Edit Phantom 3 4K Video in FCP 7/X
Postod Andyeric » 24.08.2015 11:17
Import Phantom 3 4K 4k video to Final Cut Pro
Summary: How to get Phantom 3 4K video works well with FCP 7/X? We share the workaround here for people who want to edit Phantom 3 4K video in FCP 7/X.
Hot search: Sony HD1550 XAVC 4K Video to FCP | Ikegami GFCAM MXF to FCP | Canon C300 Mark II MXF to FCP | DJI Phantom 2 Vision+ Video to FCP | DJI Phantom 2 Vision+ to Premiere Elements | DJI Phantom 2 Vision+ to iMovie | DJI Phantom 3 4K MP4/MOV to Premiere Pro
Phantom 3 Professional 4K Camera:
Finally, a flying camera that packs years of experience in aerial imaging into one compact, easy to use system. With the Phantom 3 Professional, you're shooting 4K video at up to 30 frames per second and capturing 12 megapixel photos that look crisper and cleaner than ever. A live HD view lets you truly experience flight and see everything from your camera in real time.
Why does Phantom 3 4K video look horrible in FCP 7/X?
"I just purchased a DJI Phantom 3 Professional camera, when I import the 4K video into FCP X, it looks blurry and pixely. However, when I view the same video out of the folder that it resides in, the video looks amazing. I'm assuming I'm doing something wrong during the import process. Any suggestions?"
The DJI Phantom 3 professional captured 4K video in MP4 or MOV(MPEG-4 AVC/H.264) format, which is not a native editing codec for Final Cut Pro. In addition, the 4K video footage compressed with MPEG-4 AVC/H.264 will still have big file size, it will take a lot of time for Final Cut Pro to render those 4K videos. To ensure a smooth workflow of Phantom 3 4K video with FCP 7/X, it is ideal for you to transcode Phantom 3 4K video to Final Cut Pro best editing codec- Apple Prores 422 codec, a post-production format designed for pristine quality and high-performance Final Cut Pro real-time editing.
Then what is the best video tool to deal with Phantom 3 4K video in FCP 7/X? I searched on the web and find an easy-to-use yet professional software called Pavtube HD Video Converter for Mac (review), it is only straightforward 4K converter which offers the best way to help the users of Phantom 3 to edit 4K videos in FCP 7/X smoothly by effortlessly and flawlessly transcode 4K footage to ProRes MOV. It is safe to install and easy to use.
How to edit Phantom 3 4K video in FCP 7/X?
Step 1: Launch the HD Video Converter on your Mac, and then click the "Add video" button to import your 4K videos from Phantom 3 directly. In order to import several files at one time, you can click "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Final Cut Pro>>Apple ProRes codec", including ProRes 422, ProRes 422 (HQ), ProRes 422 (LT), ProRes 422 (Proxy) and ProRes 4444. Choose the proper one you want.
Step 3: Press the "Settings" icon and you'd better set the video frame rate as 30fps, video size as 1920*1080 for editing Phantom 3 4K video in FCP 7/X easily.
Step 4: Now, click "Convert" and let it go. It supports batch conversion. So if you have lots of 4K videos to convert, check "Shut down computer after conversion" and you can go away without keeping an eye on it.
Conclusion: Once the conversion process shows in 100%, click "Open" to get the output videos. Create a project and start Phantom 3 editing 4K videos in FCP 7/X with light speed.
More related tips:
Source: http://lovecamcorder.tumblr.com/post/125914003602/edit-phantom-3-4k-video-in-fcp
