How to Download/View/Play DVD IFO Files to Galaxy Note 3?
Postod AbbyCarrie11 » 02.12.2013 15:46
What is DVD IFO?
IFO is a DVD Info File format. It is the counterpart of a .VRO file, where the VRO contains the media stream information, and the IFO file contains information for chapters, subtitles and audio tracks. To be DVD-compliant, a VIDEO_TS.IFO file (also referred to as the VMGI, or Video Manager Information file) needs to be present on a DVD.
The Samsung Galaxy Note 3 is the first device ever to feature 3GB of RAM. With it, Samsung makes the jump to 1080p full HD displays on phablets and it adopts a new textured back. The Note 3 features a larger than before 5.7” 1080p Super AMOLED display, but it retains a more compact profile. There is a 13-megapixel camera with improved flash, and of course an all new S Pen with improved functionality. And this Samsung Galaxy Note 3 is also a great media player which supports a lot of media formats including files with MP4, DivX, XviD, WMV, H.264, H.263 as video format and MP3, WAV, eAAC+, AC3, FLAC as audio format. The Samsung Galaxy Note 3 could be some kind of media player, when you are away from home or during your trip.
How to convert DVD IFO to Samsung Galaxy Note 3?
You may find the IFO file does not work on the new Galaxy Note 3. If you want to put DVD IFO files to Samsung Galaxy Note 3 for playing, we need a good DVD IFO to Galaxy Note 3 converter to transcode DVD IFO to Samsung Galaxy Note 3 supported formats like H.264 MP4. The aPubsoft DVD Ripper is the best DVD IFO to Galaxy Note 3 converter on Windows XP, Windows Vista, Windows 7, Windows 8, Windows 8.1.
Step 1. Load DVD IFO to aPubsoft DVD Ripper.
Run DVD Ripper as your superior DVD IFO to Galaxy Note 3 converter , and click the “IFO/ISO” button to choose the DVD IFO file from computer hard drive.
Step 2. Choose Samsung Galaxy Note 3 MP4 format.
Click on “Format” bar and to select a video format that is supported by Samsung Galaxy Note 3. Most acceptable formats are H.264 MP4. For example, you may follow “General Video” and select “MPEG-4/H.264 AVC Video (*.mp4) for Galaxy Note 3.
Tip: You can set video and audio parameters by clicking “Settings” as follow:
Video Size: 1280×720 pixels Video Bitrate: 2000K Frame Rate: 24fps or 30fps
Audio Sample Rate: 44100Hz Audio Bitrate: 160000bps
Step 3. Convert DVD IFO to MP4 for Samsung Galaxy Note 3.
Click the convert button under the preview window, and the conversion from DVD IFO to Samsung Galaxy Note 3 MP4 starts right away. You can then transfer and sync DVD IFO movies to Samsung Galaxy Note 3, and play videos with Samsung Galaxy Note 3.
If you want to play MKV video to Samsung Galaxy Note 3, AVI video with Xvid on Samsung Galaxy Note 3, and other formats like MTS/M2T/M2TS, MOV, you may use aPubsoft Blu-ray Ripper as the fast Galaxy Note 3 Converter Ultimate. With this Windows Samsung Galaxy Note 3 Converter ultimate, you can also Rip/Convert Blu-ray, DVD to Galaxy Note 3.
Read More:
Best Baby Slideshow Maker Program for Windows 8.1/8/7-Create a Memorable Baby Slideshow
How to Make a Wedding Video/Photo Slideshow with the Best Wedding Slideshow Builder?
Import/Convert Canon EOS C300 MXF to AIC MOV for iMovie 8/9/11 on Mac
Convert/Edit Canon C300 MXF to FCP, iMovie, Avid, Premiere Pro on Mac
MXF Import Final Cut,Getting MXF files into Final Cut Pro,Convert MXF to FCP X/7/6
AbbyCarrie11
Postova:  20
Pridružio se:  01.12.2013 15:22
