MXF to MOV Encoder-Encoding Canon C300 MXF for iMovie on Mac
Postod kelly456 » 21.03.2013 4:23
In this tutorial, you will learn how to convert & transcode Canon C300 MXF format to iMovie compatible AIC MOV format so that you can smoothly import Canon C300 MXF videos to iMovie without rendering time.
Canon has produced many professional camcorders, such as XF series, include XF305, XF300, XF105, XF100, etc. these professional camcorders can help us record vivid images. Recently, a new Camera named Canon C300 came to us. You may have used Canon C300 and XF series camcorders to record many high-definition footages which are in MXF video format, this video format is good for record videos, but it’s not compatible with many editing software, such as iMovie on Mac. You may have the need to import C300 MXF footage to iMovie for editing, but the iMovie doesn't support MXF files directly.
How to import Canon C300 MXF to iMovie for editing? The best way is to convert MXF to iMovie supported video format, iMovie best supported video format is Apple InterMediate Codec (AIC) MOV format. You can convert recorded C300 mxf files to AIC MOV for iMovie easily, please follow the guide below.
1. Free Download Pavtube MXF Converter for Mac. This is an excellent Mac MXF to iMovie Converter, can help you transcode MXF files to any formats you want.
2. Install and launch this Mac MXF to iMovie Converter, import Canon MXF footages to the software.
3. Click "Format" bar to choose the output format, for editing Canon MXF files on iMovie, you can choose "iMovie-> Apple InterMediate Codec (AIC) (*.mov)".
4. You can click "Settings" button to adjust the output parameters such as resolution and bitrate, you can also keep it as original.
5. Click "Convert" button to start to convert Canon C300 MXF to AIC MOV for importing to iMovie.
Pavtube MXF to iMovie converter can convert Canon MXF footages quickly, after conversion, you can use converted files in iMovie smoothly, just have a try.
More Tricks for Editing MXF files on Mac
[*] Transfer Canon C300 MXF to FCP/Quicktime for editing
[*] Convert Panasonic P2 MXF files to iMovie AIC MOV
[*] Convert Canon MXF to Avid DNxHD on Mac OS X
[*] Load Sony XDCAM MXF to iMovie with AIC codec
[*] Let Sony XDCAM MXF files work with Final Cut Pro
[*] Encode MXF media to Avid with DnxHD codec[/b]
[*] Convert MXF to AVI/WMV/MOV/MP4/MPEG on Mac
[*] Turn Canon and Panasonic MXF files to MPEG video
Pavtube iMedia Converter for Mac is an all-in-one bluray ripper for Mac, Mac DVD Ripper, and Video Converter for Mac. can convert 1080p cameras/camcorders footages to editable HD video formats for non-linear editing software like iMovie, Final Cut Express, Final Cut Pro, Final Cut Studio, Avid, Adobe Premiere etc. The HD footage can be compressed to SD video clips for storage when you wanna save storage space. The Mac iMedia Converter is also able to extract audios from Blu-ray discs, DVDs and videos for media players with high quality and fast conversion speed.
Tips: If you need to burn MXF to DVD disc/ISO/folder on Mac, you can try Pavtube DVD Creator for Mac.
PS. If you have any problem, pls contact with [url=mailto:[email protected]][email protected][/url] to get more information. You also can leave a message on Pavtube Community or Facebook, we will answer your questions as soon as possilble.
Re: MXF to MOV Encoder-Encoding Canon C300 MXF for iMovie on
Postod lisa198754 » 22.03.2013 10:48
Summary: Having problems when importing and editing Sony PMW-320 MXF footage in Final Cut Pro 6/7? Here you will find the best solution.
We all know that the recording format of Sony PMW-320 is the MXF which delivers stunning picture quality. However, if you want to ingest and edit Sony PMW-320 MXF files in Final Cut Pro 6/7, you will meet some problems. The problems lie in that FCP cannot support the original MXF footages from PMW-320. It is a common sense that the native format for FCP is Apple ProRes encoded MOV. So the first problem you have to solve is to transcode Sony PMW-320 MXF to ProRes mov for Final Cut Pro 6/7. Along with some help from third-party softwares, it can be done. Below is a simple solution for you,
First of all, free download and install Brorsoft [url=the most compatible codec which is specially designed for editing in iMovie 8/9/11.]MXF to MOV Converter for Mac[/url] to your computer.
