Convert H.264 Files to Pinnacle Studio 14/15/16
Postod Andyeric » 25.09.2015 7:49
Summary: Problems occurred when importing H.264 files to Pinnacle Studio. You can fix importing issues by reading the following guide.
H.264 is not a stranger to most people, essentially all of the electronic digital products now support this encoding format. And various extensions of its capabilities have been added in subsequent. The intent of the H.264 project was to create a standard capable of providing good video quality at substantially lower bit rate than previous standards, without increasing the complexity of design so much that it would be impractical or excessively expensive to implement.
Pinnacle Studio supports a wide rang video formats although. It is pretty picky with the codec of what it’ll accept. As far as I know Pinnacle Studio doesn’t like H.264 files. If you want to import H.264 to Pinnacle Studio flawlessly, I recommend you to convert H.264 to a more editable format for Pinnacle.
The video format that Pinnacle Studio support:
AVI File–(.avi)
MPEG Files–MPEG-1, MPEG-2 SD & HD, and MPEG-4 – (.mpg, .mpeg, .mod, .mp2, .mp4, .m2ts, .mts, .m1v, m2v. mpv)
WMV Files- (.wmv)
DIVX–(.avi)
MOD (JVC Everio cameras)–(.mod)
3GPP Files–(.3gp)
TOD Files–(*.tod)
AVCHD–(.m2ts, .mts)–Requires Ultimate or Ultimate Collection
Comparing with others, Pavtube Video Converter has the strong ability of transcoding all different videos. With a faster conversion speed and easy operation, it can support most hot media devices and editing programs. Also, I’m sure you’ll be satisfied with some other functional items there.
How to import H.264 files to Pinnacle Studio 14/15/16 for editing?
Step 1: Download and install the program. Click "Add video" on the main interface to load H.264 files to the program. You can also drag the files to the program’s window list directly. This program can also support the batch video clips.
Step 2: Select the right formats for editing in Pinnacle Studio. Here we suggest you to go to the "HD Video" list, you will get the "AVI HD Video (*.avi)"as the best output.
Step 4: With all the preparations work done? Why not go back to the main interface to click the "Convert" button to get the work started?
Conclusion: Once the conversion is finished, click "Open" to quickly find the converted files. Then, Pinnacle Studio 14/15/16 will recognize, catalog, play and stream them just fine.
Facebook Weekend Promotion Here : Learn More: http://bit.ly/1hmOn34
More related tips:
Source: http://pc-mac-compatibility-issues.blogspot.com/2015/09/import-h264-to-pinnacle-studio.html
