Transcode normal 2D/3D movies to PS VR
Postod CaitlinAaron » 26.12.2016 13:43
How to play downloaded 2D/3D movies on PS VR
This guide will introduce a way to transcode normal 2D/3D movies to PS VR (player) supported 3D SBS video for smoothly play on PS VR in 3D effect.
Can't find your need VR videos or failed to play downladed VR videos on your immersive VR devices like PSVR? In this article, you are going to learn how to convert 2D/3D movie files to watch on PlayStation VR within a few clicks.
How to watch supported 2D/3D/VR videos on PS VR?
Be sure to activate "VR Mode" from the Media Player's Option menu, and then select 360 clips of your choice from a connected server or USB device. Both video and still 360-degree content are supported, as long as they in MKV, AVI, MP4, MPEG2 PS, MPEG2 TS, AVCHD video formats, or JPEG, BMP, PNG image formats. However, each must be recorded in "equirectangular" format by a 360-degree camera in order for PS4 to recognize the file.
As you can see, the supported video file formats for PS VR (PS4 Media Player) are very limited. If you have some videos in PSVR incompatible formats, for example, FLV, M2TS, WebM, VOB, MXF, Tivo, etc. how can you play them on PSVR? Take it easy. All you need to do is to change video format using a 3D video converter.
Here Dimo Video Converter Ultimate is a top-notch PSVR video converter software app that capable of speedily ripping any Blu-rays in 2D/3D, stardard DVD and convert 2D/3D movie files to any type of 3D you want for VR headsets including Playstation VR, HTC Vive Gear VR, VR One,Google Cardboard, etc. or 3D Players, 3D TV for watching amazing 3D movies.
Besides, it also allows you to extract melodious soundtracks or special audios from 2D/3D movies for PlayStation VR audio experience with delivering high audio quality. The Mac version- Dimo Video Converter Ultimate for Mac is also to convert 2D/3D movies to PSVR on Mac (macOS Sierra included).
Windows | Mac
Steps to convert unsupported 2D/3D movies to PSVR
Step 1. Add Video Files
Open this VR video converter for PSVR. You can directly use the "Add File" button to load the ordinary video that you wish to convert into PSVR format. Or it is also available to drag and drop video from PC folder into this program. Double click on the file and you can get a preview on the converter.
Step 2. Select 3D SBS mode
In order to make converted videos works perfectly with your PSVR, you need to set a video mode according to your video type. Click "Edit" and turn to "3D" tab and select Left/Right as the output video mode. Then you can turn to "Adjust" to crop and get the imported videos cropped as you want. If you encode the corrected aspect direct into your movie file you could plug your PS4 direct into the PlayStation VR for sbs 3D playback.
Step 3. Select PSVR as Output Format
Click the "Select Format" bar and you can choose "Format -> Video -> MP4" as the target format. This format can be played well on PSVR. Also you can select "Format -> Audio -> FLAC" as output audio format for enjoying.
Step 4. Customize Video Settings
Before starting the conversion, click the "Setting" icon on bottom right corner where you are able to adjust the video/audio settings like encoder, resolution, frame rate, bit rate and so on. Also it is possible to change output folder path as per your need by clicking "...".
Step 5. Start to Convert Normal 2D/3D video to PSVR
Click on "Start" button to accomplish the process of 2D/3D video to PSVR conversion. And this virtual reality video conversion will be finished in a short time. After the conversion, click the "Open" button to locate converted files, and then you can import the output .mp4 files into PlayStation VR for playing with the best quality including "look all around you" 3D vision and "hear things behind you" stereo sound.
Find more Christmas Giveway and contact us if you have any issues.
Related Articles:
CaitlinAaron
Postova:  31
