Convert Panasonic GX8 MP4 Video to Avid Media Composer
Postod Andyeric » 21.09.2015 8:24
Summary: Ever met any importing and transferring problems while you are trying to import GX8 AVCHD/MP4 to Avid MC? This tutorial will teach you how to easily enjoy it with help of the best HD Video Converter for Mac.
Hot search: Panasonic GX8 4K Video to Premiere Pro CC/AE | Panasonic GX8 4K Clips to FCP/iMovie/FCE | Panasonic HVX2000A MXF Files to Avid MC
The black Panasonic Lumix DMC-GX8 is a sleek, compact mirrorless camera enabling versatile, multimedia recording. In addition to the versatile still shooting modes, the GX8 also supports recording 4K UHD (3840*2160) video in the MP4 format. Full HD 1080p/60 is also supported, in both MP4 and AVCHD formats. But there are a few issues when it comes to viewing, importing and editing GX8 AVCHD/MP4 in Avid Media Composer.
"I want to buy Panasonic GX8. It can shoot video with AVCHD but wanted to check the better encoder. I’m working with Avid and it does not recognize the 4K file. How to solve this problem? How to import MTS video to Avid on Mac?"
If we want to import and edit Panasonic GX8 AVCHD/MP4 in Avid MC, the result may let you down- these popular video editing programs won't open the 4K footage from Panasonic GX8 correctly. Maybe an upgrade version of editing software could help. Still stuck with unsuccessful attempts? Perhaps there is some required codec missing or it is an incompatible video file format.
In this case, the easy workaround is to convert GX8 AVCHD/MP4 video to DNxHD, which is the best codec with best results when working with Avid MC. To finish the job, Pavtube HD Video Converter for Mac (review) would be the great help. The program can effortlessly encode/re-encode 4K H.264(MP4/MOV), XAVC, XAVC S, etc footage for smoothly importing and editing in various non-linear editing systems.
How to import Panasonic GX8 4K video to Avid?
Step 1: Launch the HD Video Converter on your Mac, and then click the "Add video" button to import your source files directly. In order to import several files at one time, you can click "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Avid Media Composer>>Avid DNxHD (*.mov)" as best output format.
Step 4: Now, click "Convert" and let it go. The program supports batch conversion. So if you have lots of files to convert, check "Shut down computer after conversion" and you can go away without keeping an eye on it.
Conclusion: Once the conversion process shows in 100%, click "Open" to get the output videos. Create a project and start editing GX8 4K video in Avid MC with light speed.
More related tips:
Source: http://bestvideoking.blogspot.com/2015/09/edit-gx8-avchd-mp4-in-avid-mc.html
