Import Sony a7R II XAVC S into Final Cut Pro 7/X
Postod lauralily520 » 06.07.2015 11:00
The newly released Sony a7R II has won lots of attractions from videographers for its major feature- internal UHD 4K 3840 x 2160p recording in XAVC S format. However, there are a few issues while playing and editing Sony a7R II XAVC S footage in FCP 7/X or other NLEs. Now, some tips and tricks for Sony a7R II XAVC S to FCP workflow are listed below. Read on you can find something useful you want.
As a user of Sony a7R II, you must be excited that Sony a7R II can record videos upto 4K and maybe eager to edit the 4K XAVC S in Final Cut Pro to get some superb masterpiece. However, it is a pity that Apple’s Final Cut Pro even the FCP X hardly supports 4K XAVC S files. The easy workaround here is to transcode and rewrap Sony a7R II XAVC S clips into Apple ProRes codec for FCP with a best program- Brorsoft Video Converter for Mac, a solid tool to help users convert 4K XAVC S to ProRes, which ensures the best results when using in Final Cut Pro 7 or FCP X.
With this professional XAVC S to FCP converter, you can effortlessly encode/re-encode 4K or 1080p XAVC-S from Sony A7R II for smoothly importing and editing in various non-linear editing systems (NLE), including Final Cut Pro X, FCP 6/7, iMovie, Final Cut Express, Adobe Premiere Pro, Avid Media Composer, etc. Follow the article to learn how to transcode Sony a7R II XAVC S to FCP X or FCP 7 editable format step by step.
Tutorial on converting Sony a7R II XAVC S to Final Cut Pro in simple steps
1. Launch the XAVC S to ProRes Converter; click “Add Videos” icon to load your source XAVC S videos from Sony a7R II for converting. It supports batch conversion.
2. Click “Format” bar and choose “Final Cut Pro > Apple ProRes 422 (*.mov)” as output format for editing XAVC S in FCP with natively supported video codec.
Tip: Click “Settings” button if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sample rate, audio channels.
3. After all necessary settings, click the convert button; it will start converting Sony a7R II XAVC S to ProRes .mov for importing to Final Cut Pro immediately.
After the conversion, just click “Open” button to get the generated files for natively editing in FCP 7 as well as FCP X without hassle.
Related Guides:
Work Nikon P900 H.264 in iMovie easily
Sony 4K XAVC to 1080p video for editing
Embed and Play DVD movies in PowerPoint
Play MKV/AVI/VOB files on Tesco Hudl 2, Hudl 3
Editing Nikon Coolpix P900 MOV in iMovie 09/11
Play MKV/MP4/VOB/MTS/ProRes/YouTube on PPT
Editing Sony α7R ii XAVC S files in Adobe Premiere Pro
Downscale 4K XAVC S to 1080p for playback and editing
Convert and insert DVD (ISO, IFO) to PowerPoint on Mac
Find the Solution to Rip DVD to iPad Air 2 on Windows/Mac
Apple TV 2015 Reviews: What to expect from the new Apple TV
Encode MTS/MPG/VOB/TiVo files to Play on Nvidia Shield Tablet
Source: Editing Sony a7R II XAVC S in Final Cut Pro 7/X
