How to edit Canon Vixia R40 AVCHD in PremierePro CS4/CS5/CS6
Postod kelly456 » 19.03.2013 7:20
How to edit Canon Vixia R40 AVCHD in Premiere Pro CS4/CS5/CS6
Summary:In this post, you will learn how to lossless Join Canon Vixia R40 for Adobe Premiere Pro CS4/CS5/CS6, and then you can edit natively.
The Canon VIXIA HF R40 Full HD Camcorder records Full HD 1920 x 1080p video to an internal 8GB flash drive or to an SD/SDHC/SDXC memory card. It also supports Full HD still image capture and the camera is equipped with built-in Wi-Fi for remote operation and live streaming. The HF R40 features a 3.28 megapixel Full HD CMOS image sensor and a DIGIC DV 4 Image Processor. It also employs a genuine Canon HD video lens with 53x Advanced Zoom and SuperRange Optical Image Stabilization with improved Dynamic Image Stabilization.
The VIXIA HF R40 lets you record AVCHD or MP4 files. 1080/60p recording captures twice the amount of information as 60i, and with images captured at a rate of 60 frames per second, diagonal noise is minimized so even fast moving subjects are clearly recorded. 1080/60p recording also means that the still images you extract are high quality as well. The camera supports an improved bit rate of 28Mbps for AVCHD recording, and MP4 files are captured at a bit rate of up to 35Mbps.
How to transfer Canon HF R40 AVCHD files to Adobe Premiere Pro CS6/CS5/CS4 for editing on Mac?
The best video codec and format supported by Adobe Premiere Pro CS6/CS5/CS4 on Mac is:Apple ProRes 422 codec MOV format, or QuickTime MOV format.
So before importing Canon HF R40 AVCHD files to Adobe Premiere Pro CS6/CS5/CS4, you can use Pavtube MTS/M2TS Converter for Mac to transcode Canon HF R40 AVCHD to MOV for Premiere Pro CS6/CS5/CS4, and then you can edit smoothly. Now please follow the steps below to know detail conversion steps.
1. Download and install Mac Canon Vixia MTS Converter. It's an excellent software which can convert Canon HF R40 AVCHD to MOV for Adobe Premiere Pro CS6/CS5/CS4 on Mac 10.8, more output formats are also supported, such as MOV, AVI, etc.
2. Import the Canon HF R40 AVCHD video you want to convert.
3. Click format column to choose the best video format for editing in Adobe Premiere Pro CS6/CS5/CS4 on Mac. Click and choose Apple ProRes 422 MOV for output. You can also choose Adobe Premiere -> MOV for output.
4. You can customize output parameters as you want. Adjust the resolution, bitrate, etc according to your need; you can also keep the parameters as original.
5. After these steps above, click convert button to start converting Canon HF R40 AVCHD to ProRes MOV for Adobe Premiere Pro CS6/CS5/CS4 on Mac. Then you can import your converted media files to Adobe Premiere Pro on Mac for editing.
This Canon AVCHD to Premiere Pro converter will help you convert videos with best quality, and then you can edit Canon HF R40 AVCHD in Adobe Premiere Pro CS6/CS5/CS4 on Mac as you want with no codec problems.
Related Canon AVCHD application in Pavtube Canon Column and MTS column:
Canon AVCHD to FCP
Canon AVCHD to iMovie
Use MXF files in Premiere Pro
Premiere Elements workflow with MTS
You can also try Pavtube DVD Creator product for free, which can easily burn Canon AVCHD to DVD disc/ISO files.
PS. If you have any problem, pls contact with [email=http://[email protected]/][email protected][/email] to get more information. You also can leave a message on Pavtube Community or Pavtube Facebook, we will answer your questions as soon as possilble.
Re: How to edit Canon Vixia R40 AVCHD in PremierePro CS4/CS5
Postod lisa198754 » 22.03.2013 10:46
Summary: Having problems when importing and editing Sony PMW-320 MXF footage in Final Cut Pro 6/7? Here you will find the best solution.
We all know that the recording format of Sony PMW-320 is the MXF which delivers stunning picture quality. However, if you want to ingest and edit Sony PMW-320 MXF files in Final Cut Pro 6/7, you will meet some problems. The problems lie in that FCP cannot support the original MXF footages from PMW-320. It is a common sense that the native format for FCP is Apple ProRes encoded MOV. So the first problem you have to solve is to transcode Sony PMW-320 MXF to ProRes mov for Final Cut Pro 6/7. Along with some help from third-party softwares, it can be done. Below is a simple solution for you,
First of all, free download and install Brorsoft [url=the most compatible codec which is specially designed for editing in iMovie 8/9/11.]MXF to MOV Converter for Mac[/url] to your computer.
Overall, the program is a professional yet easy-to-use MXF to MOV Converter on Mac OS X which can not only convert Sony PMW-320 MXF files to Apple ProRes codec videos for Mac editing, but also provide simple video editing functions for you. The mac MXF to ProRes Converter can also convert MXF videos from Canon C30O XF100, XF105, XF305, Pansonic P2 cameras for editing in Final Cut Pro 6/7, Final Cut Pro X, Final Cut Express, iMovie, Avid MC, Adobe Premiere Pro etc. Just download it and follow the tutorial below to get the work done.
[size="4"]Guide: Transcoding Sony PMW-320 MXF files to Apple ProRes MOV for FCP 6/7[/size]
Step 1: Import video files from your Sony PMW-320 to the MXF to FCP Converter Mac.
Note: Before conversion, you need to transfer MXF files from your Sony PMW-320 to Mac Hard Drive, then click the "Add files" button to browse to import MXF videos.
Step 2. Click the format bar, and move mouse cursor to "Final Cut Pro > Apple ProRes 422 (*.mov)" as output format.
Step 3. Click "Convert" button to start transcoding Sony PMW-320 mxf files to Apple ProRes MOV for Final Cut Pro 6/7 under Mac OS.
Some more helpful features of the Free Mac MXF to MOV Converter:
Once the MXF to ProRes 422 conversion is done, you can transfer Sony PMW-320 MXF footage into Final Cut Pro 6/7 for editing smoothly on Mac with ease.
If you have problems when importing or editing your Canon, Sony, Panasonic etc, camera video files, you can check out "Brorsoft Camcorder/Camera Importing Tips" or "FCE, FCP, iMovie Column"to get your solutions.
lisa198754
Postova:  3
Pridružio se:  22.03.2013 10:41
