Workaround to import OBS files to Pinnacle Studio
Postod lauralily520 » 11.08.2015 10:17
Summary: Have got some OBS recordings and want to import/edit OBS files in Pinnacle Studio without issue; check out the guide to learn how to convert OBS files to Pinnacle Studio compatible MPEG-2 video format.
If you obtain many OBS files, you may wanna edit these OBS videos in Pinnacle Studio. Whereas, when you import OBS files to Pinnacle Studio for further editing, you will probably get some issues like program crashed, black viewer screen, no audio track... So, what's the available workflow for OBS files(MP4/FLV) in Pinnacle Studio? Okay. This article will present you how to work OBS files in Pinnacle Studio flawlessly in detail.
As mentioned above, Open Broadcaster Software(OBS) generally can record FLV and MP4 videos. Although Pinnacle Studio supports FLV and MP4 format, due to the different video/audio codes contained in a video file, some incompatible issues with Pinnacle still exist. To prepare OBS recordings for Pinnacle, the easy option is to transcode OBS files to Pinnacle Studio natively supported formats (MPG/WMV/MOV are highly recommended). Brorsoft Video Converter is the first and best choice for you.
The program is the best Video Converter for OBS footage. With this OBS video converter, you can effortlessly convert OBS FLV/MP4 to MPEG-2, which will create Pinnacle Studio friendly file format keeping the original quality. Besides Pinnacle, this software can also export DNxHD for Avid Media Composer, WMV for Windows Movie Maker and more NLE systems for native editing. Just download it and follow the tutorial below to get the work done.
How to convert OBS for editing in Pinnacle Studio smoothly
Step 1: Load OBS files to the software
Install and launch the best OBS to Pinnacle Studio converter and load source FLV, MP4 clips to it. You can also drag and drop the OBS files to the software directly.
Step 2: Choose output format
Click "Format" pull down list to select Adobe Premiere/Sony Vegas> MPEG-2(*.mpg) as the best video format for Premiere Pro. WMV, MOV formats are the good choice as well.
Tip: Advanced Settings You can click the “Settings” button and customize proper video/audio parameters if necessary. Video size, bitrate and fame rate are flexible and can be adjusted as you like.
Step 3. Convert OBS video to Pinnacle
Click the convert button under the preview window; this OBS file converter will start encoding OBS flv/mp4 to Pinnacle Studio.
When the conversion process shows in 100%, you can get the resulted videos from output folder for easier editing in Pinnacle Studio 9/11/12/14/16.
More Guides:
Convert OBS recording for Sony Vegas Pro 11/12/13
Transfer Android videos to FCP/iMovie/FCE for editing
Transcode Canon C300 Mark II MXF clips to Mac Editing
Import Video_TS to iTunes for Syncing to iPad/iPhone/iPod
Make MTS/M2TS videos editable in Cyberlink PowerDirector
Best Sony AX33 Workflow Guide with Avid Media Composer
How to Make Sony FDR-AX33 XAVC S files work with Avid
Freemake Alternative for Mac (El Capitan) to Rip DVD on Mac
Encode Canon C300 Mark II 4K XF-AVC/H.264 MXF to Premiere
How to import Sony AS30V MP4 video into FCP, Premiere, Avid
Import Canon EOS C300 Mark ii 4k MXF to Final Cut Pro7, FCP X
Source: How to convert OBS for editing in Pinnacle Studio smoothly
