Edit XAVC/XAVC-S in EDIUS Pro 7/8
Postod Andyeric » 18.08.2015 4:19
Summary: A quick and easy solution to make your XAVC/XAVC-S video compatible with EDIUS Pro 7/8 with the maximum editing quality and efficiency.
Hot search: TS File into EDIUS 567 | H.265/HEVC to EDIUS | MOV Files to EDIUS 6 | MXF to EDIUS Pro 7 | MP4 to EDIUS 6/7/8 | AVI Stuttering/Shaking Problems in EDIUS
Sony had expanded XAVC to the consumer market with the release of XAVC S, which supports resolution ups to 3840*2160 with MP4 container format and AAC or LCPM for the audio. The XAVC S format has been used in the Sony FDR-AX100 4K Ultra HD consumer camcorder and Sony HDR-AS100V action camera. The Sony A7S as well as some consumer stills camera with movie support also offer XAVC S.
Sony XAVC/XAVC-S camera and camcorder models:
PMW-F55, PMW-F5, PWM-400, PMW-300, PXW-X180, PXW-Z100, FDR-AX1, FDR-AX100, Alpha A7S, HDR-AS100V
The latest version of EDIUS vesion 7.41 and its later version supports all types of XAVC and XAVC-S. But for its former versions such as EDIUS Pro 6.5 or, people will often complained that they get only audio but no video files when importing the XAVC video footage to EDIUS Pro for editing. This error can be caused by the unrecognized codec contained in your XAVC video footage.
To solve above mentioned problems, you will need to transcode or rewrap the video files that you are going to edit with EDIUS Pro 7/8 into one single file format or codec that can be easily recognized by EDIUS Pro 7/8 as below:
Video format: 3GPP, AVCHD, AVC-Intra (4K 444/4K 422/4K-LT/200/100/50), AVC LongG, AVI, DIF stream, DVCPRO(DVCPRO HD/50/25), Flash Video, MPEG HHD MOVIE, MPEG Program Stream, MPEG Transport Stream, MPEG Video Stream, MPEG File, MXF, P2 Clip File, QuickTime Movie, RED File, SONY HVR-DR60/HVR-MRC1 Meta File, Transport Stream (MPEG2, H.264), Windows Media*1, XAVC, XAVC-S, XDCAM, XDCAM EX, XF Clip File.
Audio format: AAC Files, AIFF Files, Dobly Digital (AC-3), Dobly Digital (AC-3) (for professional), MPEG Audio Layer-3, MPEG Audio Stream, Ogg Vorbis Files, Wave Files, Windows Media Audio.
After multiple testing, I found Pavtube Video Converter is the best option. It is able to convert XAVC/XAVC-S to EDIUS Pro 7/8 friendly format easily with the best video quality. Besides XAVC/XAVC-S, this video convert program can also help to convert between any popular video and audio formats as you need. Plus, with the built-in video editing feature of the program, you can trim, crop, add watermark and more to your video files.
How to import XAVC/XAVC-S to EDIUS Pro 7/8?
Step 1: As soon as you download and install the program, launch it and when the main interface pops up in front of us, just click the "Add Video" or "Add from Folder" to let in.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)" as output format.
Step 4: After that, click "Convert" to start XAVC/XAVC-S to EDIUS Pro 7/8 conversion.
Conclusion: After conversion, you can get the generated files by clicking "Open" button. Now, you’ll get no troubles in editing XAVC/XAVC-S file in EDIUS Pro 7/8.
Further Reading:
Import 2K/4K Sony XAVC/XAVC-S/XAVC-L to Edius Pro 4/5/6
How to Edit H.265/HEVC 4K Video with Edius Pro 4/5/6/7/8?
How to Edit MKV, AVI, MTS, TS, MXF, VOB, WMV, Tivo on Edius 7/8?
Simple Way to Import Canon C100 Mark II AVCHD to Sony Vegas Pro 13/12
Display 4:3 Aspect Ratio Fullscreen Video/Movie on 16:9 Widescreen
Can FCP 6/7/X Ingest iPhone MOV Files?
Convert DJI Inspire 1 4K Files to 1080p for Editing on Mac/PC
Source: http://camcordervideoshare.altervista.org/blog/edit-xavc-xavc-s-in-edius-pro-7-8/
