Media coder aspect ratio problem
Postod dannyd » 23.12.2010 14:45
Imam problem sa videom koji je dobijen iz premiere-a, kada ga konvertujem u media coderu da bi ga stavio na youtube...problem je sa aspect ratiom, nikako da dobijem 16:9 dar kao sto je ovaj originalni video...Ovo je original u mediainfo:
Complete name : D:\proba.avi
Format : AVI
Format_Commercial_IfAny : DVCPRO
File size : 72.4 MiB
Duration : 19s 920ms
Overall bit rate : 30.5 Mbps
Writing application : Lavf52.23.1
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Bit rate : 24.4 Mbps
Width : 720 pixels
Height : 576 pixels
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Scan type : Interlaced
Bits/(Pixel*Frame) : 2.357
Stream size : 68.4 MiB (94%)
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 19s 919ms
Bit rate : 1 536 Kbps
Bit depth : 16 bits
Stream size : 3.65 MiB (5%)
Interleave, duration : 1 ms (0.03 video frame)
A dobijam ovako nesto svaki put:
Complete name : D:\proba.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 6.09 MiB
Overall bit rate : 2 565 Kbps
Encoded date : UTC 2010-12-22 12:39:42
Tagged date : UTC 2010-12-22 12:39:42
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 2 500 Kbps
Maximum bit rate : 3 695 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Standard : PAL
Bits/(Pixel*Frame) : 0.241
Stream size : 5.94 MiB (98%)
Title : Imported with GPAC 0.4.6-DEV (internal rev. 5)
Writing library : x264 core 110 r1804 e89c4cf
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=100 / keyint_min=10 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2010-12-22 12:39:43
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 19s 818ms
Bit rate : 59.7 Kbps
Maximum bit rate : 64.2 Kbps
Stream size : 144 KiB (2%)
Encoded date : UTC 2010-12-22 12:39:43
Podesavanja su prema vodicu za h.264 u media coderu, sve je isto kako god da je podeseno na kartici Picture, keep display ar, keep pixel ar, set display ar 16:9, set pixer ar 1.42...
Isto se desava i ako je xvid cedec a avi container...
dannyd
Postova:  37
Re: Media coder aspect ratio problem
Postod Video Majstor » 23.12.2010 22:29
Velika je mogucnost da si sve dobro podesio samo što neki plejeri i kodeci koji učestvuju u puštanju videa jednostvano ignorišu podatak o aspect ratiu. Do pre nekoliko godina ni jedan codec nije prepoznavao aspect ratio kod AVi fajlova vec je uvek podrazumevano da je PAR 1:1 i tako se slika prikazuje. Sada je situacija nesto bolje, mislim da nekoliko najpopularnijih codeca imaju sada ubaceno i citanje oznake za aspect ratio.
Koliko znam ne možeš u isto vreme zadati i DAR I PAR. Zadaje se samo jedan od njih a onaj drugi se izračunava.
Da li si ti zadavo oba?
Na priemr ako je zadat DAR onda se PAR izračunava:
SAR = 720:576 = 5:4 = 1,25
DAR = 16:9 = 1,77
DAR = SAR x PAR
PAR = DAR/SAR = 1,77 / 1,25 = 1,42
U mediacoder mislim da moraš zadati PAR u obliku celih brojeva. Znači 1,42 je u stavru 17/12
17 / 12 = približno 1,42
Pokušaj ovako još podesiti
"Set Pixel AR 0 17:12"
i ostavi tako, nemoj ponovo podešavati DAR nakon toga.
Ako i dalje ne bude prepoznao onda verovatno ti muxeri koji su ugrađeni u mediacoder ne reaguju na taj podatak...
Srećom svi plejeri mogu da se nameste na 16:9 aspect ratio.
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Je li to video snimljen nekom kamerom?
Postod dannyd » 23.12.2010 22:55
Video Majstor je napisao:Je li to video snimljen nekom kamerom?
Jeste, snimano je kamerom sony xdcam ex 1080i, pa exportovano iz premiera u pal widescreen...
Video Majstor je napisao:Koliko znam ne možeš u isto vreme zadati i DAR I PAR. Zadaje se samo jedan od njih a onaj drugi se izračunava.
Nisam zadavao oba, samo jedan ili drugi ali je rezultat isti u oba slucaja...
