Importing Sony HDR-AZ1 XAVC S to Final Cut Pro X/7
Postod lauralily520 » 19.08.2015 10:33
Summary: Learn from this article, you can easily convert and import Sony HDR-AZ1 XAVC S footage into Final Cut Pro X/7 for further editing on Mac OS X(Yosemite, Mavericks included).
The splashproof HDR-AZ1 Action Cam Mini from Sony is designed for capturing POV footage of adventures of all kinds. It features 1080p60 recording in the lower-compression XAVC S format at 50 Mbps. Well, for Sony AZ1 users, here comes the Sony HDR-AZ1 XAVC S to Final Cut Pro incompatibility issues. Have you got XAVC S files from Sony HDR-AZ1, and found that it is unable to import the XAVC S to FCP X/7? Is it a Sony/Apple problem or more a problem of amateurs not understanding how to make it work?
Sony HDR-AZ1 records 1080/60p XAVC S files. While, the non-linear video editing software Final Cut Pro(including FCP X or FCP 7) cannot support XAVC S codec natively. So the best way for you to solve this issue is to transcode XAVC S to ProRes and edit away. In that case, you will need a powerful XAVC S converter. Here I’d like to recommend you to download Brorsoft Video Converter for Mac and use it to transcode Sony HDR-AZ1 XAVC S to FCP editable format Apple ProRes with the least loss of original video quality. By the way, besides encoding XAVC S to FCP, this Mac video converter offers the optimal preset profiles for iMovie, Avid Media Composer, Adobe Premiere Pro, FCE and more.
Step by Step Guide: How to transfer XAVC S from Sony HDR-AZ1 to FCP X/7 for editing
Step 1: Import XAVC S videos
Install and run the XAVC S to ProRes Converter on your Mac, then run it. Click on "Add", and browse your files; select all the XAVC S files you wanna convert.
Step 2: Choose ProRes as output format
Click the "Format" bar and select Final Cut Pro > Apple PreRes 422(*.mov) as output format.
Tips: Adjust video, audio settings
Click the "Settings" button and customize proper video/audio parameters including Video size, bitrate and fame rate and mroe. Usually 1920*1080 video size and 30fps video frame rate are recommended for FCP editing.
Step 3: Start XAVC S to ProRes conversion
After all necessary settings, hit the convert button to start the XAVC S to ProRes 422 conversion on Mac OS X.
Once the conversion process shows in 100%, click Open to get the output videos. Create a project and start editing Son HDR-AZ1 XAVC S video in Final Cut Pro 7 or FCP X with light speed.
See also:
Ripping Blu-ray/DVD collections to Sony Xperia M5
Encode GoPro Hero 4 4k videos to YouTube Sharing
Import Video_TS files to iMovie For Editing with OS X
How to convert HD videos to Google Nexus 7 2nd generation
Is Sony FDR-AX33 4K XAVC S files supported by Avid MC
How to Make Sony FDR-AX33 XAVC S files work with Avid
Can't Watch and Play H.265/HEVC 4K movie on Ultra HD TV
Transcode MTS files to MPEG-2 for Adobe Premiere Pro/Elements
How to convert Sony HDR-AZ1 XAVC S to Adobe Premiere format
Put Family DVD, Blu-ray movies to Sony Xperia C5 Ultra for Playback
Encode Panasonic P2 Card MXF footage to Premiere Pro CC/CS6/CS5
Guide of Converting Canon 7D Mark II MOV to MPEG-2 for Adobe PP
Source: Sony Action Cam Mini HDR-AZ1 to Final Cut Pro workflow
