Using Gear VR, HTC Vive, Oculus Rift to watch Gopro Videos
Postod CaitlinAaron » 13.01.2017 4:31
Convert VR Videos from Gopro camera for playback on VR Devices
Convert videos from Gopro to be compatible with VR devices, that’s the key point to easily watch GoPro VR videos on Gear VR, HTC Vive, Oculus Rift, etc.
There is also a growing collection of 360-degree VR videos available on the Web for you to watch. However, if you have other video shootings like Gopro VR video, is it possible to put these VR video from Gopro into VR devices for playing with ease?
Why GoPro VR Player won't play VR video from Gopro?
GoPro VR Player is a 360-degree video & photo player for computers at their original quality. By default, GoPro VR Player will choose the best default video plugin according to your OS and if you are using an Oculus or not. GoPro VR Player will not play some Gopro videos due to decoding issue.
Fortunately, you can change video plugin through the Preferences menu, which will directly affect GoPro VR Player video decoding abilities. GoPro VR Player will use a different video backend according to this setting after you restart the player to apply it. Then tap Reset to "Reset to suggested settings" in the start menu.
How to Convert VR Videos from Gopro for Playing on VR Devices
GoPro cameras are the best fit for capturing 360 degree videos. With the help of special camera holders and some fancy video stitching software, making the best quality high-definition 360 degree video is possible. After shooting with GoPro and do some editing job, how to get a virtual reality experience with your VR video from Gopro on a VR device like HTC Vive, Samsung Gear VR and Oculus Rift?
Here's why Dimo Video Converter Ultimate is such a wonderful tool to have in your arsenal when you are going to be making VR videos and regularly having to preview Gopro VR videos, convert them to be compatible with various VR devices and even sharing them on all devices that you wish to watch them on.
Get the Best VR Video Converter:
* Convert distinctive audio/video records in the meantime, fundamentally rearranged the audio/video you have to convert to the program.
* It can be wholeheartedly used to edit or play videos on various devices (such as HTC Vive, Samsung VR devices and Oculus Rift, etc.) as required.
* Create 3D modes like Top-bottom, Side-by-Side which can be played on VR devices perfectly
* Intel and NVIDIA GPU hardware animating grows conversion speed.
* It moreover can share videos from the computer and even make ISO files.
It is perfectly compatible with Windows 10/8/7/XP/Vista & macOS 10.12 Sierra, macOS 10.11 El Capitan, macOS 10.10 Yosemite, 10.9 Mavericks, 10.8 Mountain Lion and 10.7 Lion. For mac users, please turn to Dimo Video Converter Ultimate for Mac.
Win Mac
Guide: Convert GoPro VR video to SBS/TB 3D Video for VR devices
One: Run the GoPro VR video converter and click "Add File" button to load your media sources.
Two: Tap on "Select Format" bar and basically "Format > Video > MP4" is a universal format for most VR devices. Plus, there are optimized presets for Samsung Gear VR, HTC Vive, Oculus Rift, etc from "Device > VR"; choose a proper one as you need.
Tip: Click Settings button to adjust video/audio parameters like video resolution, bitrate, audio codec, audio channel. According to my experience, anything over 720p does nothing but turn battery energy into heat, due to the screen resolution.
Three: The 3D Video Converter program provides three kinds of 3D effects, you can choose one that match your VR devices, such as Side-by-side (Left-Right) or Top-Bottom.
Before converting your videos, you can preview and edit them as needed. Click the "Start" button to get GoPro VR video compatible with your VR devices. After the conversion, click "Open" button to quickly locate the generated media file. Now you can transfer the converted videos to play with VR devices easily.
Related Articles:
Source: How Can I Watch GoPro Videos on VR Devices
CaitlinAaron
Postova:  31
Korisnici koji su trenutno na forumu: Google [Bot] i 22 gostiju
