Play Phantom 4 Pro/DJI Inspire 2 4K H.265 on QuickTime
Postod laurali » 20.04.2017 11:24
The new Phantom 4 Pro and DJI Inspire 2 can record 4K H.265 videos. If you have got some 4K H.265 videos from Phantom 4 Pro/DJI Inspire 2, you may want to play them on QuickTime. But H.265 codec is not friendly with QuickTime. So how to play Phantom 4 Pro/DJI Inspire 2 4K H.265 videos on QuickTime player? Read on to get the solution.
It’s possible to make Phantom 4 Pro/DJI Inspire 2 4K H.265 files playable in QuickTime as long as you decode H.265/HEVC to QuickTime readable format. To get the work done, you need help from the best H.265 file converter- Pavtube HD Video Converter for Mac.
As a professional H.265 converter, it can help users to convert Phantom 4 Pro/DJI Inspire 2 4K H.265 to QuickTime playable MOV, convert H.265 to H.264 MP4 video on Mac (including macOS Sierra) without quality loss. It also can convert AVI, MKV, MP4, MXF, XAVC etc to QuickTime player supported formats for playing. Besides, it also supports converting H.265 files to other common videos including MPEG-4, MPEG-2, DivX, XviD, WMV, MKV, etc to meet your different needs. Plus, if you need, with this program you can fast convert non-H.265 videos to H.265 seamlessly. Download the program to start the H.265 to QuickTime conversion task.
Main features:
  • Support H.265/HEVC Encode & Decode
  • Convert 250+ video and audio formats in SD/HD/4K
  • Compress 4K H.265 to 1080p video with high quality
  • 160+ ready presets for iPhone, iPad, QuickTime, Apple TV, Game Console, TV, video editors, etc.
  • Customize the output resolutions to any size the users want
  • Batch conversion and super fast conversion speed
Free download the 4K H.265 to QuickTime video converter for Mac
How to Open and Play Phantom 4 Pro/DJI Inspire 2 4K H.265 videos in QuickTime Player
1. Load 4K H.265 footage
Launch the 4K H.265 to QuickTime Converter macOS Sierra. Drag & drop 4K files to the program directly and your files would be added instantaneously. Or you can head to the “Add” button to locate the 4K H.265 videos you want to add.
2. Select output format
Click format you choose MOV as target format. This video app offers the QuickTime Movie Format for you. Or, you can also choose “Common Video -> MOV – QuickTime (*.mov)” as the output format.
3. Tweak video, audio settings
Click “Settings” button; you can adjust video and audio settings, including codec, aspect ratio, bit rate, frame rate, sample rate, and audio channel. To down-convert Phantom 4 Pro/DJI Inspire 2 4K H.265 to 1080p video for easier playback, you just need to adjust video size to 1920*1080.
4. Start 4K to QuickTime conversion
Hit the “Convert” button to let this smart converter start encoding Phantom 4 Pro/DJI Inspire 2 4K H.265 to QuickTime .mov on Mac. When the conversion is done, you can play the converted 4K videos in QuickTime player on macOS Sierra without hassle.
Read More:
DJI Phantom 4 Pro Review | Downscale DJI Inspire 2 4K to 1080P
Import DJI Inspire 2 H.265 to FCP X | Final Cut Pro X Edit DJI Phantom 4K video
Blu-ray to QuickTime| MKV to QuickTime | MXF to QuickTime
AVCHD to QuickTime | Edit DJI 4K H.265 video in Windows Movie Maker
laurali
Postova:  18
