How to Recover Deleted text SMS from iPhone 4/4S/5?
Postod abcmac83 » 29.09.2012 12:08
If you often use your iPhone 4/4S/5 to send or receive messages, you may have the habit of clearing useless text messages regularly. In this situation, it is very easy to delete some messages that you really want by accident. If you happened to come across this situation, you may be interested in the following contents.
Is it possible to recover deleted messages from iPhone 4/4S/5?
When you search for the solution from Internet, you will find that many people say it is impossible to get back the deleted messages without backup. Do you believe it? If so, please take that concept away from now on. No matter how you lost messages from your iPhone 4/4S/5, there is still a chance to recover them, even if your iPhone is lost.
How to undelete iPhone 4/4S/5 text messages?
As we know, every time you sync iDevice with iTunes, it will automatically make a backup of your iDevice contents including photos, SMS, reminders, contacts and more. Therefore, as long as you have ever synced your iPhone 4/4S/5 with iTunes, you can get the lost messages from iPhone 4/4S/5 backup files created by iTunes. Sounds greats, isn’t it?
To restore lost messages from iTunes backups, you need:
Do not connect your iPhone 4/4S/5 to iTunes again until the messages are recovered. Otherwise, the old backup file will be overwritten by the current content on your iPhone 4/4S/5. Once it happens, the deleted messages will be gone forever.
In addition, iTunes backup files cannot be used and opened directly on Mac and iDevice. The backup files location is “~/Library/Application Support/MobileSync/Backup”. In Finder, press “ALT/Option” on your keyboard and click “Go” from menu bar, you will see “Library” option. Choose it and then you can find the backup files.
How to use iTunes backup files to restore deleted messages?
Data Recovery for iTunes can get back your lost messages, photos, contacts and more on your iPhone 4/4S/5 from iTunes backup files. If you accidentally lost your iPhone 4/4S/5 or deleted some messages off iPhone 4/4S/5, with this recovery utility, you can restore them at ease. No need to connect the device! No need to open iTunes!
Read more : http://www.total-data-recovery.com/MacOSX/iTunes/iPhone.SMS.Recovery.php
How to recover iPhone lost data from iTunes backup files? - YouTube
abcmac83
Postova:  67
Re: How to Recover Deleted text SMS from iPhone 4/4S/5?
Postod EmmaAustin » 25.02.2014 12:09
I know the stadard deletion on iPhone handset can't actually delete the messages. Some advanced recovery tool can retrieve them in some way. So when I decided to resell my iPhone 4, I searched and founded that there are many third-party software on the market. One of my friend told me that try the Myjad iTunes Backup Extractor. I used it with the highest data-erasing level, so it suprisely worked. If you want to recover deleted text messages on iPhone, you can just a try.
Check more form here:
http://www.myjad.com/recover-iphone-sms.html
EmmaAustin
Pridružio se:  25.02.2014 12:08
Postod Dindyr2 » 12.04.2014 9:38
If your iPhone data are indeed gone, I would suggest you try using iTunes in order to restore your iPhone data (including sms)from the last time you last sycned your iPhone with your iTunes. Here is about how to recover deleted text messages from iPhone.
Here are two easy methods to recover data from old iPhone :
One. Recover data from iPhone via iTunes.
Two. Recover iPhone Data without Backup by using third party iPhone Data Recovery Software
Hope it helps.
More Tips:
How to Recover Deleted Photos from iPhone
How to Restore iPhone Contacts
how to recover deleted videos from iPhone
Dindyr2
Pridružio se:  12.04.2014 9:15
Postod Coni21 » 14.05.2014 10:00
A lot iPhone users are asking for help to recover deleted messages which they deleted accidentally or intentionaly. General speaking, it's impossible to recover deleted data from iPhone. But now some data recovery program have succeed to create iPhone data recovery tool that could help. It works very well on iPhone 5s/5/4S/4/3GS.
How to Recover Lost Messages on iPhone
How to Recover Data from Dead iPhone
[Solved]iPhone Stuck in Recovery Mode
Coni21
Postova:  2
Pridružio se:  14.05.2014 9:20
Postod Jentera1 » 14.05.2014 18:54
Accidentally deleted messages from iPhone? Lost or broken your iPhone? Failed iOS update cause lost messages on your iPhone? If you have ever synced your iPhone with iTunes on computer, iPhone Data Recovery is a good iOS Data Recovery program can help you recover lost or deleted iPhone messages from iTunes Backup files, or retrieve deleted text messages on iPhone directly.
The iPhone SMS Recovery offers you the fast & simple-to-use way to extract and recover your iPhone data such as video, photo,Message, contact, note, calendar event, call history, voice memo, camera roll, voicemail, Safari bookmark and App Data etc from iTunes Backup. It provides an easy way to restore SMS Messages, Contacts, calendar events, notes, bookmarks.
how to recover deleted photos from iPhone
how to retrieve contacts from iPhone
how to recover deleted video on iPhone
Jentera1
Pridružio se:  14.05.2014 18:32
Postod Alrenly11 » 08.07.2014 8:22
Lost photos, text messages, contacts and other important data on your iPhone, iPad or iPod touch? And you even have not backed it up on iTunes? Or the occasion is your iOS is crashed, broken or lost, how can you recover deleted photos without your iPhone, iPad or iPod touch? Don't worry, here we provide you powerful iOS Data Recovery to deal with the problems.
iOS Data Recovery is a wonderful and powerful recovery software helping you to retrieve all types of data from your iOS device, including messages, contacts, photos, videos, notes, etc.
More information:
How to Extract Data from iPad Backup
How to Exit DFU Mode Safely with Your iOS Device
Alrenly11
Postova:  5
Pridružio se:  08.07.2014 3:53
