How to play 3D Blu-ray on Oculus Rift without limitations?
Postod CaitlinAaron » 30.11.2016 8:28
This tutorial show you how to rip the 3D Blu-ray to 3D MP4 for play on your Oculus Rift with the side-by-side 3D effects.
With 3D display and tilt sensors, Oculus Rift VR headset is not only designed for gaming, but also be used for movies as well. Step into Rift and watch an immersive VR movie, jump to a destination on the other side of the world. The screen looks huge and so do the pixels. Since now VR sources are so limited, and in 2016 it's not legally buy and download 3D movies in any resolution, then is it possible to watch purchased 3D Blu-ray with Oculus Rift (including the latest development kit for the Oculus Rift- DK2) while lying in soft sofa for a true theater entertainment instead of going to cinema?
Of course Yes! To play 3D Blu-ray on Oculus Rift without limitations, many users are looking for VR players to make Rift (DK2) to afford 3D Blu-ray movies. However, as far as I know, most vr player apps can only play side by side or top-bottom video, while most Blu-rays are in the "frame packed" format. Worse still, Oculus Rift doesn't support Blu-ray drive attaching.
In this case, if you wanna enjoy 3D Blu-ray movie on Oculus Rift freely, you'd better find a 3D Blu-ray ripping tool to help you convert a frame packed Blu-ray to a SBS/TB which are supported by Oculus Rift natively. In the market, 3D video converter software programs vary, so you might be confused when you have to choose one.
If so, you are recommended Dimo Video Converter Ultimate. It is rated as the best solution out there to watch 3D Blu-ray movies on Oculus Rift (DK2). The program is easy to use and fully supports new released Blu-ray discs like Game of Thrones seasons 6, Deadpool, etc.. With it, you can easily rip 2D/3D Blu-ray, DVDs to MP4/MKV/AVI/WMV with 3D SBS/TB effect for VR headsets like Oculus Rift, HTC Vive, Homido VR, VR One, PSVR, etc. instead of going to cinema.
Plus, this 3D Blu-ray ripping software offers fast speed, excellent output quality, and even entitles users to freely customize the output videos by changing video/audio parameters, trimming, cropping, adding video effect/watermark freely. The equivalent Mac version is Dimo Video Converter Ultimate for Mac, which can help you convert 3D Blu-ray on Mac OS X (macOS Sierra included) with ease. Just download the right version and follow the step-by-step guide to rip and play 3D Blu-ray films on Oculus Rift (DK2) with 3D effect.
How to rip 3D Blu-ray movie for Oculus Rift
One: Insert your 3D Blu-ray disc into your BD drive, run the 3D Blu-ray ripping software and click "Add Blu-ray" icon to load your movies.
Tip 1: The Blu-ray to Rift Converter allows you to select desired audio tracks from source Blu-ray movies. You can achieve the selections via opening the drop-down boxes of "Audio tracks" in each loaded Blu-ray file.
Two: Go to the Format bar and follow the path "Device > VR > OculusRift" for ripping 3D Blu-ray to H.264 MP4 video. This Blu-ray ripper for rift offers preset specific profiles for easy and direct Blu-ray to Oculus Rift conversion.
Tip 2: If you like, you can go to "Settings" page to adjust codec, aspect ratio, bitrate, frame rate, sample rate and audio channel as you like. For ripping 3D Blu-ray to view on Oculus Rift (DK2), the created 3D videos for the Cinema app should be in 720p (1280*720) with a higher bitrate around 5mbit/s. Higher resolutions for the specific format doesn't make the quality better but are a waste of power and battery life.
Three: After you have set output format, you could even click "Edit" button to open the Video Editor Window. As you see, you can turn to "3D" tab and choose "Left-Right" or "Top-Bottom" 3D mode. Also, you can trim, crop or adjust the video effect with the built-in video editor to get the very part and effect of the movie you want.
Four: Finally click the "Start" button under the preview window to begin converting 3D Blu-ray to Oculus Rift 3D MP4 format you select. This converter can achieve 6X faster Bluray to Rift conversion with the help of NVIDIA CUDA, AMD APP and Intel Quick Sync graphics acceleration technologies. The encoding process will be finished soon. After conversion, you can find the converted 3D Blu-ray files under "Open" panel.
Now just import 3D Blu-ray movies to watch with Oculus Rift as you wish.
Which Video Formats Are Supported by Oculus Rift
2D videos: MKV, MP4, AVI, WMV
3D movies: Side-by-side, Top-Bottome
360-degree videos
More Articles:
CaitlinAaron
Postova:  31