Overall, the program is a professional yet easy-to-use MXF to MOV Converter on Mac OS X which can not only convert Sony PMW-320 MXF files to Apple ProRes codec videos for Mac editing, but also provide simple video editing functions for you. The mac MXF to ProRes Converter can also convert MXF videos from Canon C30O XF100, XF105, XF305, Pansonic P2 cameras for editing in Final Cut Pro 6/7, Final Cut Pro X, Final Cut Express, iMovie, Avid MC, Adobe Premiere Pro etc. Just download it and follow the tutorial below to get the work done.
[size="4"]Guide: Transcoding Sony PMW-320 MXF files to Apple ProRes MOV for FCP 6/7[/size]
Step 1: Import video files from your Sony PMW-320 to the MXF to FCP Converter Mac.
Note: Before conversion, you need to transfer MXF files from your Sony PMW-320 to Mac Hard Drive, then click the "Add files" button to browse to import MXF videos.
Step 2. Click the format bar, and move mouse cursor to "Final Cut Pro > Apple ProRes 422 (*.mov)" as output format.
Step 3. Click "Convert" button to start transcoding Sony PMW-320 mxf files to Apple ProRes MOV for Final Cut Pro 6/7 under Mac OS.
Some more helpful features of the Free Mac MXF to MOV Converter:
Once the MXF to ProRes 422 conversion is done, you can transfer Sony PMW-320 MXF footage into Final Cut Pro 6/7 for editing smoothly on Mac with ease.
If you have problems when importing or editing your Canon, Sony, Panasonic etc, camera video files, you can check out "Brorsoft Camcorder/Camera Importing Tips" or "FCE, FCP, iMovie Column"to get your solutions.
lisa198754
Postova:  3
Pridružio se:  22.03.2013 10:41
Postod kelly456 » 25.05.2013 5:26
Get latest Pavtube Video Converter Ultimate with 40% off
Surprising!!! Pavtube anounced the new Update and you can get 40% off Special Offer From Pavtube Now!
Pavtube offers updates for the outstanding Video Converter Ultimate on May 22, 2013 to help Pavtube members with better video/audio sync display, and this new update offers more output formats for new portable devices, e.g. Samsung Galaxy Tab , Acer Iconia Series Tablets, HTC One, etc. And to celebrate this new update and show gratitude to new and registered users, Pavtube Video Converter Ultimate is on sale with 40% off.
What's Pavtube Video Converter Ultimate and what can it do for you?
Pavtube Video Converter Ultimate is the best all-in-one application that combines a best Blu-ray ripper, DVD converter, and video converter together for you to convert Blu-ray/DVD movies and almost all kinds of videos to universal video and audio file types with super fast conversion speed and excellent image and sound quality, so that you can play and watch output videos on multiple portable tablets and smartphones, HD media players and programs for video editing. Also, it provides video editing functions so you can trim, crop, merger and split original Blu-ray, DVD and videos.
What's new in the latest 4.3.0.4818 version?
* Support latest Blu-ray and DVD movies.
Pavtube Video Converter Ultimate now support MKB v38 disk decryption, and new Blu-ray movies like Les Miserables, Jack Reacher, The Hobbit–An unexpected Journey, Life of Pi and DVD releases including The Twilight Saga: Breaking Dawn, Part 2, Wreck-It Ralph, End of Watch, Parental Guidance, Downton Abbey: Season 3 are successfully loaded and ripped in latest Pavtube program.
* Better video/audio synchronization and better video display.
You will get better video display without video/audio sync issue in latest Pavtube version and it is outstanding from its competitors.
* Better DVD main title detecting.
Pavtube improves the performance of detecting DVD main title so you can get exact correct main movie for backup and ripping.
* More output formats for Mobile Devices
It adds more preset output formats for latest Portable Devices like iPad 4, Samsung Galaxy Tab 3, Google Nexus 10, etc. As for devices not included, Pavtube offers several common profiles for Android tablets/phones as well as Windows 8 tablets/phones.
