Galaxy Note 5 vs Note 4: Best Professional Converter For Gal
Postod Andyeric » 01.09.2015 11:19
Galaxy Note 5 vs Note 4: Best Professional Converter For Galaxy Note
Summary: This guide focuses on making a comparison between Galaxy Note 5 and Note 4 and introduce the best Galaxy Note 5 Video Converter to you. Find out in the following part.
Hot search: Watch 3D Videos on Galaxy Note 4 | MKV/HD MKV to Galaxy Note 5 | Work MKV, AVI, VOB, WMV MPG, Tivo, WebM on Samsung Galaxy Note 4 | 3D Videos to Galaxy Note 4
A brief introduction to Galaxy Note 5:
Galaxy Note 5 is very hot now, there are more and more users choose to buy Galaxy Note 5 to replace old smartphones, the Galaxy Note 5 has 5.89 inches display so it is wonderful for us to copy videos and movies onto it for watching at anytime, anywhere. But on the forums there are a few of Galaxy Note 5 users have found that Galaxy Note 5 can't play all the video formats, such as WMV, MKV, M4V and other formats, the Galaxy Note 5 only plays H.264 MP4 files well. From Samsung Galaxy Note 5 official website you will get the know that Galaxy Note 5 best supported video format is H.264 MP4 format, for other formats you will get video playback issue. Below is the Galaxy Note 5 supported formats, please check.
Galaxy Note 5 supported video formats: MP4/DivX/XviD/WMV in H.264/H.263 codec
Galaxy Note 5 supported audio formats: MP3/WAV/eAAC+/AC3/FLAC
A brief introduction to Galaxy Note 4:
Samsung's Galaxy Note 4 was the most hotly anticipated phablet of the year until Apple came along last week and unveiled its first entry into the supersized smartphone market. It comes with the same-sized 5.7-inch screen as the Note 3, with Samsung instead deciding to improve on the quality of the screen rather than its size. The screen now boasts Quad HD Super AMOLED (2,560*1,440 resolution) technology that stretches to 500 pixels per inch. With a larger and satisfying definition screen, Galaxy Note 4 is also a perfect portable video player for you to enjoy movies. Galaxy Note 4 Supported Video/Audio Formats:
Video Formats: MP4, AVI, MKV, 3GP, WMV and FLV
Codecs: MPEG4, H.264, VC-1, DivX/XviD, H.263, Sorenson H.263
Audio Formats: MP3, AAC, WMA, WAV, AC3
Playback/Recording: 1080p Full HD@30fps, 720p HD@30fps
How to play unsupported videos on Galaxy Note 5?
From the information above you may have known Galaxy Note 5 supported video formats, you will also know that Galaxy Note 5 supported video formats are limited, there are a lot of video formats are not supported, such as MKV, AVI, MOV, M4V, MPG, MTS, FLV, VOB, DVD, Blu-ray, etc. In this case how to play unsupported videos on Galaxy Note 5? The best way is to convert unsupported videos to Galaxy Note 5 supported video format, such as MP4 format, and then you can play videos on Galaxy Note 5 with compatible format. Here we want to recommend the best Galaxy Note 5 video converter for you, the program isPavtube Video Converter (Mac version).
http://download.pavtube.com/video_converter/videoconverter_setup.exeSlika Slika
Detailed steps are offered here for your reference:
Step 1: Install and launch the corresponding program. Drag and drop your source files to the software. You can import multiple files at once thanks to batch conversion.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "HD Video>>H.264 HD Video (*.mp4)” as output format.
Step 3: Click "Settings” button to customize the output video and audio settings by yourself. But if you are not good at it, you'd better use the default parameters, they will ensure you a good balance between file size and image quality basically. You can change the resolution, bit rate, frame rate as you need.
Step 4: You can preview to check the final result. Once you are satisfied with it, click the "Convert” button to start conversion.
Conclusion: After conversion, you can get the generated files by clicking "Open” button. Follow the steps and have a try! This program will convert your videos at top speed, video and audio synchronization is perfectly guaranteed.
More related tips:
Source: http://android-ios-tips.tumblr.com/post/126899983163/best-galaxy-note-5-video-converter
