Transfer Panasonic FZ1000 4K MP4 to MPEG-2 for Premiere Pro
Postod Andyeric » 21.09.2015 7:56
Summary: This guide you will know how to compress Panasonic FZ1000 4K MP4 and AVCHD MTS to Premiere Pro for editing with MPEG-2 native codec.
Hot search: Convert Panasonic FZ1000 4K Video to iMovie for Watching | Panasonic GX8 4K Video to Premiere Pro | Sony HDR-TD10 3D .mts/.m2ts to Premiere Pro
Panasonic FZ1000 is one of the hottest 4K cameras in this Summer. The headline feature of the Panasonic GH4 is that it’s a Micro Four Thirds camera that can shoot 4K video (in MP4, MOV format) for under $2000, capturing either Quad HD (3840*2160) at up to 29.97p or "Cinema 4K" (4096*2160) at up to 24p. If you recorded some videos by Panasonic FZ1000, you may like editing the 4K videos in Premiere Pro.
"Hi, all, does anyone have any experience of Panasonic Lumix FZ1000 and Premiere Pro workflow? I have just received my Panasonic FZ1000 camera the day before yesterday and everything is performing as expected, except there is no go when I importing FZ1000 4K video to Premiere Pro for basic editing. And yes I have other more robust video editing programs but I like the simplicity of Premiere Pro so I would like to use it. Does anyone know how to get around this and make Premiere Pro read FZ1000 raw footage flawlessly? I don’t even mind paying for third party software."
Premiere Pro won’t open and import Panasonic FZ1000 4K MP4/AVCHD correctly. Question is, what’s causing the issues? According to my experience, it may due to the high video resolution and the video codec incompatibility. Since MPEG-2 is the best editing video codec for Premiere, so we can convert Panasonic FZ1000 4K MP4/AVCHD (1080p would be the best settings) with a top 4K Video Converter, which will save you both time and trouble, and all you need is to drag the result videos for prompt editing.
Here Pavtube Video Converter is highly recommended. It does a good job in converting Panasonic FZ1000 4K MP4/AVCHD to Premiere most compatible format with least quality loss. Plus, it supports encoding camera shootings in different formats (MTS/M2TS, MP4, MXF, XAVC, etc.) to video editing software compatible file types, i.e. DNxHD for Avid Media Composer, MPEG-2 for Sony Vegas and etc. to meet your different needs.
How to convert Panasonic FZ1000 4K MP4/AVCHD to Premiere Pro?
Step 1: Download and have a quick installation. The trial version will have a watermark on your converted files. Except for that, there are no time limitation, no virus, and no unnecessary bundle apps while downloading. After that, click "Add Video" button to load your source files. You can load several files at once thanks to "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Adobe Premiere/Sony Vegas". Choose "MPEG-2 (*.mpg)" as best output format.
Step 4:
When everything is done, you can take a preview by hitting "Play" button. If you are satisfied with the final result, you can click "Convert" button to finish the conversion work.
Conclusion:
When the conversion is done, you can click "Open" to get your generated files. Now, you can edit Panasonic FZ1000 4K MP4/AVCHD in Premiere Pro without any hassles.
More related tips:
Source: http://camcordervideoshare.altervista.org/blog/import-fz1000-4k-mp4-avchd-to-premiere/
