Handle Panasonic BWT740 MTS to MPEG-2 for Making DVDs
Postod Andyeric » 21.09.2015 8:21
Summary: Are you eager to know how to convert Panasonic BWT740 ACVHD MTS to MPEG-2 for making DVDs so that you can keep for the captured fantastic files? Read this article and find the best way here.
MTS is the file extension for the Advanced Video Codec High Definition, or AVCHD, video file type. Many camcorder manufacturers like Sony and Panasonic use this codec and the .mts file extension for the footage captured on their high definition camcorders. It really lets you down that MTS files can’t work with many video programs and editing software. If you want to burn Panasonic BWT740 AVCHD MTS for making DVDs, you will have no luck either.
If you would like to use Panasonic BWT740 AVCHD MTS files for making DVDs, I’m afraid that DVDs don’t have the ability to accept the MTS videos. To get the work done, you will first need to run it through a third-party program that can read it and convert Panasonic BWT740 AVCHD MTS to MPEG-2 for making DVDs. It means a MTS to MPEG-2 Video Converter is required.
There’s lots of conversion software out there, here we take Pavtube MTS/M2TS Converter for Mac (review) as example, a nice little program that can encode various video types into several other formats. There’s a lot more you can do with it, for instance, convert video from one type to another (of course including converting Panasonic BWT740 AVCHD MTS to MPEG-2), take snapshots of your favorite MTS videos, merge, clip and split files , batch processing and multi-threading. With optimized interface, this program only requires you to do few simple clicks.
http://download.pavtube.com/mts-converter-mac/mtsconvertermac_setup.dmgSlika Slika
How to convert Panasonic BWT740 AVCHD MTS to MPEG-2 for making DVDs?
Step 1: Download, install and run the program on your Mac. When the main interface pops up, please click "Add video" button to import Panasonic BWT740 AVCHD MTS files that you want to convert. You can load several files at once by clicking "Add from folder".
Step 2: Click format column and choose best video format for DVDs making. Just click and choose "Common Video>>MPEG-2 Video (*.mpg)" as output format for this profile is native format for converting Panasonic BWT740 AVCHD MTS for making DVDs. If you have the requirement to convert Panasonic BWT740 AVCHD MTS files to other programs, you can choose according to your need.
Step 3: Adjust video and audio parameters in Profile Settings, where you can get by clicking "Settings" on the main interface.
Step 4: Click "Convert" button to start process of converting Panasonic BWT740 AVCHD MTS to MPEG-2 for making DVDs. This best Mac MTS to MPEG-2 Video Converter will start the conversion process immediately.
Conclusion: After converting Panasonic BWT740 AVCHD MTS to MPEG-2, you can burn them into DVDs for keeping. It’s easy and it’s indeed of great convenience, right? The newly released Pavtube DVD Creator for Mac program makes DVD creation much easier than ever before. It lets you burn any kind of video sources to playable DVDs within a few clicks.
More related tips:
Source: http://lovecamcorder.tumblr.com/post/128697252192/convert-mts-to-mpeg-2-for-making-dvds
