MXF to EDIUS Pro 7 workflow--Perfect Edit Panasonic HD
Postod Andyeric » 14.08.2015 4:10
MXF to EDIUS Pro 7 workflow--Perfect Edit Panasonic DVCPro HD
Summary: This article mainly talks about how to import Panasonic DVCPro HD MXF to EDIUS Pro 7 for seamlessly editing. If you are confused about MXF to EDIUS Pro 7 workflow, you’ve come to the right place!
Hot search: MKV to EDIUS Pro 8 | GoPro MP4 File with EDIUS Pro 7 | AVI to EDIUS 7/7.01 | MP4 Video to EDIUS 6/7/8
"I've been struggling to import DVCPro HD in an MXF wrapper to EDIUS 7.21.822. No matter the settings, I get an error of ‘Could not use the selected format. Please confirm setting’. It doesn’t matter how I set them. Any ideas?"
EDIUS Pro 7 is the fastest and most versatile real-time editing software- 4K, 3D, HD, SD and almost any format from 24×24 to 4Kx2K, all on the same timeline, even in nested sequences, all in real-time. EDIUS Pro 7 gives you the ability to handle more resolutions, unlimited tracks and real-time editing for the ability to edit anything, anywhere. EDIUS Pro 7 is the perfect finishing tool for studio, news, corporate, documentary and 4K theatrical productions.
In order to import Panasonic DVCPro HD MXF to EDIUS Pro 7 smoothly, you’ll need to convert DVCPro HD MXF to a format that is suited for editing in EDIUS 7, like WMV, MOV, DNxHD and more. After multiple testing, I found Pavtube Video Converter is the best option for me. It is able to convert DVCPro HD MXF to EDIUS friendly format WMV easily with the best video quality. Besides DVCPro HD MXF, this video convert program can also help to convert between any popular video and audio formats as you need. Plus, with the built-in video editing feature of the program, you can trim, crop, add watermark and more to your video files.
How to import Panasonic DVCPro HD MXF to EDIUS Pro 7?
Step 1: As soon as you download and install the program, launch it and when the main interface pops up in front of us, just click the "Add Video" or "Add from Folder" to let in.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "HD Video>>WMV HD (*.wmv)" as output format.
Step 4: After that, click "Convert" to start DVCPro HD MXF to WMV conversion.
Conclusion: After conversion, you can get the generated files by clicking "Open" button. Now, you’ll get no troubles in importing Panasonic DVCPro HD MXF to EDIUS Pro 7.
Further Reading:
Convert JVC GY-HM200 MTS to ProRes for FCP X
Make Sony HX400V MTS Editable in Premiere Pro
Edit nanoFlash MXF in FCP
Top AVC-Intra MXF Converter
How to View GoPro Video on iPhone?
Get Phantom 3 4K MP4/MOV Files Work Well with After Effects
Import Canon Vixia MTS to iMovie for Burning to DVD
Source: http://file-editing-tips.over-blog.com/import-panasonic-dvcpro-hd-mxf-to-edius
