Convert Canon C300 Mark II MXF to PowerDirector for Editing
Postod Andyeric » 05.08.2015 9:18
Summary: If you want to import MXF to PowerDirector, just convert MXF to MPG so that you can edit Canon C300 Mark II MXF in PowerDirector smoothly. Keep reading and learn how to.
Hot search: C300 Mark II MXF to Avid MC | C300 Mark II MXF to iMovie | C300 Mark II MXF to FCP X | C300 Mark II MXF to Premiere Pro
Canon C300 Mark II is a hot camcorder on the market, since it released it has attracted great attention due to its excellent hardware equipment. It features a Super 35mm CMOS sensor, which will help you to record 4K, 1920*1080 60/50i, 23.98/25p True 24p videos. Besides Canon C300 Mark II uses Dual Pixel CMOS AF technology. This provides faster and more accurate autofocusing to assist users when operating with small crews. With C300 Mark II you can record high quality videos, it delivers the highest image quality with its XF Codec–the same codec used by other Canon XF professional camcorders.
Canon C300 camcorder is shooting footage in MXF format- a file type not well supported by most popular professional video editing software, like Cyberlink PowerDirector. We’ve searched the supported file formats of PowerDirector 13/12/11/10/9/8, and we can easily find supported file formats of different versions. It’s clearly that MXF is not included in all the lists. So you must want to know how to edit Canon C300 Mark II MXF in PowerDirector to create your own masterpieces at this time, right?
In this case, Pavtube MXF MultiMixer is what you need indeed. This Canon C300 MXF Converter is especially designed for MXF camcorders users, with which you can easily convert Canon C300 Mark II MXF to PowerDirector 13/12/11/10/9/8 editable format like MPEG-2 at super fast speed due to the advanced CUDA technology support. What’s more? This professional tool comes with powerful video edit function, like trimming, cropping, adding watermark, etc. Thus, you can do some simple edit first according to your need. The latest version can support H.265/HEVC encode/decode and encoding to M3U8, that’s may be the newest attractive point we would like to enjoy.
- Pavtube old official address: http://www.pavtube.com/mxf-multimixer/
- Amazon Download: http://www.amazon.com/Pavtube-Studio-MXF-MultiMixer-Download/dp/B00QI35ELI
- Cnet Download: http://download.cnet.com/Pavtube-MXF-MultiMixer/3000-2194_4-76171745.html
How to convert Canon C300 Mark II MXF to PowerDirector for editing?
Step 1: Download and install the program. Click "Add video" button to load your original MXF files or directly drag the files into file list. By default, the files are selected. You can delete files which you don't want to import to.
Step 2: Choose the output video format in the "Format" bar. There are all kinds of video formats, editing softwares and portable devices for your consideration. For converting C300 Mark II MXF to PowerDirector, you can choose "Common Video>>MPEG-2 Video (*.mpg)".
Step 4: Click the "Convert" button on the main interface if you have done all the preparation work. This is the workflow that we need to convert MXF to MPG.
Conclusion: Once the conversion is finished, click "Open" to quickly find the converted files. Then, PowerDirector 13/12/11/10/9/8 will recognize, catalog, play and stream them just fine.
More related tips:
Source: http://1080p-video-tool.blogspot.com/2015/07/convert-mxf-to-powerdirector.html
