Great Converter to Fix MOV Files to EDIUS 6 Import Issues
Postod Andyeric » 18.08.2015 4:16
Summary: Fail to find a nice MOV converter Workflow to convert MOV to MPEG-2 on EDIUS 6? If you meet problem like this, you can read to this article here to do the job.
Hot search: MKV to EDIUS Pro 8 | GoPro MP4 to EDIUS Pro 7 | AVI to EDIUS 7/7.01 | Panasonic DVCPro HD MXF to EDIUS Pro 7 | MP4 Video to EDIUS 6/7/8 | H.265/HEVC in EDIUS 5/6/7/8
EDIUS Pro provides a simple alternatives to the industry leaders, but it has all of the tools that other professional video editing software has such as powerful tools, enhanced timeline, advanced multicam support, 64-bit processing. One peculiarity that sets EDIUS Pro apart from others is that it doesn't utilize GPU acceleration for rendering, transcoding and exporting videos. And this is a big advantage over other applications that require time and processing capacity to render footage.
When you import MOV files to EDIUS, you may face some errors or issues like EDIUS crashed, MOV can't be recognized and etc.
-"When working with QuickTime MOV files, EDIUS 6 crashes a lot! Any suggestion for me? "
-"I’ll get some MOV files and I have to edit them with EDIUS 6. Does EDIUS 6 work fine with MOV files or I have to convert them? If I have to convert them, what is the best video tool? What file format have I to get from conversion?"
EDIUS Pro supported format for file import:
So, is there any way to fix MOV files crashed issue with EDIUS 6? From the table list above, I got some hints. What I can do with the current project is take the MOV files I have and convert it for use with EDIUS 6. And what I need is a great MOV converter. After multiple testing, I found Pavtube Video Converter is the best option for me. It is able to convert MOV files to EDIUS 6 friendly format MPEG-2 easily with the best video quality. Besides MOV, this video convert program can also help to convert between any popular video and audio formats as you need. Plus, with the built-in video editing feature of the program, you can trim, crop, add watermark and more to your video files.
How to import MOV files to EDIUS 6 for smoothly editing?
Step 1: As soon as you download and install the program, launch it and when the main interface pops up in front of us, just click the "Add Video" or "Add from Folder" to let in.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)" as output format.
Step 4: After that, click "Convert" to start MOV to EDIUS 6 MPEG-2 conversion.
Conclusion: After conversion, you can get the generated files by clicking "Open" button. Now, you’ll get no troubles in fixing EDIUS 6 crashes with MOV files.
Further Reading:
How to Edit H.265/HEVC 4K Video with Edius Pro 4/5/6/7/8?
How to Edit MKV, AVI, MTS, TS, MXF, VOB, WMV, Tivo on Edius 7/8?
Put HD Videos to Android Devices on Windows 10/El Capitan
How Can I Edit 3D MTS from Sony HDR-TD20V in FCP X?
Convert Phantom 3 4K Video to DNxHD MOV for DaVinci Resolve
Edit Sony HDR-CX440/B Footage in iMovie 11
Two Ways to Import Canon XF100 MXF to Premiere Pro CS6 for Editing on Mac
Source: http://1080p-video-tool.blogspot.com/2015/08/fix-mov-files-to-edius-6-import-issues.html
