MP4 to EDIUS 6/7/8 Converter--Edit MP4 Video in EDIUS
Postod Andyeric » 14.08.2015 4:03
Summary: This article focus on problems which occur when adding MP4 video to EDIUS 6/7/8 timeline and provides a quick and easy solution.
Hot search: MKV to EDIUS Pro 8 | GoPro MP4 File with EDIUS Pro 7 | AVI to EDIUS 7/7.01 | AVI to Sony Movie Studio 11 | Movie Maker WLMP to AVI
EDIUS is a non-linear editor (NLE) that works with most modern video formats. As an ideal video editing tool, EDIUS is widely used by video professionals and hobbyists. You probably would like to use EDIUS to edit MP4 recordings to get more wonderful video files. While, some errors appeared when adding MP4 video to EDIUS 6/7/8 timeline: file import failure, no video playback, program crashed and etc.
“I am looking for suggestions on MP4 workflow with EDIUS. Recently I’ve received a Sony a7 II camera which records footage in XAVC S codec in MP4 format. I intend to edit these MP4 videos in EDIUS 6.5.3, but it seems that the EDIUS 6 doesn’t recognize XAVC S MP4 footage as import. I know that the most recent EDIUS Pro 7 has support for XAVC Intra 4K and HD as well as XAVC S Long GOP QFHD and HD, but there’s no go on EDIUS 6 system. How can I get the XAVC S MP4 video to EDIUS 6? I really appreciate any help.”
If you don’t want to upgrade the version, you’ll need to convert MP4 to a format that is suited for editing in EDIUS 6/7/8, like WMV, MOV, DNxHD and more. After multiple testing, I found Pavtube Video Converter is the best option for me. It is able to convert MP4 to EDIUS friendly format WMV easily with the best video quality. Besides MP4, this video convert program can also help to convert between any popular video and audio formats as you need. Plus, with the built-in video editing feature of the program, you can trim, crop, add watermark and more to your video files.
How to add MP4 video to EDIUS 6/7/8 timeline?
Step 1: As soon as you download and install the program, launch it and when the main interface pops up in front of us, just click the “Add Video” or “Add from Folder” to let in.
Step 2: Click the drop-down list in the format line to get the format box. Then choose “HD Video>>WMV HD (*.wmv)” as output format.
Step 3: Click “Settings” button to customize the output video and audio settings by yourself. But if you are not good at it, you’d better use the default parameters, they will ensure you a good balance between file size and image quality basically. You can change the resolution, bit rate, frame rate as you need.
Step 4: After that, click “Convert” to start MP4 to WMV conversion.
Conclusion: After conversion, you can get the generated files by clicking “Open” button. Now, you’ll get no troubles in adding MP4 video to EDIUS 6/7/8 timeline.
Further Reading:
Import AEE S71 MP4 to FCP 7/X for Editing
Phantom 3 4K MP4/MOV to iMovie 11/09/08 Workflow
Import Panasonic HX-A1 MP4 to After Effects for Editing
Stream FLAC to Apple TV to Play FLAC on Apple TV
Import Sony PMW-PZ1 XAVC to QuickTime for Playing
Edit Canon C300 Mark II MXF in Avid NewsCutter 10
Upload GoPro 4K Video to Instagram for Sharing
Source: http://mediaconverting.blogspot.com/2015/08/add-mp4-video-to-edius-timeline.html
