Ingest HC-X1000 4K AVCHD MTS to iMovie 11/10/9
Postod Andyeric » 09.07.2015 8:36
Panasonic HC-X1000 4k AVCHD workflow for iMovie 11/10/9
Summary: Failed to import Panasonic HC-X1000 4K AVCHD MTS to iMovie 11/10/9? Always edit Panasonic HC-X1000 4K AVCHD MTS in iMovie 11/10/9 unsuccessfully? Read through to know iMovie 11/10/9 better on the recommended video formats. Tips for how to ingest HC-X1000 4K AVCHD MTS to iMovie 11/10/9 are also provided.
Hot search: MTS Column|Paansonic Column | AVCHD to FXhome HitFilm | AVCHD to FCP|AVCHD to Premiere Pro CS5|AVCHD to Premiere Pro CC|MTS to Avid Media Composer | AVCHD to Sony Vegas Pro|MTS to Panasonic Media Player | MTS to Sony Movie Studio
Panasonic HC-X1000 is a powerful camcorder, it works as 4K DCI/Ultra HD/Full HD Camcorder, and with it you can jump right into 4K. In case that you encountered import issues while handling Panasonic HC-X1000 4K AVCHD MTS clips with iMovie 11/10/9, you can consider converting these HD video contents to a format that is best suited for iMovie 11/10/9, such as AIC MOV.
Panasonic HC-X1000 can record videos in MP4, MOV or AVCHD codec, have you recorded some wonderful videos with this camcorder? After you recorded videos with it, you may have the need to import Panasonic HC-X1000 4K AVCHD MTS to iMovie 11/10/9 for editing. 4K Video and AVCHD MTS format is not easy to use as it's not well supported by many editing software, especially on Mac. Currently neither iMovie nor FCE supports the original 4K Video, AVCHD MTS footages from HC-X1000, that's why you cannot import Panasonic's HC-X1000 files to iMovie 11/10/9.
If you have ever used iMovie, you may know there are limited video codecs and formats are supported by iMovie 11/10/9. In this case, how can we avoid the Panasonic HC-X1000 4K AVCHD MTS to iMovie 11/10/9 importing issue? It's easy. The common practice for HC-X1000 footage workflow with iMovie 11/10/9 is, get a Top MTS/M2TS Converter for Mac and transcode HC-X1000 4K AVCHD MTS to AIC (Apple Intermediate Codec), the well-acknowledged optimal editing format for iMovie 11/10/9. Here Pavtube MTS/M2TS Converter for Mac is highly recommended, which can save you both time and troubles. All you need is drag and drop the result videos for prompt editing. (Read also: Best MTS/M2TS Converter for Mac Reviews)
How to ingest HC-X1000 4K AVCHD MTS to iMovie 11/10/9?
Step 1. Free download this best 4K AVCHD MTS to iMovie 11/10/9 Converter. Install and run it as the best Panasonic 4K AVCHD MTS to iMovie 11/10/9 Converter. It supports single or batch conversion. Therefore, you are able to add individual or multiple 4K AVCHD MTS footages into the program at one time. Click the "Add video" button on the tool bar to finish the input.
Step 2. Click the drop-down list in the "Format" line to get the format box. Then choose "iMovie and Final Cut Express -> Apple InterMediate Codec (AIC) (*.mov)" as output format compatible with iMovie 11/10/9.
Step 3. The built-in editing function provided by 4K AVCHD MTS to iMovie 11/10/9 converter is something worth trying. To trim the video, add artistic effects, adjust audio, add watermark, customize video parameters and so on. You can get the work done splendidly. Of course, if you don't think it's a necessary to do, you can skip it and move onto the next step directly.
Step 4. You can preview to check the final result. Once you are happy with it, click the "Convert" button to start converting Panasonic HC-X1000 4K AVCHD MTS to iMovie 11/10/9 supported AIC MOV. It will take you a little while.
Conclusion: After the conversion is done, launch iMovie 11/10/9 and do the edit work. For more operation information about iMovie, you can refer to the article: How to import video files to iMovie 8/9/11 on Mac? Don't wait. Just follow the steps above and enjoy your editing!
Good news! Pavtube Bundles Deals are coming! It's a time for taking a break from work and relaxing. And now you can enjoy your colorful time with good featured products at "Pavtube Bundles Deals". Go ahead and click the link to get your coupon. Save up to $44.1!Never miss!!!
- MTS/M2TS Converter for Mac($29) + MXF Converter for Mac($29) = Only $29.9
- MTS/M2TS Converter for Mac($29) + MKV Converter for Mac($29) = Only $29.9
MTS/M2TS Converter for Mac($29) + FLV/F4V Converter for Mac($29) = Only $29.9
- iMixMXF($45) + HD Video Converter for Mac($35) = Only $54.9 .....
Further Reading:
Compress MTS to MP4 with Handbrake
Edit Nabi Square HD 4K Video in FCP
Convert Sony Camera Video to QuickTime for Playback
Encode Blackmagic 4K to ProRes and DNxHD on Mac
Play Sony HDV Video on Smart TV or Media Player
Audio does not work for MPEG-2 file to FCP X?
Sony AX-100 4K XAVC S and Premiere Pro Workflow
Encode MXF to MOV, MPG, MP4, AVI, WMV, FLV on Mac/PC
Import Sony XAVC MXF to Adobe Premiere Pro
Play AVI Videos on QuickTime Player
How to Upload iMovie Videos to Facebook?
Import Canon XC10 MXF to Avid Media Composer
Import GoPro 4K Video to Final Cut Pro X
Source: http://camcordervideoshare.altervista.org/blog/import-4k-avchd-mts-to-imovie/