See More details about this update and 40% off discount, plz check Pavtube official site:
http://www.pavtube.com/
Free trial version of Pavtube Video Converter Ultimate is available for everyone:
Pavtube Video Converter Ultimate for Windows
Get 40% off discount for Pavtube Video Converter Ultimate:
https://www.facebook.com/pavtubefans?v=app_186981981345123
Alternative Giveaway from Pavtube:
* 40% off iMedia Converter for Mac
* 40% off Blu-ray Ripper
Pavtube Blu-ray Ripper is Updated to MKB V38 – 40% OFF
Pavtube Blu-ray Ripper for Mac Update: Rip the latest Blu-ray movies on Mac OS X
* 40% off DVD Ripper
Never miss "Big Sale for Pavtube- Get 40% OFF on Blu-ray/DVD Ripping tools"!
Source: New Update for Pavtube Video Converter Ultimate
Postod kelly456 » 22.06.2013 15:46
Father's Day Biggest Discount: Save $13 Get Best iMedia Converter for Mac
Surprising!!! Up to 30% OFF Special Offer for 2013 Father's Day From Pavtube.com
Father's Day is coming soon! To celebrate Father's Day with you, Pavtube is offering up to 30% OFF discount at 2013 Father's Day Biggest Promotion. Like us on our facebook page to get it Now! And don't forget to tell your friends about it! Expires on June 23, 2013. Time-limited! Never Miss!!!
Here is Father's Day best Gift Idea for your beloved dad!
Top Pick - 30% OFF Pavtube iMedia Converter for Mac (Saving $13)
* Backup/Rip BD/DVD/Videos for home server, iPhone/iPad/Android/Windows 8 Tablets & Phones
Pavtube iMedia Converter for Mac is an all-in-one video converter, DVD ripper and Blu-ray Ripper, which means it lets you convert Blu-rays, DVDs, TV recordings, HD (AVCHD) shootings, Flashes and many other video types into desire formats (MP4, MOV, M4V, TS, MKV, AVI, WMV, MPG, VOB, etc) for playback on your Android tablet, such as Nexus 7, Galaxy Tab,Galaxy S3, Asus Transformer Prime, Acer Iconia Tab, HP TouchPad, BlackBerry PlayBook, Motorola Xoom, Kindle File HD, Nook Color, Pandigital Novel 7 Tablet, etc. or IOS Device like Apple TV, iPhone 5, Microsoft Surface and others.
Related guides for you:
Move TiVo recordings to iPhone 4 on Mac
Backup Blu-ray disc to Mac
Microsoft Surface Video Playback
Convert MKV/M2TS/AVI/WMV to iTunes for iPad
Mac transfer movies to Galaxy Tab 10.1/Galaxy Tab 8.9
Steam music and video to iPhone and iOS device
Put/Play Blu-ray/DVD/Videos on Archos 101 Internet Tablet
* Convert HD footages (AVCHD MTS/M2TS/M2T, MXF, HDV, TOD, MOD, MOV) to various Video Editing Software(FCP, iMovie, FCE, Avid, Premiere, Sony Vegas, Windows Movie Maker, etc.)
Pavtube iMedia Converter for Mac can also convert Canon, Nikon, Olympus, Sony and Panasonic camera or camcorder recorded HD videos or 1080p footages to editable HD video formats for non-linear editing software like iMovie, FCE, FCP 7/FCP X, Final Cut Studio, Avid, Adobe Premiere, Sony Vegas, Pinnacle Studio, Cyberlink PowerDirector, Windows Movie Maker, etc. The HD footage can be compressed to SD video clips for storage when you wanna save storage space.
