"8" - (2010) kratak film
Postod Inter » 28.07.2012 19:34
Zdravo svima!
Zarko me je angazovao da postavim moj poslednji kratak film ovde:
Pozdrav!
http://www.imdb.com/title/tt1592502/
Inter
Re: "8" - (2010) kratak film
Postod Video Majstor » 30.07.2012 19:02
Hvala što si okačio film!
Stvarno je dobar! :winner: Definitivno, za moj ukus, bi ga svrstao među najbolje kratke filmove koje sam gledao.
Posebno cenim filmove koji su dobri a ne zahtevaju skup budžet. Zato mislim da je ovaj film odličan da posluži kao uzor početnicima. Nadam se da će inspirisati naše filmmakere amatere da više snimaju.
:clapping:
Inače, za film sam slučajno saznao jer sam naleteo na ovu stranicu: http://www.filmindustrynetwork.biz/serb ... -odds/3886
Iain: Do you have any advice you can give to filmmakers?
Acim: Pffff, I’m really not so experienced that I can give any very useful advice, but basically it should be a simple strategy. You just have to know what do you want to make, and why, and if you truly believe in it – that will hopefully give you enough energy to just keep pulling like a mule until you do it. And of course, always try to be yourself, that’s the most important. That will give your personal stamp on your film or showreel. You will run onto hundreds of advices, you will get confused as many times, and you will meet people that don’t like your work, it is normal and you just have to accept it. And no matter what is your nature, try to put your ego in the drawer and not use it too much, and be able to listen and speak to everyone around you, you will be surprised how much you can learn from so many people that you never really imagined that could give you an advice, idea or inspiration. And what a friend of mine Merlyn says, never forget that before everyone else, you have to like your film. Then it is truly yours.
Postoji li šansa da ustupiš scenario ovog filma na čitanje? Zanima me baš kako izgleda jer ovaj film nema dijaloga a meni baš takvi često padaju na pmet.
Postod Inter » 01.08.2012 13:04
Evo ga scenario, nisam siguran da li je poslednja verzija, ali to je to.
https://rapidshare.com/files/2996005933/8-by%20Acim%20Vasic%20(script%20and%20poster).zip
PS A da li nekako moze da se registrujemo na ovom forumu, pa da nas automatski obavesti kada je neko uradio Reply ili poslao poruku?
Inter
Postod bytefx » 01.08.2012 13:40
Super, svaka cast!
bytefx
Postova:  28
Pridružio se:  09.09.2010 22:26
Postod Video Majstor » 02.08.2012 3:53
Hvala mnogo!
Skinuo sam. Poslužiće mi definitivno. Kada budem koncentrisan baš ću da ga pažljivo uporedim sa filmom da vidim kakav je odnos trajanja filma i trajanja čitanja i tako to...
Naravno da je moguće da se registrujete.
Sad ne znam da li si pokušao registraciju pa imao problema ili se samo raspituješ o mogućnostima...
U sluačju problema sve se može rešiti. Samo napiši šta je problem u poruku i otkloniću.
Može. Kada pišeš post ispod ima opcija "Pošalji mi email kad neko odgovori"
a takođe je u slučaju privatnih poruka po defaultu podešeno slanje obaveštenja na email.
Dodatna prednost registracije je što možeš da popuniš polja profila. Osmišljeno je tako da možeš da tu staviš "filmmakerski CV" u suštini. Onda dalje postoji potncijal da putem tih informacija neko poželi da te unajmi ili sarađuje...
Nema obaveza za registraciju i ta polja profila ali mogućnosti su tu.
