Convert Panasonic MTS/M2TS to MP4 on iPad Workflow
Postod Andyeric » 25.09.2015 7:22
Summary: Transferring videos to iPad could be a big headache. This guide aims to tell you how to play MTS/M2TS recorded by Panasonic on iPad.
"It was that I record some MTS/M2TS files with Panasonic. Since I got a new iPad, I prefer to enjoy the files on my new tablet anywhere anytime. However, something wrong when I wanna put my MTS/M2TS files into iPad. Any good measures I can solve that problems well?"
iPad supported video formats:
H.264 video format: Up to 1080p, 60 frames/second, High Profile level 4.2 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats.
MPEG-4 video format: Up to 2.5 Mbps, 640 x 480 pixels, 30 frames/second with AAC-LC audio up to 160 Kbps/ channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats.
Motion JPEG: Up to 35 Mbps, 1280 x 720 pixels, 30 frames/second audio in ulaw, PCM stereo audio in .avi file format.
iPad supported audio formats:
AAC and HE-AAC (bitrate from 8 to 320 Kbps)
Protected AAC (DRM copy protection used on the iTunes Store)
MP3 (8 to 320 Kbps) and MP3 VBR
Audible (formats 2, 3, 4, Audible Enhanced Audio, AAX, and AAX+)
ALAC (Apple Lossless), AIFF and WAV
To make MTS/M2TS files compatible with iPad, Pavtube Video Converter should be your first choice since it can convert any videos to iPad supported formats. Compare with many other such video conversion tools, you will find this software is much powerful. Conversion could be easily achieved, but to keep the high quality will be much more difficult. Most such tools will supply new videos with much quality loss, but never will this Video Converter.
http://download.pavtube.com/video_converter/videoconverter_setup.exeSlika Slika
How to play Panasonic MTS/M2TS on iPad?
Step 1: Download and install the program. Click "Add video" on the main interface to load your original files to the program. You can also drag the files to the program’s window list directly. This program can also support the batch video clips.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "iPad". Choose "iPad Air HD Video (*.mp4)" as best output format.
Step 4: Specify output folder on your computer to save the output files. Click the "Browse" button to choose the path where you want to save the output files in. Click "Convert" button to finish converting MTS/M2TS to iPad compatible MP4 format.
Conclusion: Connect iPad to computer, start iTunes, and then import the converted file to iTunes for sync and transfer to iPad. Wait no more, just get this powerful iPad Video Converter now!
More related tips:
Facebook Weekend Promotion Here : Learn More: http://bit.ly/1hmOn34
Source: http://android-ios-tips.tumblr.com/post/128766101208/play-panasonic-mts-m2ts-on-ipad
