Encode H.265 files to Apple TV with smooth playback
Postod lauralily520 » 25.08.2015 11:00
As you know, Apple TV is the combination of on-demand media and easy access to your own extensive media library. Most of you probably have had the pleasure of using an Apple TV 3 for enjoyment any movie files you want. If you got some H.265 movies, why not add H.265 to Apple TV 3 for playback? If you also have the intention to play H.265/HEVC on Apple TV 3, read on to get the solution.
Well, to get H.265 files onto Apple TV 3, we should concern the video format compatibility. Officially, the Apple TV only supports MP4, MOV and M4V video. So, you need to encode/re-encode H.265 to Apple TV 3 friendly video first. To get the work done, you need a reliable H.265 converter to do the job. Overall, Brorsoft Video Converter Mac is considered to be the best choice for you.
This software is a powerful H.265 encoder, decoder and converter. It can help you convert H.265 videos to Apple TV 3 supported MP4/MOV/M4V files on Mac OS X(including Yosemite/Mavericks) with the best quality. It's easy to use, and performs professionally. What's more, this video converter severs as a wonderful H.265 video player for you. And with the built-in video editor, you can personalize and retouch your videos in clicks. For converting H.265/HEVC to Apple TV 3 on Windows, please get the Windows version- Video Converter. Download the program now and learn how to change H.265 movie to Apple TV 3.
How to convert H.265 video to Apple TV 3 with ease
1. Install and launch the H.265 to Apple TV 3 Converter on your Mac, and then click "Add" button to browse to H.265 footage or directly drag the H.265 video to the program.
2. Click “Format” bar and turn to the Apple TV category. The program has a number of presets for Apple TV, Apple TV 2, and Apple TV 3rd Generation, to export a Apple TV 3 1080p video with ac3 5.1 pass-through for AV receiver decoding, “Apple TV 3 Dolby Digital Pass-through (*.m4v)” preset is recommended.
Note: By choosing this format, you will get two sound tracks in the result M4V video, one is stereo, and the other is AC3 encoded Dolby Digital 5.1 pass-through. When your Apple TV is connected to audio receiver, the 5.1 surround sound will work. When ATV is connected to your HDTV only, the stereo track will work.
3. If you’re not satisfied with the result videos, you can click “Settings” to adjust codec, aspect ratio, bit rate, frame rate, sample rate and audio channel in the interface according to your needs and optimize the output file quality.
4. After everything is OK, simply click the big “Convert” button to start converting H.265 videos for Apple TV 3. Once the conversion finished, you can easily sync the converted H.265 files to Apple TV 3 with iTunes and then just enjoy.
Related Guides:
Convert DVD to Facebook friendly video
How to convert MKV to Facebook format
Top 5 iPhone Data Recovery Software Review 2015
Recover Deleted Files From Apple iOS Devices 2015
Convert H.265(HEVC) to Roku 3 supported file format
Convert HEVC/H.265 to Pinnacle Studio editable format
Transcode Sony HDR-AZ1 XAVC S to MPEG-2 for Avid MC
How to convert GoPro HERO4 Session MP4 to FCP/iMovie/FCE
How to backup and upload DVD videos to Seagate Wireless Plus?
Source: How to convert H.265 video to Apple TV 3 with ease
