Encode MKV to H.265 MP4 video with best quality
Postod lauralily520 » 10.07.2015 10:49
Summary: If you want to get started and convert your MKV files to H.265 but don't have any idea where to begin, we are here to help you. Just read further to know how to convert MKV to H.265 MP4 video easily.
A lot of guys want to convert video files like MKV to H.265, as H.265(HEVC) can compress video files to 50% with the most proficient encoding format today, MPEG-4, or also known as the H.264. More significantly, H.265 is being used to compress video files that have 4K resolution. Well, to achieve the goal, you will need to have a reliable H.265 converter to do the job. In this article, I just aim to tell you how to convert MKV to H.265 MP4 with a top H.265 encoder. Read on.
With luck, I’ve found a professional H.265 converter- Brorsoft Video Converter from Google. Based on my testing, it works perfectly and now I’d like to share it with all of you. This top MKV to H.265 converter enables you to convert MKV as well as M2TS, MTS, AVI, TS, WMV, MOV, MPEG, etc. to H.265 MP4 rapidly in high quality. The converting speed is faster than any other video convert software programs. With the Edit function, you can trim, crop, add watermark, adjust effects, add subtitles as you like. If you are going to encode MKV to H.265 on Mac OS X (Yosemite and Mavericks), you can get Video Converter for Mac. Download it from below and read further to know how to successfully convert your MKV video files into H.265 MP4 format.
Tutorial: How to convert MKV to H.265 MP4 easily and quickly
Step 1: After downloading the software, install and run it. Click “Add” to import all MKV files. This video converter supports batch conversion.
Step 2: To encode videos to H.265 MP4, just hit the "Format" box and select H.265 Video(*.mp4) from Common Video profile. It ensures the best quality.
Tip: To adjust video and audio parameters like codec, aspect ratio, bit rate, frame rate, sample rate, you could click on "Settings" button.
Step 3: Click Convert button to start transcoding MKV to H.265 MP4. Once the conversion finished, click the Open button and you can locate the output files effortlessly. And then you can play, share the converted MKV files anywhere.
Additional Tips:
This versatile MKV to H.265 Converter not only can convert MKV to H.264 .mp4 video easily, it also can convert any video, audio format like AVI, MOV, WMV, TiVo, VOB, FLV, MTS, XAVC, MP3, WAV, M4A, etc to another format you want with the best quality.
See also:
Rip Blu-ray movies to 1080P DivX AVI videos
Issues importing .mp4 files to Final Cut Pro X
Losslessly convert Blu-ray to 1080p DivX AVI files
Convert MP4 to Apple ProRes for editing with OS X
Transcode MXF files to MOV for Quicktime on Mac
Rip Blu-ray to Dropbox friendly video formats for uploading
Edit Samsung NX500 H.265/HEVC files in Final Cut Pro 7/X
Import Samsung NX500 H.265/HEVC to Final Cut Pro X/7/6
Convert Sony HDR-CX100E AVCHD to AIC MOV for iMovie
Copy iPhone Voice Memos to Save on Your Computer Playing
Source: Transferring HD MKV to H.265 MP4 Playback
