCP, iMovie, Avid, Premiere Pro on Mac
MXF Import Final Cut,Getting MXF files into Final Cut Pro,Convert MXF to FCP X/7/6
AbbyCarrie11
Postova:  20
Pridružio se:  01.12.2013 15:22