Video Majstor je napisao:U mediacoder mislim da moraš zadati PAR u obliku celih brojeva. Znači 1,42 je u stavru 17/12
Kada sam zadavao PAR kucao sam 1,42 i enter i on je sam pretvarao broj 1,42 u 71:50 sto je isto 1,42 tako da mislim da sam to dobro zadao...
Video Majstor je napisao:Ako i dalje ne bude prepoznao onda verovatno ti muxeri koji su ugrađeni u mediacoder ne reaguju na taj podatak...
Mislio sam na youtube da stavim video i zato mi ne valja da ostane ovakav dar 5:4 koji dobijem svaki put, jer je takav na internetu i ne moze se promijenit u 16:9 na youtubu :(
dannyd
Postova:  37
Postod dannyd » 23.12.2010 23:11
Probao sam da dobijem iz media codera ciste video i audio zapise bez muksovanja, pa mux u MeGUI-u mp4 i isti je rezultat :(
dannyd
Postova:  37
Postod Video Majstor » 24.12.2010 8:27
Na žalost YouTube potpuno ignoriše podatak o aspect ratiu i uvek računa da je Square pixels (PAR=1:1). Zbog toga se za YouTube često mora posebno pripremati video.
Kada uaplodujes video YouTube ce ga smanjiti na rezoluciju 640x360 a sledeca veća je mislim 848x480
Znači pošto pripremaš za YouTube najbolje bi bilo da podesiš u MediaCoderu 848x480. YouTube će u tom slučaju ostaviti dve rezolucije 480p (ista rezolucija) i 360p (640x360) koje se mogu birati u YouTube plejeru. Tako ćeš najmanje izgubiti na kvalitetu.
U muxerima takođe moraš da ukucaš aspect ratio i taj aspect ratio će posebno biti upisan ucontainer fajlu. on bi trebao imati prednost (samo što neki codeci i ti ignorišu).
Ne mroas da dobijas ciste zapise. Mozes i uobicajen container fajl da ponovo remuyujes u istim tim alatima. Znaci mozes remuxovati bilo koji fajl u .MKV sa MKVtooolnix-om i da ukucas u njemu aspect ratio 16:9 ili u .MP4 sa YAMB-om.
Postod dannyd » 24.12.2010 16:07
Video Majstor je napisao:Ne mroas da dobijas ciste zapise. Mozes i uobicajen container fajl da ponovo remuyujes u istim tim alatima. Znaci mozes remuxovati bilo koji fajl u .MKV sa MKVtooolnix-om i da ukucas u njemu aspect ratio 16:9 ili u .MP4 sa YAMB-om.
Tako sam i uradio, onaj fajl (.mp4) sa nekorektnim AR iz mediacodera sam remuxovao u MKVtooolnix-u i tamo podesio ponovo ar na 16:9 i dobio .mkv sa dar-om 16:9 sto je i bio cilj :)
Video Majstor je napisao:Znači pošto pripremaš za YouTube najbolje bi bilo da podesiš u MediaCoderu 848x480. YouTube će u tom slučaju ostaviti dve rezolucije 480p (ista rezolucija) i 360p (640x360) koje se mogu birati u YouTube plejeru. Tako ćeš najmanje izgubiti na kvalitetu.
Podesio sam u mediacoderu na kartici picture, resize na 848x480 i pixel ar na 1:1 i dobio fajl .mp4 koji sam remuxovao kako sam gore naveo, ali mi na youtubu ima samo opcija plejera 360 za gledanje videa, ne i 480, dok je bila u funkciji kad sam uploadovao original video 720x576...
dannyd
Postova:  37
Postod Video Majstor » 25.12.2010 10:43
Odlično!
Znači muxer je ispustio taj podatak. Nadam se da će to popraviti u narednim verzijama mediacodera.
MediaCoder isti koristi MKVmerge koji koristi isti muxer kao MKVtoolnix, samo nije omogućeno mnogo komandi da se za njega ukucaju. ...Može u stvari i sada da se to postigne ali moraju se ručno ukucavati CLI komande... (što ja ne volim).
Hm. Dobo da si rekao. Prilično je nejasno šta podrazumevaju pod tim 480p najverovatnije misle na američki NTSC 720x480 ili evropski PAL 720x576...?!
:unknown:
Za sada ti onda preostaje da resajzujes u 1280x720 pa će youtube ponuditi tri rezolucije: 360p, 480p i 720p.