Focus on dealing with HD footages for Camera & Camcorders:
1. Record videos in MXF:
Canon XF series
: Canon XF100,Canon XF105, Canon XF300, Canon XF305, etc. or Canon C300, Canon C500. (Canon MXF)
Sony XDCAM EX : PMW-350K, PMW-F3L, PMW-F3K, PMW-100, PMW-150, PMW-EX1, PMW-320 (XDCAM MXF)
Panasonic P2 Camcorders and AVCCM Cameras : AG-HPX600, AJ-HPX3700, AG-HPX250, AJ-HPX2000, AJ-HPX2100, AJ-HPX3000,AJ-HPX3100, AJ-HPX2700, AG-HVX200, AG-HPX170, AG-HPX171, AG-HPX500, AG-3DA1, AG-AC160, AG-AF100, AG-HCK10G, AG-HMC150PJ, AG-HMC40PJ, AG-HMC80PJ, etc. (P2 MXF)
2. Record videos in MTS:
Sony: Sony HDR-XR100, Sony HDR-TG1, Sony HDR-CX7, Sony HDR-XR500, Sony HDR-CX550V, Sony NEX-F3, Sony NEX-5N, Sony NEX-FS700, Sony FS100, Sony A57, Sony A65, Sony A77, Sony HDR-PJ780, Sony DSC-WX80, Sony HDR-SR1, Sony HDR-XR160E, Sony NEX-6, Sony NEX-5R, Sony A99, Sony CX106, Sony VG900/VG30
Canon: Canon Vixia HF G20, Canon Vixia HF G10, Canon Vixia HF S100, Canon VIXIA HF200, Canon HF100, Canon HD camcorder HG10, Canon HF G25, Canon XA10, Canon HF M300, Canon HF M500, Canon C100
Panasonic: Panasonic Lumix LX-7, Panasonic GH2, Panasonic GH3, Panasoni TM90, Panasonic TM900, Panasonic HC-X900/X900M, Panasonic HC-X800, Panasonic X920, Panasoni SD900, Panasonic DMC-FZ200, DMC-ZS3 camcorder, Panasonic TZ-7 (ZS3 in the US)., Panasonic hdc-sd9 camera, Panasonic HDC-HS300,Panasonic HMC70P, Panasonic HDC-SD10 camcorder, Panasonic DMC TZ7, Panasonic HMC70P
Olympus: E-PL3,E-PM1,E-P3
JVC camcorder: GZ-HD300 Everio, GZ-EX215, GZ-HD30
3. Record videos with "MVI _":
Canon PowerShot digital cameras like A630, SD780, SD1100
4. Record videos in H.264 MOV:
Canon DSLR Cameras: T4i 650D, T3i 600D, T2i 550D,T5i 700D, 1D Mark IV, 1Ds Mark III, 5D Mark II/5D Mark III, 7D, 50D, 60D, EOS M, Powershot S95
Nikon DSLR Cameras: D800/D800E, 1J1, 1V1, 1J2, D600, D90, D7000, D3100, D3200, D5100, D4, D3S, S800C, D300S, D3X, D700
Pentax Cameras: Pentax Q/K-1, K-5, K-R, K-30
Olympus Cameras: E-M5, E-PL1, E-M1
Fujiflim Cameras: Finepix F550EXR
5. Record with XAVC format:
Sony F5, Sony F55, Sony PMW-400
6. Record videos with MP4 format:
Sony Cyber-shot DSC-H200, Sony Cyber-shot W730
* Convert Blu-ray/DVD videos to FCP, iMovie, FCE, Avid editable codec (AIC, ProRes, Avid DNxHD etc)
Import Blu-ray contents to iMovie/FCE for editing
How to Rip a DVD for FCP(X) editing
Convert Blu-ray files to FCP(X)
More Giveaway on Pavtube 2013 Father's Day Coupon:
1. Pavtube Blu-ray Video Converter Ultimate (20% off)
Basically it lets you put Blu-ray movies, DVDs and videos of various formats onto any portable device, so that you can use the copy-protected movies freely and watch movie anywhere.
Useful tips:
Convert Blu-ray/DVD movies to iTunes 11
Transfer 1080p Videos, Blu-ray, DVD to Galaxy Tab 3
Sync DVD, Blu-ray, 1080p Videos to Galaxy S4
Enjoy HD Contents on Galaxy Note II
Watch DVD, Blu-ray, and 1080p Video on LG Optimus G Pro
VivoTab ME400 play Blu-ray, DVD and 1080p videos
Stream DVD, Blu-ray Movies, 1080p HD Videos to PS3
Extract audio from Blu-ray movie for use in Pro Tools 9
2. Pavtube Blu-ray Ripper (Windows) (Mac) (30% off)
The app lets you back up and convert Blu-ray& DVD collections into iPad/iPhone/Apple TV friendly format so as to enjoy movies. This is definitely a good gift for frequent travelers. The software exports up to 1080p full HD video with both stereo and 5.1 sound, so as to make full use of available surround sound system. Moreover, the latest update includes 3D Blu-Ray ripping feature!
