Import AVI File Stuttering/Shaking Problems in EDIUS 7/7.01
Postod Andyeric » 14.08.2015 4:00
Summary: Are you looking for an easy, quick and affordable way to seamlessly convert AVI file to MPEG-2 so that you can edit them in EDIUS 7/7.01? Consider it done.
Hot search: MKV to EDIUS Pro 8 | GoPro MP4 File with EDIUS Pro 7 | AVI to Windows Movie Maker | AVI to Sony Movie Studio | XAVC MXF to AVI
AVI, Audio Video Interleave video file format is developed by Microsoft mainly for Windows operating systems. Audio and video can be played in synchronous format without any halt in the video. AVI file format can be played with various media players like AVI media player, Media player classic, Plex and many others. People who have tons of AVI files at hand usually ask the same or similar questions when they try to edit AVI file in EDIUS 7/7.01.
"After my negative testing experience with EDIUS 7 on a Windows 8 Machine, the AVI file is stuttering/shaking during playback and after exporting to an .m2ts file. There is no buffering issue. When I load the same video file to my EDIUS 6.08 system all looks smooth and normal the output file is perfect!"
EDIUS 7 is a new engine under the hood and 64-bit, it can affect various subsystems differently than previous versions. Is there any way to solve AVI file stuttering/shaking problems with EDIUS 7/7.01? Searching the web, I got some hints. What I can do with the current project is take the AVI I have and convert it for use with EDIUS 7/7.01. And what I need is a great AVI converter. After multiple testing, I found Pavtube Video Converter is the best option for me. It is able to convert AVI to EDIUS 7/7.01 friendly format MPEG-2 easily with the best video quality. Besides AVI, this video convert program can also help to convert between any popular video and audio formats as you need. Plus, with the built-in video editing feature of the program, you can trim, crop, add watermark and more to your video files.
How to solve AVI file stuttering/shaking problems with EDIUS 7/7.01?
Step 1: As soon as you download and install the program, launch it and when the main interface pops up in front of us, just click the "Add Video" or "Add from Folder" to let in.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)" as output format.
Step 4: After that, click "Convert" to start AVI to EDIUS 7/7.01 MPEG-2 conversion.
Conclusion: After conversion, you can get the generated files by clicking "Open" button. Now, you’ll get no troubles in editing AVI file in EDIUS 7/7.01. AVI file stuttering/shaking problems with EDIUS 7/7.01 have been solved!
Further Reading:
Downsize Sony 4K XAVC to 1080p for Playing Smoothly
How Can I Edit 3D MTS from Sony HDR-TD20V in FCP X?
Smoothly Edit Sony F55/F5 4K XAVC in Final Cut Pro 6/7
How to Play MOV on iPhone?
Work with Canon C100 Mark II AVCHD in iMovie
Upload Canon C300 MXF to YouTube/Vimeo for Sharing
Import Canon EOS 5DS R MOV to Final Cut Studio
Source: http://pc-mac-compatibility-issues.blogspot.com/2015/08/import-avi-file-to-edius-7-7.01.html
