Tips for Casting AVI movie to Samsung TV for playback
Postod lauralily520 » 22.09.2015 11:08
[size="4"]Here is the solution supplied for you to play AVI on Samsung TV with the best quality. Read on.[/size]
Let's go to the point: if you want to play AVI on Samsung TV, what would be the best way to go about it? Just read on this article. We will share the tips and tricks for transferring AVI files to Samsung TV for HD playback in the simplest way.
As far as we know, Samsung TV doesn’t support AVI files. Before adding your AVI videos to Samsung TV via USB drive, what you need to do is to convert AVI to Samsung TV compatible format. And from Samsung TV official website we know that Samsung TV best video format is H.264 codec MP4 format. Here we recommend Brorsoft Video Converter to complete the AVI to Samsung TV conversion task.
This program works as the best video converter for Samsung TV. It can convert all kinds of AVI, MKV, MOV, VOB, FLV, WMV, MTS files to Samsung Smart TV, OLED TV, UHD TV, LED TV more supported video format. Plus, with the built-in video editor, you can also choose to trim, crop, add watermark to your original videos. If you are Mac users, please turn to Brorsoft Video Converter for Mac (Mavericks, Yosemite included), which has the same function as the Windows version. Download the software and study the step-by-step tutorial below.
Converting AVI to Samsung TV best video format
1. Import AVI video files
Launch the AVI file converter. Click "Add File" button to import the .avi files which you like to play on Samsung TV. This software supports batch conversion.
2. Set Samsung TV compatible format
Click the "Format" drop-down button to select Samsung TV more compatible H.264 MP4 video from the "Common Video" category.
Tip: Video, Audio settings
Before start the video conversion for Samsung TV, you can click the Settings icon and adjust the video bitrate, codec, frame rate, audio sample rate, etc parameters.
3. Start AVI to Samsung TV conversion
Click the "Convert" button to start converting AVI to Samsung TV more supported MP4 video. When the conversion is finished, you can click "Open" button to get the generated MP4 files effortlessly. Just transfer and play AVI movies on Samsung TV with ease.
Editor’s Note:
Besides transferring AVI video to Samsung TV through USB external drive, you can also cast AVI to Samsung TV directly with Chromecast. However, Chromecast doesn’t support AVI directly. Something you should note is- you still need to use change AVI format with the professional AVI to Samsung TV Converter first and then plug this thumb-sized media streaming device into the HDMI port on your TV. Then you can set it up with a simple mobile app and share your favorite online shows, movies, and even webpages to your TV using your smartphone, tablet or PC.
READ MORE:
How can I play MTS video on my Mac?
Best video player for watching MOV on Android
Trying to Play MKV (DTS encoded) files via DLNA
Guides about ripping DVD for uploading to Google Drive
Load DVD films to Samsung Galaxy Note 5 for Enjoyment
How to convert Blu-ray to any video format in Windows 10
Guide: How to Convert DVD to Facebook Video on Mac OS X
Source:Solution to Playing AVI Files on Samsung TV
