Insert Panasonic FZ300 4K Videos to FCP/Premiere/Avid
Postod Andyeric » 25.09.2015 7:40
Insert Panasonic FZ300 4K Videos to FCP/Premiere/Avid for Editing
Summary: If you have Panasonic FZ300 4K to FCP/Premiere/Avid importing issues, this article will shed you some lights on how to make NLEs work with FZ300 4K recordings.
Panasonic FZ300 is a new 4K camcorder for us, which can shoot high-resolution 4K QFHD video in MP4 format. As new to Panasonic FZ300, you may concern the Panasonic FZ300 4K workflow like how to import Panasonic FZ300 4K video to FCP/Premiere/Avid for editing.
Generally, Final Cut Pro, Adobe Premiere Pro, Avid Media Composer can’t support MP4 format well which is not an ideal format for editing. Plus, expect for Final Cut Pro X, Adobe Premiere Pro CC, the old version FCP 6/7, Premiere Pro CS4/CS5/CS6 can’t support 4K video. To edit FZ300 4K video in FCP/Premiere/Avid flawlessly, an ultimate solution is to convert FZ300 4K MP4 files to ProRes MOV for FCP, MPEG-2 MPG for Premiere, DNxHD MOV for Avid.
To convert FZ300 4K MP4 to FCP/Premiere/Avid friendly format quickly and easily, a professional and easy-to-use 4K video converter is the key. Here you can depend on Pavtube Video Converter for Mac (review). It provides hundreds of output format presets for 4K videos, such as DNxHD for Avid, Apple ProRes for Final Cut Pro, MPEG-2 for Adobe Premiere, Apple InterMediate Codec for iMovie, etc. Besides, this 4K converter is also available to customize the output resolutions to any size like 1080p, 2K, 4K as users want. It will save you both time and trouble, and all you need to do is to drag the result videos for prompt editing.
How to convert FZ300 4K videos to FCP/Premiere/Avid?
Step 1: Download and have a quick installation. The trial version will have a watermark on your converted files. Except for that, there are no time limitation, no virus, and no unnecessary bundle apps while downloading. After that, click "Add Video" button to load your FZ300 4K MP4 videos. You can load several files at once thanks to "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Final Cut Pro>>Apple ProRes codec", including ProRes 422, ProRes 422 (HQ), ProRes 422 (LT), ProRes 422 (Proxy) and ProRes 4444. Choose the proper one you want. Here, we suggest you to choose "Apple ProRes 422 (*.mov)" as the best output format.
Tips: For editing FZ300 4K MP4 in Premiere, choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)".
For editing FZ300 4K MP4 in Avid, choose "Avid Media Composer>>Avid DNxHD (*.mov)".
Step 3: Click the "Settings" button and set proper video/ audio parameters. My advice is to set the video size, bit rate and fame rate to be exactly as the footages so that you will suffer least quality degradation. If you would like to use default settings, simply skip this step.
Step 4: After all necessary settings, hit the "Convert" button to start the conversion work.
Conclusion: After conversion, you can get the generated files by clicking "Open" button. Then, you can transfer FZ300 4K videos to FCP/Premiere/Avid without any hassles.
More related tips:
Source: http://mediaconverting.blogspot.com/2015/09/import-fz300-4k-videos-to-fcp-premiere-avid.html
