30% off Blu-ray Ripper-Ripping Blu-ray to LG G-Pad for playb
Postod HaileyLi » 22.09.2013 8:54
Description: Do you want to play Blu-ray movie on new LG G-Pad? The article will show you detailed guide to super easy and ultrafast convert Blu-ray to LG G-Pad for playback anywhere.
Tips. If you want to put and play MKV, AVI, VOB, Tivo, M4V, WMV, MPG, FLV, F4V videos onto LG G-Pad, please refer to the guide: How to play any videos on LG G-Pad?.
LG has just announced new super-small Android tablet LG G-Pad 8.3. It is fitted out with an 8.3-inch screen with a better-than-full-HD display at a resolution of 1920*1200 and powered by Android 4.2.2 Jelly Bean. A quad-core Qualcomm Snapdragon 600 processor clocked at 1.7 GHz, 2GB of RAM and 16GB of storage with micro SD slot are built in. A healthily-sized 4,600 mAh battery is claimed to support playing videos for 7-8 hours. And Q-pair can sync note, memo, SMS, etc from your phones to LG G-Pad. Compared with new Nexus 7, larger display, better processor with 1.7GHz quad core and longer battery life is more desirable.
It will become a great handy device for watching HD movies wherever you are. However, it is hard to enjoy your favorite Blu-ray movies on the go with LG G-Pad. Without Blu-ray drive LG G-Pad cannot play Blu-ray directly for copyright protection of Blu-ray like region code, AACS, BD+, etc, prevents from copying the digital copy to LG G-Pad. In this case, ripping and converting Blu-ray to LG G-Pad supported format is a good idea.
What you need is proper third party software to remove Blu-ray copyright protection and convert to LG G-Pad friendly video format. Pavtube Blu-ray Ripper (Blu-ray ripper for Mac) is an ideal tool. It is specialized in ripping the latest Blu-ray, and then converting to videos with high quality for portable devices. And you can adjust the video parameters like bitrate, audio channels, resolution, etc.
How to super easy and ultrafast convert Blu-ray movie to LG G-Pad friendly format?
Download the best Blu-ray to LG G-Pad Ripper and install it on your PC or Mac.(Back to School Promotion is on the way; seize the opportunity to get 30% discount for it.)
Step 1. Load Blu-ray to Blu-ray to G-Pad Converter.
Launch Pavtube Blu-ray Ripper, Click "Load file" button on the top left to import Blu-ray source. To rip Blu-ray to LG G-Pad will just take few seconds and then you can preview the entire movies on the preview window on the right. Then go to "Subtitle" and "Audio" drop list to select the desired tracks for output.
Note: The real main title can be recognized and picked up automatically, which is what some other Blu-ray rippers like Leawo cannot do. Some Disney movies contain a fake main title with similar duration and file size but chaotic contents, and it is difficult to manually choose real main title without previewing it.
Step 2. Choose H.264/MPEG-4 MP4 format for LG G-Pad.
Click "Format" dropdown list to go through video formats. Choose a compatible format for LG G-Pad from "Common Video" or "HD Video" option.
You can choose compatible "H.264 HD Video (*.mp4)" under "HD Video" option. H.264 MP4 will create files with less quality loss. For the high quality of videos, the output files will be with big file size. If you want to get a smaller file, "MPEG-4 HD Video (*.mp4)" is available.
Step 3. Adjust video and audio parameters. (Optional)
Click "Settings" button to check and change video and audio parameters like bitrate, size, codec, etc. Generally bigger bitrate will create higher image quality and bigger file size, and vice versa. And there is a balance between bitrate and resolution. Take note that default settings is sufficient enough for most of users.
Step 4. Convert Blu-ray to LG G-Pad.
"Browse" your computer to find a new folder for generated file. Then click "Convert" button to start super easy and ultrafast converting Blu-rau to MP4 for LG G-Pad. Once completed, you can click "Open" button to locate the generated files for LG G-Pad.
Connect LG G-Pad to computer and copy the generated files to it. It is time to enjoy Blu-ray on your LG G-Pad.
You may also want to get more special offer:
ByteCopy($42) + Blu-ray Video Converter Ultimate($65) = Only $80, Save $27
ChewTune ($29) + Blu-ray Video Converter Ultimate($65) = Only $75, Save $19
ChewTune for Mac($29) + iMedia Converter for Mac($65) = Only $75, Save $19
Blu-ray Video Converter Ultimate($65) + DVD Creator($35) = Only 65$, Save $35
iMedia Converter for Mac($65) + DVD Creator for Mac($35) = Only 65$, Save $35
HaileyLi
Postova:  54
