Work with Individual .mts/.m2ts Videos in FCP and Premiere
Postod Fgzp513 » 27.11.2013 4:17
Summary: When you didn't get correct structure of your AVCHD footage, then how to open and edit your single .mts files in FCP and Premiere Pro without problems? Fortunately, there is an easy way to fix the issue. Let's find it out here.
Adobe Premiere can edit natively with MTS files, but it doesn't work well at all if you do this. And I couldn't transcode them with FCP 7 as the original directory structure from the camera had been lost. This is why I need a third party tool to help me. To get my Final Cut Pro and Premiere Pro working perfectly with AVCHD .mts files, the best way is to convert MTS to ProRes MOV when is perfectly work with FCP and Premiere Pro. Read on to learn details.
The reason that I can't sucessfully ingest the single .mts videos to your non-linear editing systems is simple. In fact, Final Cut Pro/Premiere Pro is very picky in importing videos. One can import AVCHD files on Mac directly from a memory card (with the original file structure in place), or from a camera archive, but can't import them by selecting the single .mts clips.
That's is to say, if your card structure is broken and whatever reason it doesn’t come across intact, you can't directly load your mts files onto your FCP and Premiere Pro. In case that FCP/Premiere needs a correct folder Structure so if you have to, transcoding the MTS to Prores with a 3rd party app is a feasible workaround. They you will have no requirement with ingest supported with additional software and no use camera archives method.
Here I would like to share this usefull MTS Converting program - Pavtube MTS/M2TS Converter for Mac is recommended for you, with this you can achieve the individual .mts to Prores conversion. No matter the AVCHD files are single .MTS files or directly from your camera, you can transfer it to FCP/Premiere compatible formats and directly import it to FCP for easy editing.
Goode News! Now buy MTS/MTS Converter for Mac, you can free get a FLV/F4V Converter for Mac on Pavtube 2013 Thanksgiving Giveaway
Plus, this Mac AVCHD converter also supports converting AVCHD MTS footage to iMovie, Avid Media Composer, Final Cut Express and more to meet your needs. These output formats are specially presetted, so the conversion quality is guaranteed, you can get lossless video conversion with this tool. Now, download it and follow the step-by-step guide transcoding single .MTS/M2TS to Final Cut Pro/Premiere Pro.
Step 1. Run the nice AVCHD MTS Converter on your Mac and load mpg clips to it by clicking "Add" button. There are two ways for you to import files: add video directly and add the entire folder.
The software supports batch conversion, so you can import several videos to it one time.
Step 2. Click "Format" bar and then move your pointer to "Final Cut Pro > Apple ProRes 422 (*.mov)" as the editable format for Final Cut Pro and Premiere Pro.
Here listed the main difference of the five ProRes codecs.
a. ProRes 422 (HQ): offers the utmost possible quality for 4:2:2 or 4:2:0 sources and provides target data rate of approximately 220 Mbps and higher quality than Apple ProRes 422;
b. ProRes 422: provides target data rate of approximately 145 Mbps and higher quality than Apple ProRes 422 (LT);
c. ProRes 422 (LT): provides roughly 70 percent of the data rate of Apple ProRes 422 (thus, smaller file sizes than Apple ProRes 422) and higher quality than ProRes 422 (Proxy);
d. ProRes 422 (Proxy): provides roughly 30 percent of the data rate of Apple ProRes 422 and high-quality offline editing at the original frame size, frame rate, and aspect ratio;
e. ProRes 4444: offers the utmost possible quality for 4:4:4 sources and roughly 50 percent higher than the data rate of Apple ProRes 422 (HQ).
Step 4. You can click "settings" to customize the output parameters, adjust the resolution, bitrate as you want.
Note 1: You are allowed to adjust output video and video parameters. However, if you have no idea about profile setting, keep it as original recordings will provide you the files with less quality loss, and keep default settings is also a good choice for your to get a high quality files.
Note 2: In order to get customized videos, you can add subtitles to your own videos.
The free Subtitle Edit will help you to edit your own subtitles then put it into videos.
Read More: Subtitle FAQs: Free permanently attach subtitles to videos/movies
Step 5. Click convert button to start converting AVCHD MTS to Prores MOV for Final Cut Pro and Premiere Pro editing.
After the Mac MTS to Prores conversion, you can import the converted footages to FCP and Premiere Pro for editing smoothly on Mac. You're done! Now you may know how to ingest and edit single .MTS footage in Final Cut Pro and Premiere Pro.
Other related tutorials:
Convert MTS/M2TS on Windows
Play AVCHD mts files on QuickTime
Transcode AVCHD MTS, M2TS, M2T, TS to AIC for importing to iMovie/FCE 4
Converting MTS files to Edit in Window Movie Maker
Source: http://mediaconverting.blogspot.com/2013/11/import-avchd-mts-files-to-fcp-premiere.html
Fgzp513
Postova:  50
Pridružio se:  24.10.2013 3:20