Useful tutorial:
Best Mac Blu-ray Ripper Review for Android, iOS or Windows 8
Watch 1080p Blu-ray Movies on Galaxy Tab 3
Rip Blu-ray to Kindle Fire HD
Convert Blu-ray to iMovie/FCE on Mac
Backup Blu-ray titles to Nexus 10 on Mac
How to stream Blu-ray movies to Popcorn Hour A-400
How can you appreciate Blu-ray Content material on Western Electronic WD TV Live
3. Pavtube DVD Ripper (Windows) (Mac) (30% off)
More than converting Blu-ray/DVD movies to Android tablet playing both on Mac and Windows, Pavtube DVD Ripper also pack perfect support for portable devices that run other OS, including iPad, iPhone, BlackBerry PlayBook, Microsoft Surface RT/Pro tablet, HP TouchPad, Nokia Lumia 920/822, etc.
Related tricks and tips:
Transfer DVD ISO/IFO to Surface RT & Pro
Put DVD to Nook HD or HD+ Tablet with desired subtitles
Convert DVD ISO/IFO to Galaxy Tab 2 10.1
Transfer DVD movies to Nabi 2 tablet for your kid
Transfer DVD to Coby Kyros Tablet
Play DVD/DVD ISO/IFO on Nexus 4 in 16:9 widescreen
Play DVD movies on LG 32LV2400 HDTV
Never miss to get 20% off iMedia Converter for Mac, Video Converter Ultimate and 30% off Blu-ray Ripper and DVD Ripper at 2013 Father's Day Special Offer!
Postod kelly456 » 13.07.2013 11:27
20% off-Working with HD Video (AVCHD/MTS/MOV) from Camera/Camcorder on Mac
Bonnes vacances mates, summer is here again! Giant waves, the sand, the rocks, etc. all awaits for you. With whom you are planning to hang out the wonderful summer break? With which camera/device you want to take with? Don't forget to shoot these wonderful moments timely, so that you can enjoy these valuable when playing back or sharing the footage with friends.
No matter what you will do with these raw footages, a powerful converter will help you out of the editing/converting dilemma easily. See this Pavtube iMedia Converter for Mac which is offering up to 50% off on Summer Big Sale together with you. Plus, Like Pavtube on Facebook and you would get an extra 5% off discount from above products!
Pavtube iMedia Converter for Mac with 20% OFF
An ultimate program which integrates video converting, blu-ray/dvd ripping and video/audio extracting feature. With it, you can easily convert your MTS/M2T/TS/MXF, and videos in MKV/MOV/AVI/MOV/WMV/FLV/VOB videos to FCP, iMovie, Avid, Premiere Pro, Apple Aperture 3, Kdenlive, After Effects CS6, DaVinci Resolve for further editing, or convert summer videos to compatible formats on portable devices like iPhone, iPad, android tablets and other devices.
Click the top left two icons to load your videos or discs, click the third icon to edit them including crop, trim, effect and audio editor.
Then click Format to choose best video format for your editing program or devices; click the red circle to star conversion.
More step-by-step guides available here to learn how to convert videos to FCPfor editing.
If you need to take a long flight on the way heading for your destination, it'll be a good idea to rip blu-ray/DVD movies to iPad, iPhone, iTouch or Android tablets for watching. The iMedia Converter for Mac is able to do this within a few clicks. Feel free to have a try!
Related articles:
Transfer movies to Galaxy Tab tablets from Mac
Import Media Files to Premiere Pro on Mac
Transfer Blu-rays to iMovie/FCE for editing
Rip Blu-Ray HD contents to Final Cut Pro
Convert a dvd for FCP(X) editing
Work with DVDs in iMovie
Pavtube Video Converter Ultimate-Faster DVD Ripper and Converter
Alternative Coupon Code for Mac users at Pavtube Summer Holiday Biggest Discoun:
1. Pavtube Media Magician for Mac with 50% OFF
A footage-focus program with lossless output, multi-trim out, smoothly transcoding and uploading to youtube features. It's a nice camera/camcorder assistant to help you convert hd videos in mov, mts, m2ts formats to MTS/M2TS/MOV/MKV/AVI losslessly.
Attached is a guide for video to NLE editing like FCPwith Media Magician.
2. Pavtube DVD Creator for Mac with 50% OFF
Burn your summer videos to playable DVDs easily and efficiently. You can customize your DVD templates, background music and text on videos.
Here are some more tips about how to burn a DVD quickly.
Don't hesitate, this Summer Break Special Offer expires on July 31, 2013. Never miss!!!
